In real life, do most pilots equipped with autopilots use them to fly
holds (i.e., by using the HDG function of the autopilot, and possibly altitude holds or autothrottle if available), or do they fly the plane by hand through the holds? When you are tested on your ability to fly holds, do you have to fly them by hand, or can you use the autopilot as above? Note that I'm not talking about fully automated systems that will fly the entire hold pattern automatically, I'm talking about just using heading and altitude controls in the autopilot to simplify the task of turning and rolling out, turning and rolling out, over and over. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Mxsmanic wrote:
In real life, do most pilots equipped with autopilots use them to fly holds (i.e., by using the HDG function of the autopilot, and possibly altitude holds or autothrottle if available), or do they fly the plane by hand through the holds? Holds are the perfect time for the autopilot. Usually, I do them in HDG mode, but the GNS480 will steer the autopilot around the hold in GPSS mode (either as a part of a charted approach, or you can just throw a hold in at any waypoint) When you are tested on your ability to fly holds, do you have to fly them by hand, or can you use the autopilot as above? The examiner expects you to use the autopilot when appropriate. Of course, they can (and will) make you hand fly any part of the test that they need to evaluate fully. Note that I'm not talking about fully automated systems that will fly the entire hold pattern automatically, I'm talking about just using heading and altitude controls in the autopilot to simplify the task of turning and rolling out, turning and rolling out, over and over. It's not a feature of the autopilot in my plane. It's the GPS. The autopilot just does what the GPS tells it. |
Ron Natalie writes:
Holds are the perfect time for the autopilot. Usually, I do them in HDG mode, but the GNS480 will steer the autopilot around the hold in GPSS mode (either as a part of a charted approach, or you can just throw a hold in at any waypoint) How do you do it with the GNS480? Is it possible with a GNS530? I've looked in the manual but I don't see anything that explains how to do it. The examiner expects you to use the autopilot when appropriate. Of course, they can (and will) make you hand fly any part of the test that they need to evaluate fully. Hmm, okay. Not that I'll be taking an exam any time soon, but I was curious. It's not a feature of the autopilot in my plane. It's the GPS. The autopilot just does what the GPS tells it. If there's a way to get a GNS430 or GNS530 to do it, I'd like to know how. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Mxsmanic wrote: How do you do it with the GNS480? Is it possible with a GNS530? I've looked in the manual but I don't see anything that explains how to do it. Garmin did not design the GNS480, so none of the Garmin designs incorporate that feature. |
john smith writes:
Garmin did not design the GNS480, so none of the Garmin designs incorporate that feature. And yet they sell it? What's the story behind that? I thought Garmin designed all their stuff (even if they have it manufactured in Taiwan). -- Transpose mxsmanic and gmail to reach me by e-mail. |
"I've read that holds have become very rare since ATC adopted the policy of spacing flights from their departure points rather than en route. " You want to come and visit Heathrow some time - there are four holds, and they get used. |
Mxsmanic wrote:
john smith writes: Garmin did not design the GNS480, so none of the Garmin designs incorporate that feature. And yet they sell it? What's the story behind that? I thought Garmin designed all their stuff (even if they have it manufactured in Taiwan). Garmin bought UPSAT (formerly known as Apollo) after UPSAT designed the 480 (which UPSAT called the CNX80) and the MX20 (which has evolved into the GMX200) and the SL-30 and SL-40 NAV/COM and COM. All of which (with the exception of the original MX20) are still Garmin products. |
Mxsmanic wrote: john smith writes: Garmin did not design the GNS480, so none of the Garmin designs incorporate that feature. And yet they sell it? What's the story behind that? I thought Garmin designed all their stuff (even if they have it manufactured in Taiwan). Garmin bought Apollo Avionics from UPS a few years back. If I remember correctly the 480 was originally an Apollo product. |
Mxsmanic wrote:
Ron Natalie writes: Holds are the perfect time for the autopilot. Usually, I do them in HDG mode, but the GNS480 will steer the autopilot around the hold in GPSS mode (either as a part of a charted approach, or you can just throw a hold in at any waypoint) How do you do it with the GNS480? Is it possible with a GNS530? I've looked in the manual but I don't see anything that explains how to do it. If you are in an approach, it will fly the hold once automatically. If you press SUSP in the hold, it will fly around the hold indefinitely. Otherwise, you can press DIRECT and then HOLD and it prompts you for the course and leg length. I don't know what the traditional Garmin stuff is capable of. |
Mxsmanic wrote: In real life, do most pilots equipped with autopilots use them to fly holds (i.e., by using the HDG function of the autopilot, and possibly altitude holds or autothrottle if available), or do they fly the plane by hand through the holds? Even in the very advanced G1000 aircraft the autopilot doesn't fly the hold. However you can manually set the heading and drive it around the hold. The GNS 480 will drive the hold and is awesome but its just a box, not an integrated system like the G1000. The best thing about any IFR GPS system (430,480,530,G1000) is that it gives you the entry procedure. That's 95% of the complexity of the hold, fingering out the entry. When you are tested on your ability to fly holds, do you have to fly them by hand, or can you use the autopilot as above? Usually when you are being tested on holding you are being tested on two things... 1) Using a correct entry procedure (or at least staying on the safe side) and 2) Timing the hold to arrive back at the holding fix right at the EFC time. A hold can be 4,3 or 2 minutes so you mix them up to make the time come out right. Just the flying around in circles part isn't anything difficult itself. Note that I'm not talking about fully automated systems that will fly the entire hold pattern automatically, I'm talking about just using heading and altitude controls in the autopilot to simplify the task of turning and rolling out, turning and rolling out, over and over. Usually you do use the autopilot, because the hold is usually when you are briefing the approach. Pre-approach is the busiest time because you need to study the approach. In real life holding is about as common as being hit by lightening. Even when you do get a hold its usually just a vectored hold, not a formal procedures. The only time you really get to fly holds is to remote airports without ATC when the approach procedure requires a hold for the procedure turn. -Robert |
| Thread Tools | |
| Display Modes | |
| How much is autopilot on commercial flights today? | Mxsmanic | Piloting | 25 | September 12th 06 07:41 AM |
| KAP140 autopilot and a KLN94 GPS question | STICKMONKE | Instrument Flight Rules | 5 | November 12th 05 05:06 AM |
| mitchell autopilot | dave | Owning | 1 | May 5th 04 07:11 PM |
| Chelton AP-3C autopilot | Kyler Laird | Owning | 0 | April 2nd 04 04:08 PM |
| KAP140 Autopilot Details | News | Instrument Flight Rules | 27 | October 22nd 03 03:01 AM |
