When I change the prop setting on my (simulated) Baron 58, lowering
	the prop RPM, my airspeed drops. I thought that for a given throttle setting, the actual thrust produced by the powerplant was supposed to remain the same for a wide range of prop settings, because of automatic pitch changes made when I change the prop RPM. However, that doesn't seem to be the case. A lowering of the prop RPM also lowers airspeed, which implies a change in thrust. The fuel flow also diminishes, which implies a change in power (?). So, exactly what do I gain or lose by adjusting prop RPM when I'm cruising along? Why would I want to change it? Some sources I've read say that the prop makes less noise, which is surely true, but it seems that I can't lower the RPM without losing airspeed (and thus I must be losing power, right?). -- Transpose mxsmanic and gmail to reach me by e-mail.  |
| Thread Tools | |
| Display Modes | |
| Why does a prop ice up so apparently readily? | Mike Rapoport | Instrument Flight Rules | 2 | November 8th 05 03:52 PM |
| Ivo Prop on O-320 | Dave S | Home Built | 14 | October 15th 04 04:04 AM |
| Prop Pitch Question | Eugene Wendland | Home Built | 2 | April 25th 04 04:22 AM |
| PC flight simulators | Bjørnar Bolsøy | Military Aviation | 178 | December 14th 03 01:14 PM |
| USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 04:17 PM |
