#31
Mxsmanic wrote:
Sam Spade writes: That won't work with the GNS400/500 series. Direct-To with any type of fix will put a magenta route line on the map (and potentially other instruments that pull information from the GPS). That is not the point. Direct-to on a GNS400/500 will not yield the unpublished extension of the final approach course unless you happen to be in the correct position when you activate direct-to. Sure, you will have a magenta line but it probably won't have a magnetic course of 002, as per the example IAP. |
#32
#33
Roy Smith wrote:
Stan, Just curious why you picked SENNA and not FRZZN as the waypoint. From "Turn left 10 degrees to intercept the final approach course", I'd assume I'd intercept outside of FRZZN, but perhaps not outside of SENNA. I would think -D- FRZZN with a course of 002 would make more sense. It makes more sense to set up the first published fix in this case, where the course remains the same. If the clearance were issued correctly (off route extension of published segment) the clearance would be to cross SENNA, not FRZZN. |
#34
Mark Manes wrote:
Isn't this an RNAV approach? http://www.naco.faa.gov/d-tpp/0612/09092R35.PDF Mark Sure it is. So is this: http://www.naco.faa.gov/d-tpp/0612/00569G12.PDF |
#35
Mxsmanic wrote:
.. Approaches are different, though, since changing them seems to mutate them into regular routes. I don't use approaches and the like too much on the GPS, since it's harder to get it working than to fly it by hand (or by autopilot). You can do changes to the IAP flight plan sequence prior to the FAF and the approach mode will still activate as well as the missed approach. The limiting factor is an unacceptably large angle of intercept to the FAF as established by Garmin. |
#36
![]() "Sam Spade" wrote in message ... That is not the point. Direct-to on a GNS400/500 will not yield the unpublished extension of the final approach course unless you happen to be in the correct position when you activate direct-to. Sure, you will have a magenta line but it probably won't have a magnetic course of 002, as per the example IAP. On the GNS430, Direct-To provides an opportunity to set the course to/from the waypoint. Press Direct To, enter the waypoint, press Enter, move the cursor to the course field, set the course, then press Enter again. |
#37
![]() "Roy Smith" wrote in message ... On the 480, I would hit the VTF soft key (assuming I've already got the approach loaded with some arbitrary IAF selected). At that point, the box would create a segment from [a point 50(*) miles 182 degrees from FRZZN] to FRZZN, make that the active leg (i.e. draw it in magenta on the map), and go into suspend mode. Assuming I was given a good vector, flew it correctly, and had sufficient fuel, I would eventually intercept that segment. At that time the box would automagically come out of suspend mode. When I reached FRZZN, it would sequence to FRZZN-MAP36 being the active leg. (*) I think it's 50 miles. Could be something else, but it's long enough that it's never been an issue for me. Roy, apparently VTF works much differently on the 480 than the 430 and sounds correctly implemented. On the 430, VTF doesn't work properly on a dogleg approach. It sets up for the dogleg intermediate segment rather than the extended final course. Have you checked the 480 for a dogleg, such as http://www.naco.faa.gov/d-tpp/0612/05924VDB.PDF or http://www.naco.faa.gov/d-tpp/0612/06712R23.PDF ? |
#38
Stan Prevost wrote:
"Sam Spade" wrote in message ... That is not the point. Direct-to on a GNS400/500 will not yield the unpublished extension of the final approach course unless you happen to be in the correct position when you activate direct-to. Sure, you will have a magenta line but it probably won't have a magnetic course of 002, as per the example IAP. On the GNS430, Direct-To provides an opportunity to set the course to/from the waypoint. Press Direct To, enter the waypoint, press Enter, move the cursor to the course field, set the course, then press Enter again. I'll take your word for it. That seems more complicated, though, than using OBS mode. |
#39
Stan Prevost wrote:
On the GNS430, Direct-To provides an opportunity to set the course to/from the waypoint. Press Direct To, enter the waypoint, press Enter, move the cursor to the course field, set the course, then press Enter again. I just tried that on the 530 trainer and it works the same way. On relection that might be a better way to go in this hypothetical than using OBS mode. |
#40
Stan Prevost wrote:
Roy, apparently VTF works much differently on the 480 than the 430 and sounds correctly implemented. On the 430, VTF doesn't work properly on a dogleg approach. It sets up for the dogleg intermediate segment rather than the extended final course. Have you checked the 480 for a dogleg, such as It seems to me to work correctly. Using your example of KEKX RNAV 23, if I select VTF, as you say, I get a track line of 270 magnetic to JEXUD. That would be the correct course to intercept for vectors to "final." The issue is FAA terminology that is predicated on the ILS case. |
Contact Approach -- WX reporting | [email protected] | Instrument Flight Rules | 64 | December 22nd 06 01:43 PM |
RNAV Operations in FS2004 | Rookie | Instrument Flight Rules | 2 | November 29th 06 11:51 PM |
RNAV approaches | Kevin Chandler | Instrument Flight Rules | 3 | September 18th 03 06:00 PM |
RNAV approaches | Kevin Chandler | Piloting | 3 | September 18th 03 06:00 PM |
Slam dunk into Janesville | Steven P. McNicoll | Piloting | 0 | July 31st 03 01:08 AM |
