Implications of.....keeping the speed up
Old January 9th 07, 12:47 AM posted to rec.aviation.ifr
Sam Spade
Default Implications of.....keeping the speed up
Robert M. Gary wrote:
Sam Spade wrote:
Secondly, is there some atc requirement that if your destination is
the primary airport in a class B, then atc is required to keep you in
class B, and not vector you below?
That is policy to the extent it can be done without creating some other
traffic problem. But, there is no "rule."
Althought ATC can authorized it, there is a rule.
91.131
(2) Unless otherwise authorized by ATC, each person operating a large
turbine engine-powered airplane to or from a primary airport for which
a Class B airspace area is designated must operate at or above the
designated floors of the Class B airspace area while within the lateral
limits of that area.
Why do I get the feeling that none of you guys have ever flown anything
that does 250 knots?
-Robert, CFII
And, doesn't it say "unless otherwise authorized by ATC?" The pilot of
a large turbine-powered airplane cannot drop below the floor unless ATC
sends them there.
I don't know where you get your feeling. I suspect I have a lot more
air carrier large jet time that you do, and let me assure you no one in
the airline business refers to a Class B (TCA for many years) chart
since no airline pilot in his/her right mind ever cancels arriving at a
Class B airport.
ATC takes aircraft out the sides of Class B, and sometime returns them
below the floor of an outer area.
I did my fair share of ferrying aircraft from KONT to LAX and the
clearance was always at 4,000, handed off to LAX Approach Control
(pre-SoCal) days well below the floor of Class B. On that one most of
us were smart enough to stay at 200 knots; if not assigned something
less before the handoff.
  #32
Old January 10th 07, 03:39 AM posted to rec.aviation.ifr
Robert M. Gary
sends them there.
Your browser appears to be truncating previous posts so I'll repost the
statement I made in the posting you are referring to...
"Althought ATC can authorized it, there is a rule."
-Robert
  #33
Old January 10th 07, 11:25 AM posted to rec.aviation.ifr
Sam Spade
sends them there.
-Robert
But, that is not a rule that requires ATC to keep you in Class B. It is
just the opposite.
The OP wanted to know whether ATC would assure containment within Class
B. It was my choice of words to say there is no rule that requires to
to that, but it is FAA policy to the extent practical.
The regulation you cited is their authority to deviate from that policy.
  #34
Old January 12th 07, 07:32 PM posted to rec.aviation.ifr
Jack Cunniff[_1_]
Mxsmanic writes:
G. Sylvester writes:
First off, I'm a (very) light a/c IFR pilot. But having listened to
Channel 9 on UA for 135000 miles this past year ...
Is that like spending hundreds of hours with a simulator?
No, it takes hundreds of hours flying an actual plane to get to be an IFR
pilot. Having simulator experience helps a person understand the
environment, but it's not the same as having actually had a scary learning
experience in real life. Guaranteed that THOSE are the lessons you learn
from.
-Jack
  #35
Old January 13th 07, 04:51 PM posted to rec.aviation.ifr
Sam Spade
from.
-Jack
Where did you get that idea?
  #36
Old January 13th 07, 11:02 PM posted to rec.aviation.ifr
Roger[_4_]
On Sat, 13 Jan 2007 08:51:03 -0800, Sam Spade
from.
-Jack
Sounds like the voice of experience to me:-))
Been there and done that.
www.rogerhalstead.com
  #37
Old January 14th 07, 12:49 AM posted to rec.aviation.ifr
Sam Spade
from.
-Jack
What is the regulation that requires "hundreds of hours flying" to
obtain an instrument rating?
  #38
Old January 14th 07, 02:25 AM posted to rec.aviation.ifr
Ed Mulroy
What is the regulation that requires "hundreds of hours flying" to obtain
at least 250 hours
Federal Air Regulation 61.129 a (single engine) and b (multi engine)
http://tinyurl.com/yk44ov
or, in its long form
http://ecfr.gpoaccess.gov/cgi/t/text.... 1.1.2.6.1.2
  #39
Old January 14th 07, 02:54 AM posted to rec.aviation.ifr
Matt Whiting
at least 250 hours
That is the section for a commercial certificate. The instrument rating
requirements are in 61.65. So where is the requirement for "hundreds of
flying hours" to obtain an instrument rating?
Matt
  #40
Old January 14th 07, 03:26 AM posted to rec.aviation.ifr
Jay Somerset
On Sat, 13 Jan 2007 21:25:46 -0500, "Ed Mulroy"
at least 250 hours
You seem to be confusing the Instrument requirement with the Commercial
requirement. The IR does not need the 250 hours required for the Commercial
(at least in the U.S.)
You might want to go back and read the proper section. :-)
-Jay-
Propeller thrust question xerj Piloting 11 November 25th 05 03:12 AM
Crosswind Landings... But airspeed? Jmarc99 Soaring 21 October 4th 05 07:54 PM
speed record set by scramjet - fair? Don French Piloting 55 November 28th 04 01:57 PM
Overweight takeoff / flight Koopas Ly Piloting 50 December 3rd 03 11:53 PM
