Contact Approach -- WX reporting
Old December 14th 06, 04:25 PM posted to rec.aviation.ifr
Newps
Default Contact Approach -- WX reporting
Dan wrote:
Since a contact approach requires the airport to have an IFR approach,
I fail to see the advantage of a contact approach.
You're being vectored for the ILS and are on a long downwind. You see
the airport due to the fact that only the ASOS is in the clouds, or only
a portion of the airport is in the clouds, the portion with the ASOS.
  #32
Old December 14th 06, 04:30 PM posted to rec.aviation.ifr
Newps
Jim Macklin wrote:
On a contact approach you do not follow anybody, you are the
only airplane and you navigate to the airport directly.
You got one out of three correct here and the navigation part depends on
the clouds.
A visual approach may be instigated by the controller if the
weather is good VFR.
Just VFR is all the controller needs.
At airports without official weather reporting,
the pilot can report to ATC that visibility is such and such
and he can maintain VMC and request a contact approach, the
pilot become the weather observer.
No, must have weather reporting on the ground. From the .65: 7-4-6
b. The reported ground visibility is at least 1 statute mile.
They make no exception for flight viz.
  #33
Old December 14th 06, 04:32 PM posted to rec.aviation.ifr
Newps
karl gruber wrote:
One advantage (without looking at the regs so beat me up) is if you are VFR
and want to make a low weather scud run into an airport where "special VFR"
is NOT available.
Just ask the tower for a "Contact approach" instead.
Well that could get involved. You'll have to request and get an IFR
clearance. You'll then have to climb to the MVA to make that clearance
effective. That may or may not allow you to finish your scud run. I
doubt if it will.
  #34
Old December 14th 06, 04:36 PM posted to rec.aviation.ifr
Newps
Jim Macklin wrote:
Commercial flights are
required to be "on a flight plan" and canceling IFR even for
the last few minutes of a charter flight puts you in
violation.
Rubbish. Many commercial flights go VFR. What matters is how their ops
specs are written. Some allow VFR, some don't.
Flight visibility is solely judged by the pilot on an IFR
approach, once the first step is passed.
And the first step on a contact approach is reported ground viz of a mile.
ATC will clear any
airplane to make any approach the pilot requests.
Uh, maybe. What's the traffic picture? Go into ORD and request a VOR
approach with a procedure turn and see where that gets you.
The pilot
is not supposed to request or begin an approach if the
weather is below visibility minimums. But any pilot, Part
91,121, 125, or 135 is the only person who can judge flight
visibility and that is the controlling visibility on an IFR
approach.
Wrong. 121 and 135 pilots are not allowed to even start the approach
when the reported ground viz is below the airlines minimums. Flight viz
isn't even a question that's asked.
  #36
Old December 14th 06, 04:52 PM posted to rec.aviation.ifr
karl gruber[_1_]
Steven P. McNicoll wrote:
.. I
see no advantage then in picking up an IFR clearance in order to
request a contact approach as the minimums for a contact approach are
the same as VFR in Class G airspace.
I don't think I'd try to get a clearance from Approach Control. I'd deal
diectly with tower. I "think" I've done this...at Portland. It was handled
just like a special VFR, only it was a contact approach. It was on a scud
run down I-5 from Seattle. I know, this is an IFR clearance, but you make it
sound dificult when all it is is a tower call. PDX tower, Piper 7777Z, 5NW,
request contact approach.
Bam!...........in there.
Karl
"Curator"
Karl
"Curator"
  #37
Old December 14th 06, 05:00 PM posted to rec.aviation.ifr
Steven P. McNicoll[_2_]
It's not a tower call, it's up to whatever facility is responsible for
approach control functions.
  #38
Old December 14th 06, 05:02 PM posted to rec.aviation.ifr
Stan Prevost
ps.com...
Surface areas and contact approaches both
require weather observations.
Does that include automated weather observations?
  #39
Old December 14th 06, 05:07 PM posted to rec.aviation.ifr
karl gruber[_1_]
"Newps" wrote in message
doubt if it will.
No. You can just get one from tower, JUST lke special VFR.
Karl
  #40
Old December 14th 06, 05:11 PM posted to rec.aviation.ifr
karl gruber[_1_]
handled
it
5NW,
Nope, it can be a tower call. I've done it.
Karl
"Curator"
VFR position reporting Mxsmanic Piloting 154 November 26th 06 04:45 PM
OLV GPS 36 approach question A Lieberma Instrument Flight Rules 59 August 15th 06 12:32 AM
Trust those Instruments.... Trust those Instruments..... A Lieberman Instrument Flight Rules 1 May 2nd 06 03:54 PM
"Cleared Straight-In Runway X; Report Y Miles Final" Jim Cummiskey Piloting 86 August 16th 04 06:23 PM
