Agreed. Over the airport in a descent, enter left dowwind and land. Eyes
and ears peeled the whole way. Broadcast my intentions in as concise a manner as I can. Or just enter behind the last pilot. Frankly, If I were approaching from the NW and saw someone from the NE do a "cross, fly out, RH 225 to the 45 entry", I would be totally confused and surprised to see that you are landing at the same airport I was aimed at. But my eyes would be on you the whole way. The only thing I wouldn't do is fly a right hand pattern at a LH runway. Otherwise enter whatever leg is shortest or follow the last plane in the pattern. "Newps" wrote in message ... Fly an extra 10 miles? For what purpose? Just enter the left downwind and land. Don't make this more difficult than it has to be. The more time you spend in the terminal area the more risk you have. |
Maule Driver wrote:
Agreed. Over the airport in a descent, enter left dowwind and land. Eyes and ears peeled the whole way. Broadcast my intentions in as concise a manner as I can. Or just enter behind the last pilot. Frankly, If I were approaching from the NW and saw someone from the NE do a "cross, fly out, RH 225 to the 45 entry", I would be totally confused and surprised to see that you are landing at the same airport I was aimed at. But my eyes would be on you the whole way. Well, I've managed to stay out of this thread 'til now, but the pressure is irresistible. I see some merit in the 225 deg turn to the 45 entry. Descending onto the downwind from across the field puts any traffic already on the downwind underneath me and made more difficult to see due to my low wings and the ground-clutter background. As I make a descending left turn, my view of the airplane I am about to cut off is blocked by my rising right wing. On the other hand, with the 225 deg turn to the 45 entry method, I cross the downwind safely above pattern altitude, and in my 225 deg right turn I have a full view of the downwind and my lowered right wing is out of the way. I view the downwind from pattern altitude, so I am looking for traffic against the sky instead of against ground clutter. My own airplane is in a turn for several seconds, presenting a more visible profile and increasing the opportunity for other pilots to see me. |
Enter upwind crosswind on the 45 north of the field, procede with left
turn to downwind for R36. |
I'd enter on crosswind about a mile north of the airport. I'd have a
view of the whole runway. Your scenario would also be a good one, especially if I were trying to sort out traffic. wrote in message ... Consider you're NE of the airfield, non towered airport, runway 18/36, standard left pattern applies, with runway 36 the active. I'm interested in hearing what your personal method of joining the pattern would be, while adhering to the FAR's and AIM. I've two thoughts: Fly south, then west, pass overhead the field, and then 2 or 3 miles later do a descending 225 degree right turn, and join on a 45 degree to downwind, or Stay east and then south of the airport, and join a straight in outside 5 sm. Opinions? Stan |
Depends on what the weather is, and if there is VFR traffic. If it is
IFR conditions and no VFR traffic is observed, then circle anyway as you please, while looking out for traffic. If there are other VFR traffic, I don't like either of your options. Too much maneuvering for the first option, and it is best to avoid straight- ins when there is VFR traffic. I would fly slightly west to intercept the extended downwind and merge with the traffic. Alternatively, you could fly south, pass overhead and turn directly downwind. I wouldn't do the descending 225-degree right. Way too much maneuvering near the traffic pattern. You could do this if you go a few miles out, but you are wasting time and fuel on something that could be accomplished quite easily and safely. wrote in news:cfiqv0hgqs3mic8c9hr1cv87rpeiikqji2@ 4ax.com: Consider you're NE of the airfield, non towered airport, runway 18/36, standard left pattern applies, with runway 36 the active. I'm interested in hearing what your personal method of joining the pattern would be, while adhering to the FAR's and AIM. I've two thoughts: Fly south, then west, pass overhead the field, and then 2 or 3 miles later do a descending 225 degree right turn, and join on a 45 degree to downwind, or Stay east and then south of the airport, and join a straight in outside 5 sm. Opinions? Stan |
![]() "Andrew Sarangan" wrote: Too much maneuvering for the first option, Yup. and it is best to avoid straight- ins when there is VFR traffic. Why? If you're approaching from a direction that is straight in to your runway, what would be safer--flying all over the area to set up for a downwind? -- Dan C172RG at BFM |
"Dan Luke" wrote in
: "Andrew Sarangan" wrote: Too much maneuvering for the first option, Yup. and it is best to avoid straight- ins when there is VFR traffic. Why? If you're approaching from a direction that is straight in to your runway, what would be safer--flying all over the area to set up for a downwind? The final leg is where two airplanes are most likely to come in contact. This is where they are converging towards the runway, and the pilots are least likely to be scanning. This is also when two airplanes will be at different altitudes, making them harder to spot. How many times have you followed a traffic in the pattern and lost visual contact after it turns final? A straight-in is notorious for inaccurate distance estimates. However, I do straight-ins when the situation calls for it. But I've had several close encouters that makes me think twice in such situations. All I am saying is that it warrants extra caution compared to other entries. |
![]() "Andrew Sarangan" wrote in message 1... Depends on what the weather is, and if there is VFR traffic. If it is IFR conditions and no VFR traffic is observed, then circle anyway as you please, while looking out for traffic. Anyway I please? What about FAR 91.126(b)? If there are other VFR traffic, I don't like either of your options. Too much maneuvering for the first option, and it is best to avoid straight- ins when there is VFR traffic. Why is it best to avoid straight-ins when there is VFR traffic? |
... Consider you're NE of the airfield, non towered airport, runway 18/36, standard left pattern applies, with runway 36 the active. I'm interested in hearing what your personal method of joining the pattern would be, while adhering to the FAR's and AIM. I guess you could do an abbreviated version of the overhead join, whereby you descend on the dead side (on the east) and then when you get to circuit height, cross the northern end of the runway, effectively joining the circuit on the crosswind leg. Normally with an overhead join to a left-hand circuit you'd be approaching from the "live" side of the circuit at 2,000 feet or so, but as you're on the dead side already, this doesn't apply. Fly south, then west, pass overhead the field, and then 2 or 3 miles later do a descending 225 degree right turn, and join on a 45 degree to downwind, or Probably not favourable, as you're in the vicinity of traffic in the circuit but as you're in a right turn, you won't have a particularly good view in the direction you're turning (particularly if you have a high-wing aircraft). All you need is for someone to be doing what my instructor used to call "V-bomber circuits" (i.e. not keeping them tight and close in) and you're in a potentially sticky spot. With the crosswind join you're already flying in the direction of the circuit when you start, and the main lookout will be for departing traffic, which until you get to the runway will be forward of your nine o'clock. If you converge onto the downwind from 45 degrees you'll be looking over your left shoulder to try to spot people, which isn't ideal. Stay east and then south of the airport, and join a straight in outside 5 sm. That's probably the nicest way. Actually the absolute nicest way would be to join on a right-hand downwind (we often have both directions working at once at my home field), but in a non-ATC situation you would want to stick with the official way. D. |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 02:26 PM |
joining the traffic pattern quandary | [email protected] | Instrument Flight Rules | 77 | January 17th 05 05:07 PM |
