#31
Responding to comments about the usefulness/uselessness of calling "Clear
prop," before cranking, Barney Rubble wrote Quite often on the ramp at my home field a nearby pilot will call "All clear" in response to my "clear", as he can see the area directly in front of and underneath the nose. ... I would have appreciated a negative response the three of four times I've overlooked nose wheel chocks and had to shut down to remove them. I know someone saw me do this at least once. |
#32
Barney Rubble wrote:
Oh and take the headset off or uncover one ear, just in case someone is shouting something at you (like don't start, there's a kid playing with the prop). I don't even put the headset on until after start. I figure my ears can take a few seconds of engine noise, and it lets me hear things I might need to hear - like different engine sounds, or somebody shouting something at me before I start. .... Alan -- Alan Gerber PP-ASEL gerber AT panix DOT com |
#33
![]() "Andrey Serbinenko" wrote in message ... Everybody's using checklists. .....snip.... http://www.dauntless-soft.com/PRODUC...HandlingNotes/ Just about every GA checklist you might want and all free. HTH, Kevin ============================= |
#34
Great Thread Guys-
"CLEAR the PROP" is a call I've had drilled into me from my first flight... its one of those things that, ok, maybe its not the 'coolest' thing in the world (in the James Bond sense of the word), and although its probably completely and obviously worthless 99% of the time (I've gotten odd looks from Pax calling clear out the window at 9:00pm on a completely deserted tarmac before)... I figure if only once in my entire pilot life my 'clear prop' habit comes in useful (either convenience or safety)... anyone, then its worth the extra few seconds during each startup. As for Checklists... Frankly, I've fallen for the "flow-check" mentality. I think a huge part of this for me is the fact that I own (and exclusively fly) my ship... so I know her inside out. I take great pains to do everything identically each flight... I still use checklists for engine start, and I have them on the yoke for emergencies, but for general flying (more explicitly, for engine start, pre-takeoff, post-takeoff, cruise, pre-landing and post-landing (cleanup), I have a VERY explicit litteral "flow" that I run my eyes across the panel and check everything in my path. My Pre flight check - this is entirely from memory, visualizing my approach and walk around the plane. PA-28-140 In the cockpit: Key - above Panel. Pilot Window - Open Control Lock - Release Master Switch - On Pitot Heat - On Nav Lights - On Landing Light - On Beacon - On Flaps - Down Fuel - note gauges Sump strainer and Oil Towel - Grab Walkaround (Start from door): Beacon - Check Tail Nav Light - Check Right Wing Nav light - Check (swing wide in front of aircraft) Landing Light - Check "Macro Fuselage Check" (is there any obvious asymmetry?) Left Wing Light - Check Pitot Heat - check (at this point, the Pitot-Static Fin should be lukewarm to the touch) Stall Warning - Check (Stall light should illuminate on panel when switch flipped) Walk to pilot Window, reach arm in Cockpit: All switches off (starting inside and working out, so master switch is last) Back to Preflight: Left Wheel Chalk Left Wheel Brake Pad/Rotor Left Wheel hoses Left Wing Tiedown Left Fuel Vent Left Fuel Sump check Left Fuel Tank - Visual open and inspect... consistent with gauge reading? Left Wingtip - Undamaged Left wing skin (put eye at an oblique angle to the wing and move my head 360 degrees around the airfoil) Left Airleron counterweight - Present and firm Left Airleron Travel - free and correct ( Does the yoke move correctly? any binding?) Left Airleron Hinge outer - pin present Left Airleron Hinge inner - pin present Left Airleron Control Linkage - Firm, pin present Left Flap Hinge All Bolts Present Left Flap, pressure test, outer. middle, inner(firm push downward on flap, noting any looseness) left flap, control linkage, firm and pinned 3 antenna present Anti-Servo Hinges, 1,2,3,4, pins present Stabilator/ anti-servo tab Travel, free and correct (stand on right side of stabalator, view yoke through open door) Rudder - High Hinge - Present Rudder - Gap and hinge look nominal Fuselage skin - Check (again, oblique angle, 360 degrees around the entire fuselage noting any inconsistancies) Stabilator rigging/anti-servo - Everything connected, nothing binding Transponder Antenna Fin - Present Rear Tiedown - untied Right Flap, control Linkage firm and pinned Right Flap, Pressure Test, inner, middle, outer Right Flap Hinge - All Bolts Present Right Airleron Control Linkage - Firm and Pin Present Right Airleron Hinges, inner, outer - pin present Right Airleron Counterweight - present and secure Right Airleron motion, free and correct Right Wing Skin - unblemished Right Fuel Tank Level - Consistent with panel reading Right wheel chalk/tiedown removed Right wheel brake/pads Right wheel linkages Right Tank Vent Right Tank Sump. Open Right Cowling Oil Level Vacuum pump - inspect Steering Linkages - inspect Exhaust - Grab and yank Fore-Cowling clear (no birdies) Cowing Baffle - correct shape, condition Close right cowling making sure Baffling is laying correctly. Check cowling latches, rear - fore. Prop Spinner Alternator Belt Nose - No birdies Intake Front Strut - grab prop and compress Front gear Open Left Cowling Brake Fluid Level Check General Engine Condition CHT/EGT Sensors Left Baffling Close Left Cowling (Assuring correct Baffling position) Nose Fuel Sump. Verbally Declare "I declare this aircraft is Airworthy and ready to fly" (This is a tremendously important to me personally, if admittedly somewhat pointlessly symbolic) - The whole idea behind all of this is that each action flows into the action before and the action after it, and that they're associated with eachother so that I don't forget anything... I know it would give me fits flying any aircraft other than my own particular bird... but hey, I down own my own plane to go flying other aircraft, you know? (and I'm not rich enough to upgrade any time soon ![]() Anyways - For what its worth, of course. -Scott On Jan 20, 12:12 am, "KevinBlack" wrote: "Andrey Serbinenko" wrote in et... Everybody's using checklists.....snip.... http://www.dauntless-soft.com/PRODUC...HandlingNotes/ Just about every GA checklist you might want and all free. HTH, Kevin ============================= |
#35
On the ground, if you let the pitot heat run very long, the
probe will over heat [I've seen a lot that looked like a motorcycle exhaust (blue)] and if you touch it you'll raise blisters. Turn it on and check the ammeter or voltmeter for a drop, after a few seconds ON, turn the pitot heat OFF before you leave the cabin to begin the walk around. It will be warm then. If you want to see a real mess, turn it on with the pitot cover in place, if it is a plastic cover, it will melt. "EridanMan" wrote in message ups.com... | Great Thread Guys- | | "CLEAR the PROP" is a call I've had drilled into me from my first | flight... its one of those things that, ok, maybe its not the 'coolest' | thing in the world (in the James Bond sense of the word), and although | its probably completely and obviously worthless 99% of the time (I've | gotten odd looks from Pax calling clear out the window at 9:00pm on a | completely deserted tarmac before)... I figure if only once in my | entire pilot life my 'clear prop' habit comes in useful (either | convenience or safety)... anyone, then its worth the extra few seconds | during each startup. | | As for Checklists... | | Frankly, I've fallen for the "flow-check" mentality. I think a huge | part of this for me is the fact that I own (and exclusively fly) my | ship... so I know her inside out. I take great pains to do everything | identically each flight... I still use checklists for engine start, | and I have them on the yoke for emergencies, but for general flying | (more explicitly, for engine start, pre-takeoff, post-takeoff, cruise, | pre-landing and post-landing (cleanup), I have a VERY explicit litteral | "flow" that I run my eyes across the panel and check everything in my | path. | | My Pre flight check - this is entirely from memory, visualizing my | approach and walk around the plane. | | PA-28-140 | | In the cockpit: | | Key - above Panel. | Pilot Window - Open | Control Lock - Release | Master Switch - On | Pitot Heat - On | Nav Lights - On | Landing Light - On | Beacon - On | Flaps - Down | Fuel - note gauges | Sump strainer and Oil Towel - Grab | | Walkaround (Start from door): | | Beacon - Check | Tail Nav Light - Check | Right Wing Nav light - Check | (swing wide in front of aircraft) | Landing Light - Check | "Macro Fuselage Check" (is there any obvious asymmetry?) | Left Wing Light - Check | Pitot Heat - check (at this point, the Pitot-Static Fin should be | lukewarm to the touch) | Stall Warning - Check (Stall light should illuminate on panel when | switch flipped) | | Walk to pilot Window, reach arm in Cockpit: | All switches off (starting inside and working out, so master switch is | last) | | Back to Preflight: | Left Wheel Chalk | Left Wheel Brake Pad/Rotor | Left Wheel hoses | Left Wing Tiedown | Left Fuel Vent | Left Fuel Sump check | Left Fuel Tank - Visual open and inspect... consistent with gauge | reading? | Left Wingtip - Undamaged | Left wing skin (put eye at an oblique angle to the wing and move my | head 360 degrees around the airfoil) | Left Airleron counterweight - Present and firm | Left Airleron Travel - free and correct ( Does the yoke move correctly? | any binding?) | Left Airleron Hinge outer - pin present | Left Airleron Hinge inner - pin present | Left Airleron Control Linkage - Firm, pin present | Left Flap Hinge All Bolts Present | Left Flap, pressure test, outer. middle, inner(firm push downward on | flap, noting any looseness) | left flap, control linkage, firm and pinned | 3 antenna present | Anti-Servo Hinges, 1,2,3,4, pins present | Stabilator/ anti-servo tab Travel, free and correct (stand on right | side of stabalator, view yoke through open door) | Rudder - High Hinge - Present | Rudder - Gap and hinge look nominal | Fuselage skin - Check (again, oblique angle, 360 degrees around the | entire fuselage noting any inconsistancies) | Stabilator rigging/anti-servo - Everything connected, nothing binding | Transponder Antenna Fin - Present | Rear Tiedown - untied | Right Flap, control Linkage firm and pinned | Right Flap, Pressure Test, inner, middle, outer | Right Flap Hinge - All Bolts Present | Right Airleron Control Linkage - Firm and Pin Present | Right Airleron Hinges, inner, outer - pin present | Right Airleron Counterweight - present and secure | Right Airleron motion, free and correct | Right Wing Skin - unblemished | Right Fuel Tank Level - Consistent with panel reading | Right wheel chalk/tiedown removed | Right wheel brake/pads | Right wheel linkages | Right Tank Vent | Right Tank Sump. | Open Right Cowling | Oil Level | Vacuum pump - inspect | Steering Linkages - inspect | Exhaust - Grab and yank | Fore-Cowling clear (no birdies) | Cowing Baffle - correct shape, condition | Close right cowling making sure Baffling is laying correctly. | Check cowling latches, rear - fore. | Prop | Spinner | Alternator Belt | Nose - No birdies | Intake | Front Strut - grab prop and compress | Front gear | Open Left Cowling | Brake Fluid Level | Check General Engine Condition | CHT/EGT Sensors | Left Baffling | Close Left Cowling (Assuring correct Baffling position) | Nose Fuel Sump. | Verbally Declare "I declare this aircraft is Airworthy and ready to | fly" (This is a tremendously important to me personally, if admittedly | somewhat pointlessly symbolic) | | - | | The whole idea behind all of this is that each action flows into the | action before and the action after it, and that they're associated with | eachother so that I don't forget anything... | | I know it would give me fits flying any aircraft other than my own | particular bird... but hey, I down own my own plane to go flying other | aircraft, you know? (and I'm not rich enough to upgrade any time soon ![]() | | Anyways - For what its worth, of course. | -Scott | On Jan 20, 12:12 am, "KevinBlack" wrote: | "Andrey Serbinenko" wrote in et... | | | | Everybody's using checklists.....snip.... | | http://www.dauntless-soft.com/PRODUC...HandlingNotes/ | | Just about every GA checklist you might want and all free. | | HTH, | Kevin | | ============================= | |
#36
On 20 Jan 2007 01:33:16 -0800, "EridanMan"
wrote in . com: As for Checklists... Frankly, I've fallen for the "flow-check" mentality. I think a huge part of this for me is the fact that I own (and exclusively fly) my ship... so I know her inside out. A (good) checklist is an integrated whole, a system that comprises more than the sum of its parts. For instance, I start on the less-full tank, then at run-up there's an item to switch to the fullest tank. This verifies fuel flow from two tanks. A flow-check won't guarantee that sort of thing. |
#37
ups.com... Great Thread Guys- "CLEAR the PROP" is a call I've had drilled into me from my first flight... its one of those things that, ok, maybe its not the 'coolest' thing in the world (in the James Bond sense of the word), and although its probably completely and obviously worthless 99% of the time (I've gotten odd looks from Pax calling clear out the window at 9:00pm on a completely deserted tarmac before)... I figure if only once in my entire pilot life my 'clear prop' habit comes in useful (either convenience or safety)... anyone, then its worth the extra few seconds during each startup. I always yell it out. It was part of my training on a busy, instructional ramp. People (including new students) walking between the planes to get to the next row, etc. It seemed completely necessary and became very natural. Then, with seaplane training - same thing. Starting up close to a dock or shore. You never know when someone (especially kids) will run out to watch. And, in my case with the engine behind me, there is always that chance that I might have drifted back into something. Yelling it out and waiting a few seconds gives someone a chance to get out of the way or to call out a conflict. I was once flying a rented 150 at a small, country airport in Minnesota. I yelled "Clear Prop" and clearly heard a couple of weathered pilots standing nearby - "You don't hear that too often." I'm not exactly sure what their point was. I don't know if they were making fun of me for bothering or praising me for doing what has become unusual. Either way, after thinking it through, I am more convinced than ever that it can't hurt and, for the uninitiated passengers, adds a little sense of bravado. As in throwing the white silk scarf over the shoulder, lowering the goggles, "Contact" sort of way. Safety first. Fly safe. -- ------------------------------- Travis Lake N3094P PWK |
#38
yelled "Clear Prop" and clearly heard a couple of weathered pilots standing nearby - "You don't hear that too often." I'm not exactly sure what their point was. I don't know if they were making fun of me for bothering or praising me for doing what has become unusual. I don't know any single engine pilots who don't yell "Clear!" before starting. WRT checklists, Mary and I have very different techniques. I use the "flow-check" method, which means I do everything in a very specific order, geographically, each and every time. Because we fly the same plane all the time, it has become ingrained, and I can do it in my sleep. Mary, on the other hand, uses a laminated checklist, and methodically goes down the list. We tend to cross-check each other, and -- although it's exceedingly rare -- we *do* find the other person forgetting something once in a while. One thing I've noticed with a written checklist is that it's easy to run your finger down it, say it out loud -- and NOT SEE IT. I don't know why that is, but I find that I'm more likely to actually LOOK AT what I'm checking if I use my mental flow-chart. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
#39
Jay Honeck wrote
WRT checklists, Mary and I have very different techniques. I use the "flow-check" method, which means I do everything in a very specific order, geographically, each and every time. Mary, on the other hand, uses a laminated checklist, and methodically goes down the list. The airline "system" is to use the "flow" as a "do-list" and follow-up with the written checklist as a real "checklist", not as a "do-list". Bob Moore |
#40
"flow-check" method, which means I do everything in a very specific order, geographically, each and every time. Mary, on the other hand, uses a laminated checklist, and methodically goes down the list. The airline "system" is to use the "flow" as a "do-list" and follow-up with the written checklist as a real "checklist", not as a "do-list". Cool! Nice to know we've got the best of both worlds, so long as we fly together... However, it is possible for BOTH of us to miss stuff, amazingly. On our last flight we were ten minutes out when Mary noticed that the left tip tank was reading low, apparently down about 5 gallons. For a few minutes we were left wondering if the quick drain was leaking, since she had visually looked in the tank and prounounced it full. Then we thought maybe the gauge was bad, when we couldn't see any gas streaming out behind the wing. Finally I remembered refueling from the New Grape (see it he http://www.alexisparkinn.com/new_mighty_grape.htm ) a few days earlier. At that time I had asked Mary to check the tip, to see if it needed any gas, and she had responded that it was full -- so I never topped it off. Because of the dihedral of our wing, the tip tanks can look close to full and actually be down about 5 gallons. She had simply misinterpreted the visual inspection twice. The fact that we BOTH missed the lower-than-normal gauge during preflight (although technically Mary was PIC, so my checks were only acting as back-up) illustrates how this sort of thing *is* possible, even with two sets of eyes. Luckily, "only" having 79 gallons of gas on board isn't much of an emergency... ;-) -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Checkride Checklist Question | Gary G | Piloting | 78 | August 31st 05 11:53 PM |
Pointer please; test checklist | Michael Horowitz | Owning | 1 | February 19th 05 04:22 PM |
747-100 Checklist | Bartscher | General Aviation | 0 | December 18th 04 07:20 PM |
IFR Checkride Checklist | BTIZ | Instrument Flight Rules | 0 | April 18th 04 12:06 AM |
Checklist binder? | dougdrivr | Restoration | 0 | November 5th 03 03:55 PM |
