How fast does the skin of the airplane cool to surrounding temperatures?
Old December 9th 06, 04:38 PM posted to rec.aviation.piloting
Jay Somerset
Default How fast does the skin of the airplane cool to surrounding temperatures?
On 8 Dec 2006 18:39:30 -0500, "Ash Wyllie" wrote:
Mxsmanic opined
writes:
On a clear night the skin temperature can go BELOW the air
temperature due to the radiation losses into space.
The temperature of the aircraft won't drop below the temperature of
the ambient air, as long as the aircraft is dry.
Actually, it can. I have seen frost on metal surfaces (like wings) when the air
temp is above freezing. Taxiing will sometimes melt frost.
As usual, mxsmanic is both right and wrong (as in 'a little knowledge can be
a dfangerous thing"). When the skin radiates, it cools down, and will cool
the air in contact with its surface. This creates a thin inversion layer,
which (in the absence of any appreciable wind) is stable. The air
temperateure a few millimeters above the skin will be significantly warmer.
A clear night sky is /cold./
-ash
Cthulhu in 2005!
Why wait for nature?
  #32
Old December 9th 06, 09:22 PM posted to rec.aviation.piloting
Mxsmanic
Ash Wyllie writes:
Look up _radiational cooling_.
I'm familiar with it, and with blackbody radiation.
Space is in the single digits absolute, and the atmosphere is pretty
much transparent to radiation.
The atmosphere not only absorbs and reflects the blackbody radiation
emitted by most objects on the ground at ordinary temperatures, it
also emits radiation of its own (as does anything with a non-zero
absolute temperature).
Objects will radiate energy trying to heat up interstellar space,
and cool in the process.
The surface of the planet is not part of interstellar space.
Everything on the surface of the Earth cools through emission of
radiation, but aircraft do not do this to any greater extent than
anything else, and they don't cool to subfreezing temperatures in air
that is above freezing.
  #33
Old December 9th 06, 11:20 PM posted to rec.aviation.piloting
N2310D
"Ash Wyllie" wrote in message
Look up _radiational cooling_ . Space is in the single digits absolute,
and
the atmosphere is pretty much transparent to radiation. Objects will
radiate
energy trying to heat up interstellar space, and cool in the process.
Ash, I'd like to expand a bit on your statements.
In the 3-5 and 8-12 micrometer region of the electromagnetic spectrum,
atmospheric transmission is, like you said, close to 100% transparent. Outer
space, in those bands, is to photons like a Hoover is to dust in the
carpet - it just sucks heat right out.
The rate at which the transfer of photons occurs is dependent on, among
other things, the emmissivity of the surface and the thermal conductivity
from the mass to that surface. The perfect case is a gaussian emmissivity of
one, and since perfection is difficult, the closest you can come is a bunch
of nines behind the decimal point. A pure white specular surface is at the
opposite end of the scale.
One good example to back up your statement is in the winter time. We
have all felt the phenomena when the sky is clear that the nights are much
colder than when the sky is overcast. That is because interstellar space is
sucking the heat off the planet's surface. The adjacent atmosphere loses a
lot of its energy to the surface and its temperature decreases also.
Please, don't confuse the cloud cover effect with the so-called
"greenhouse" effect.
I always used the term "radiative cooling" (not radiational) to keep in
tune with NASA's glossary:
(http://eobglossary.gsfc.nasa.gov/Lib...seg=q&segend=s)
radiative cooling Cooling process of the Earth's surface and adjacent
air, which occurs when infrared (heat) energy radiates from the surface of
the Earth upward through the atmosphere into space. Air near the surface
transfers its thermal energy to the nearby ground through conduction, so
that radiative cooling lowers the temperature of both the surface and the
lowest part of the atmosphere.
Oh, did I mention that I spent the better part of two decades doing infrared
measurements using a Michelson Interferometric Spectrometer? [Don't try
saying that with more than two drinks under your belt.] A lot of that dealt
with radiative transfer.
  #34
Old December 10th 06, 06:42 AM posted to rec.aviation.piloting
Morgans[_2_]
"Ash Wyllie" wrote
Look up _radiational cooling_ . Space is in the single digits absolute, and
the atmosphere is pretty much transparent to radiation. Objects will radiate
You might drop in on some of the amatuer telescope groups. They have the same
problem.
Why on earth are you arguing with this BoZo? He doesn't know **** from shinola,
and has proven it on many occasions and many subjects, yet still he argues with
people that do know, and then tells them that they are not qualified to make
statements on xyz subject.
You only contribute to him overstaying his welcome even longer!
  #35
Old December 10th 06, 11:25 AM posted to rec.aviation.piloting
Ash Wyllie
Morgans opined
radiate energy trying to heat up interstellar space, and cool in the
process.
same problem.
shinola, and has proven it on many occasions and many subjects, yet still he
argues with people that do know, and then tells them that they are not
qualified to make statements on xyz subject.
I've quit doing so here. Mx is impervious to experience, and science.
-ash
Cthulhu in 2005!
  #36
Old December 10th 06, 10:28 PM posted to rec.aviation.piloting
Danny Dot
"Peter R." wrote in message
A question for those of you more adept at chemistry/physics than I: How
fast does the aluminum skin of the standard single engine GA aircraft take
to cool to surrounding air temperatures? For example, how long would it
take for the skin to cool from a heated hangar at 65 degrees F to outside
air at 20 degrees F?
This is my first winter where my airplane sits at my destination airport
(Buffalo, NY) all week in a heated hangar. The problem I just inherited
is that if I desire to depart during a lake effect snowfall event, falling
snow could melt on the wings and fuselage and then turn to ice.
You might be better off to taxi out with 20 degree wings that will not have
the snow melt and attach.
Danny
Peter
  #37
Old December 10th 06, 11:14 PM posted to rec.aviation.piloting
Mxsmanic
Danny Dot writes:
The wings couldn't melt snow _and_ freeze it. They could freeze water
droplets, or melt ice particles, but not both.
  #38
Old December 11th 06, 02:10 AM posted to rec.aviation.piloting
Tony
The snow would most likely melt over the fuel tanks (if it's a wet
skinned tank) then flow aft and freeze again. I don't remember ever
having the problem, but the only time our Mooney saw the inside of a
heated hanger was when it needed to have snow and ice melted from it.
At least once I climbed aboard after it was hanger heat soaked then
took off in fairly light snow (vis at least a half mile.) I wasn't
smart enough to worry about snow melting and refreezing -- my concern
was braking, or lack of it! It couldn't have been too bad though, the
airplane didn't move during run up.
I think even with warm fuel tanks, the convective cooling would pretty
quickly get the wing surfaces cool enough to keep the white stuff
solid.
On Dec 10, 5:28 pm, "Danny Dot" wrote:
"Peter R." wrote in ...
--You might be better off to taxi out with 20 degree wings that will not have
Danny
Peter- Hide quoted text -- Show quoted text -
  #39
Old December 11th 06, 04:14 AM posted to rec.aviation.piloting
Morgans[_2_]
Great! Another one leaves the "Dark Side" of the force! g
You will feel better, if you don't fight with him, I think.
  #40
Old December 11th 06, 07:38 PM posted to rec.aviation.piloting
Chris W
Mxsmanic wrote:
Peter R. writes:
Nor more than a couple of minutes. Aluminum is an excellent conductor
of heat.
How well aluminum conducts heat has nothing to do with it. It is all
matter of thermal mass and surface area to mass ratio. The good heat
conductivity or aluminum means that once the outside of the plane has
cooled off, the inside will cool off fast too.
Chris W
KE5GIX
"Protect your digital freedom and privacy, eliminate DRM,
learn more at http://www.defectivebydesign.org/what_is_drm"
Gift Giving Made Easy
Get the gifts you want &
give the gifts they want
One stop wish list for any gift,
from anywhere, for any occasion!
http://thewishzone.com
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 May 1st 04 07:29 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 April 5th 04 03:04 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 2 February 2nd 04 11:41 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 1 January 2nd 04 09:02 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 October 2nd 03 03:07 AM
