I was wondering what people view as their limitations in terms of wind.
I'm talking 172 / Warrior territory here. Clearly this is a personal decision, based on your perceptions of your own skills, the aircraft you are flying, the specific conditions on the day (E.g. how gusty, reports of LLWS & turbulence), your risk tolerance, etc. But I'm interested in what the various opinions are. How much wind is too much to fly, for you? And how much crosswind component? Does your max crosswind component vary with windspeed? And how about how gusty it is? Clearly if it's more gusty that's a bad thing, but how gusty is too gusty? Of course I have my own views on this but I'm wondering what others think. And by the way the context is that I have decided to cancel my flight tomorrow (Boston area) due to winds, but I'm still hoping to fly on Sunday. I guess as an aside, what are the scariest windy conditions you've ever flown in? Would you do it again? Thanks Tom |
Stealth Pilot wrote:
if you cant fly with the windsock horizontal you'd better not try flying crosscountry because one day you will find it horizontal and at the end of a long flight you might not have enough fuel to go anywhere else. Well stated. We had a case here where someone (a fairly new pilot) and his wife flew on a multi-day XC and ended up breaking the landing gear (fixed gear) on his plane when trying to land in a windy cross wind at an airport far from home. Fortunately no injuries, but the landing should have been otherwise routine. |
you should be able to fly in conditions where the windsock is horizontal from any direction. (obviously you change runway ends when it is from behind) the scariest ????? (scariest isnt the right word here, you shouldnt ever be scared because you have been trained) the most demanding conditions are turbulence and gusting winds. the winds dont go away just because you arent up to speed with the demands so you should read up on the correct technique and then practise in increasingly more difficult conditions. I would like to point out that being trained doesn't mean that you're safe handling the aircraft. It means you're aware of the hazards and you know your limits. Being scared is a sign that you ought to land somewhere else. That said, I agree with your assessment that winds can surprise you. It is good to practice with an instructor on a windy winter day. I've landed without incident in 25G40 conditions with the runway about 30 to 40 degrees off of the wind direction. The only surprise was after slowing to about 15 MPH, my aircraft weathervaned toward the right. There was a high speed taxiway right there in front of me. Instead of braking, I kept going and stopped on the taxiway. Once I came to a stop, my airspeed indicator was still reading about 35 MPH from the gust (I was now facing straight in to the wind). My personal rule of thumb in the Baltimore area is that if the winds are blowing 30 knots or greater at 3000 over EMI, I will evaluate my options very carefully. Above 35 knots I will usually stay put. My reasoning is that turbulence and LLWS are likely to get pretty dicey when the winds blow that hard. Bottom line: A good pilot uses experience to know when to stay on the ground and training to deal with the unexpected. I have experience in turbulence, LLWS, and gusty winds, but I won't launch in to it deliberately. That's one of the nice things about flying for fun. If it doesn't look like fun, don't do it. Jake Brodsky |
On Sat, 20 Jan 2007 10:31:32 -0500, Jake Brodsky
wrote: Bottom line: A good pilot uses experience to know when to stay on the ground and training to deal with the unexpected. I have experience in turbulence, LLWS, and gusty winds, but I won't launch in to it deliberately. That's one of the nice things about flying for fun. If it doesn't look like fun, don't do it. Jake Brodsky that is it in a nutshell. one should always use the superior management skills to ensure that the superior flying skills are not called for. :-) in you example that I snipped you demonstrated a very good flying skill. you kept thinking and flying right to the end and took advantage of every opportunity that presented itself. that will turn dangerous situations into stories on usnet :-) if the weather is bad, the winds deplorable, or the forecast involved and difficult my sincere advise is to find the window seat of the closest airport bar and study the weather over a beer. it all becomes much more obvious over a beer! (for the humour impaired I will explain. if it is marginal dont go. the last beer you drink will see you avoiding the weather for another 8 hours :-) ) Stealth Pilot |
![]() "Stealth Pilot" wrote in message ... On Sat, 20 Jan 2007 10:31:32 -0500, Jake Brodsky wrote: snip (for the humour impaired I will explain. if it is marginal dont go. the last beer you drink will see you avoiding the weather for another 8 hours :-) ) Or to put it another way, "I would rather be down here wishing I was up there than up there wishing I was down here!! Danny Deger |
... you should be able to fly in conditions where the windsock is horizontal from any direction. I can't say I agree with this. I think it's worth pointing out that a windsock is horizontal at 150 kts, just the same as it is at 15 kts. We had conditions here a couple weeks ago (Rocky Mountain foothills)where the windspeed at field elevation was gusting to 80 and 90 miles and hour. do you know how to guess at the wind speed from the windsock angle? its a useful skill. Yes, up to the point the windsock is horizontal, after which you need a better tool. I don't see that anyone has mentioned the demonstrated crosswind component, which is in the P.O.H. for certified aircraft. You may do better, but that's the best number the manufacturer achieved with a new aircraft and a very good pilot. If the calculated crosswind based on the wind speed, direction, and available runway exceeds the DCC for your aircraft, it's cause for at least caution if not an outright scrub of the flight. If you're landing at an airport with an overly strong crosswind, and fuel or other concerns don't allow finding another airport with a more favorable runway, lack of control authority may make landing on and maintaining the runway extremely difficult if not impossible. |
In article bSwsh.172849$YV4.24801@edtnps89,
"WestCDA" wrote: "Stealth Pilot" wrote in message ... you should be able to fly in conditions where the windsock is horizontal from any direction. I can't say I agree with this. I think it's worth pointing out that a windsock is horizontal at 150 kts, just the same as it is at 15 kts. At 15 kts, the sock is horizontal. At 150 kts, the pole it's mounted on is horizontal. |
WestCDA wrote
I don't see that anyone has mentioned the demonstrated crosswind component, which is in the P.O.H. for certified aircraft. You may do better, but that's the best number the manufacturer achieved with a new aircraft and a very good pilot. I would suggest that it might be the highest number that the lawyers would permit to be included in the flight manual. Bob Moore |
Air Force Aerial Refueling Methods: Flying Boom versus Hose-and-Drogue | Mike | Naval Aviation | 26 | July 11th 06 11:38 PM |
NTSB: USAF included? | Larry Dighera | Piloting | 10 | September 11th 05 10:33 AM |
Nearly had my life terminated today | Michelle P | Piloting | 11 | September 3rd 05 02:37 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 4 | August 7th 03 05:12 AM |
Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 04:50 PM |
