Duncan writes:
![]() ![]() Would he still be in radar contact below 100 feet AGL? -- Transpose mxsmanic and gmail to reach me by e-mail. |
![]() "Mxsmanic" wrote in message ... Duncan writes: ![]() ![]() Would he still be in radar contact below 100 feet AGL? -- Transpose mxsmanic and gmail to reach me by e-mail. If the transponder is on Standby, Primary return would still appear, but information provided by the Mode C Transponder (altitude, squawk code, etc.) would not. Primary return is just the radar signal bouncing off the aircraft, the other information is "broadcast" by the transponder when it is "interrogated" |
Depends on the area. Most areas no, but if the radar facility was
nearby, yes Mxsmanic wrote: Duncan writes: ![]() ![]() Would he still be in radar contact below 100 feet AGL? -- Transpose mxsmanic and gmail to reach me by e-mail. |
![]() "Duncan (NZ)" wrote in message . nz... In article , says... On Wed, 3 Jan 2007 16:08:40 +1300, Duncan (NZ) wrote: In article , says... What regulations determine the absolute lowest altitude you can fly above the ground in the U.S.? I understand that the area just above the ground is usually Class G outside airports, and it only goes up to 700 or 1200 feet most of the time ... which implies that you can actually fly at 500 feet AGL if you want. But is there some other regulation that prohibits aircraft from flying this low, in general or in certain conditions/areas? Well... in New Zealand it's 500' - unless you're in an approved low level (training) area, in which case it's as low a your intructor dares. Over populated areas it's 1,000' All AGL. So the instructor who took me down to 100ft over 70? mile beach, whilst on vacation was just having fun?!!!!! ![]() ![]() My instructor told me I should be careful and never fly low enough to let anyone read the tail number of the plane... -- Lee K. Gleason N5ZMR Control-G Consultants |
On Thu, 4 Jan 2007 22:33:00 -0600, "Lee K. Gleason"
wrote: "Duncan (NZ)" wrote in message .nz... In article , says... On Wed, 3 Jan 2007 16:08:40 +1300, Duncan (NZ) wrote: In article , says... What regulations determine the absolute lowest altitude you can fly above the ground in the U.S.? I understand that the area just above the ground is usually Class G outside airports, and it only goes up to 700 or 1200 feet most of the time ... which implies that you can actually fly at 500 feet AGL if you want. But is there some other regulation that prohibits aircraft from flying this low, in general or in certain conditions/areas? Well... in New Zealand it's 500' - unless you're in an approved low level (training) area, in which case it's as low a your intructor dares. Over populated areas it's 1,000' All AGL. So the instructor who took me down to 100ft over 70? mile beach, whilst on vacation was just having fun?!!!!! ![]() ![]() My instructor told me I should be careful and never fly low enough to let anyone read the tail number of the plane... When thy are this size (check logging trail or corn field) http://www.rogerhalstead.com/833R/833R_frame.htm ground reference maneuvers would be difficult. :-)) But in that light, a few years back we had some neighbors to the south (the typical new subdivision with expensive homes that thought the airport was too noisy and should be closed so they could sleep better/later) At any rate I'd not had the Deb for more than a couple of months. It had a 2-blade prop. If you've ever heard a Bonanza with a 2-blade prop take off you know they are loud. If you've not hear one...The prop tips go supersonic at take off RPM and they are LOUD. It was a hot day with a gusty wind pretty much out of the south so we all had to use the short runway which meant I could count the boards in their picnic tables. I have no doubt that the dishes rattled in their cupboards and they had to stop talking as a number of us went over. Of course if they hadn't made such a stink about lenthening 18/36 it would have been 4000 feet and most of us would have been at pattern altitude over their homes instead of a couple hundred feet. As I said, the airport was busy and most were either high performance singles or twins. I only made three trips that day. None were circuits, or pattern work. However the one irate home owner wrote down my N# and complained. The airport manager said "this guy says you went over his house every five minutes all afternoon and he knows it was you because he wrote down the N number. I explained I'd made three trips and even doing circuits I'd not be able to do one every five minutes. In a way it was good he blamed me with the impossible because the complaint was filed with the notation, Not possible. Every plane sounded the same to him and he saw my N# so I got credit for all. Had he been a bit more observant and accurate they might have listened to him about the noise, but at that point the city saw him more as a troublemaker. BTW I now have a 3-blad prop on the Deb. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
![]() Duncan (NZ) wrote: In article , says... What regulations determine the absolute lowest altitude you can fly above the ground in the U.S.? I understand that the area just above the ground is usually Class G outside airports, and it only goes up to 700 or 1200 feet most of the time ... which implies that you can actually fly at 500 feet AGL if you want. But is there some other regulation that prohibits aircraft from flying this low, in general or in certain conditions/areas? Well... in New Zealand it's 500' - unless you're in an approved low level (training) area, in which case it's as low a your intructor dares. Over populated areas it's 1,000' All AGL. Yup. Microlites are frowned upon flying over cities in NZ You -can- go lower to keep the cloud seperation numbers the way CAA like them AFAIR |
Mxsmanic wrote:
What regulations determine the absolute lowest altitude you can fly above the ground in the U.S.? The ground level. |
golf clap
Ron Natalie wrote: Mxsmanic wrote: What regulations determine the absolute lowest altitude you can fly above the ground in the U.S.? The ground level. |
Ron,
The ground level. Ground level is a regulation? gd&r -- Thomas Borchert (EDDH) |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 02:26 PM |
why is intercept altitude labeled "LOC only"? | Gary Drescher | Instrument Flight Rules | 32 | September 23rd 06 09:00 PM |
The Deaf vs. The Colorblind | Bret Ludwig | Piloting | 17 | August 21st 06 02:08 AM |
Report Leaving Assigned Altitude? | John Clonts | Instrument Flight Rules | 81 | March 20th 04 02:34 PM |
GPS Altitude with WAAS | Phil Verghese | Instrument Flight Rules | 42 | October 5th 03 12:39 AM |
