Contact approach question
Old January 18th 05, 03:13 PM
On Tue, 18 Jan 2005 14:53:32 +0000 (UTC),
(Paul Tomblin) wrote:
We were talking about cancelling the IFR clearance and proceeding VFR when
you piped up with this "you've got to fly the instrument procedure"
business. He's not flying a "home-made procedure", he's proceeding VFR.
That's not what I recall.
The original post started thusly:
"On the most recent Pilots Audio Update, the narrator was talking
about atime when fog covered half the airport, but he could see the
runway he wasgoing to land on, but because the control tower was on
the foggy half ofthe airport, they wouldn't approve a visual approach.
He was beingvectored all around, and thought it ironic that he never
lost sight of therunway. Could he had gotten a contact approach if
he'd asked for it?"
In other words, the field is IFR.
Newps then suggested that one could get an instrument approach and
then cut it short and land under IFR..).
I don't see where anyone suggested he land VFR. He can't.
  #33
Old January 18th 05, 09:19 PM
Steven P. McNicoll
I don't see anything there that prohibits you from cancelling IFR when you
have sufficient visibility and cloud clearance to operate under VFR.
Nope. But if you can operate under VFR an instrument letdown wouldn't be
necessary.
  #34
Old January 19th 05, 01:02 AM
Matt Barrow
nk.net...
you
necessary.
Paul stated "canceling when you have sufficient visibility..." which
indicates a change in status/condition/visibility (at the point visibility
becomes adequate). Your reply infers that there was adequate visibility
prior to that.
Matt
Matthew W. Barrow
Site-Fill Homes, LLC.
Montrose, CO
  #35
Old January 19th 05, 01:09 AM
Steven P. McNicoll
"Matt Barrow" wrote in message
becomes adequate).
Paul wasn't following the thread very closely. The message he responded to
stated "when an instrument letdown to a civil airport is necessary". As I
said, if you can operate under VFR an instrument letdown wouldn't be
necessary.
Your reply infers that there was adequate visibility prior to that.
No, you're inferring.
  #36
Old January 19th 05, 01:27 AM
Paul Tomblin
becomes adequate).
necessary.
That was precisely the point I was trying to make, since somebody else
brought up the "when an instrument letdown ... is necessary" as a reason
why one *couldn't* cancel IFR once you were on an approach.
If netcat is compiled with -DGAPING_SECURITY_HOLE, the -e argument
specifies a program to exec after making or receiving a successful
connection. -- netcat README file
  #37
Old January 19th 05, 01:29 AM
Steven P. McNicoll
Well, you failed.
  #38
Matt Barrow
nk.net...
visibility
becomes adequate).
to
necessary.
Let's see: The message he responded to stated "when an instrument letdown to
a civil airport is necessary". Are you saying the gist of the thread was
the opposite of this?
I'm trying to figure out why he's addressing an instrument letdown being
necessary and your addressing visual letdown.
Matt
Matthew W. Barrow
Montrose, CO
  #39
Old January 19th 05, 01:31 AM
Matt Barrow
visibility
becomes adequate).
to
I
necessary.
Seems obvious to me. Why is McNicoll changing the context 180 degrees?
Matt
Matthew W. Barrow
Montrose, CO
  #40
Old January 19th 05, 01:32 AM
Matt Barrow
nk.net...
Well, you failed.
The only failure was your change in context.
Matt
Matthew W. Barrow
Montrose, CO
GPS approach question Matt Whiting Instrument Flight Rules 30 August 29th 08 03:54 AM
GPS approach question Matt Whiting Instrument Flight Rules 8 November 1st 04 10:51 PM
Canadian holding procedures Derrick Early Instrument Flight Rules 24 July 22nd 04 04:03 PM
Established on the approach - Checkride question endre Instrument Flight Rules 59 October 6th 03 04:36 PM
