I'm still in a bit of a quandry as to how to learn to make coordinated turns
in a PC simulator that does not include a motion platform. I've turned on the visual alignment indicator that MSFS provides, which is a red "V" that sits squarely ahead in the visual field, effectively bolted to the airframe. I've been trying to turn such that this V always moves along the horizon at a constant speed for a given bank angle. Logically, a specific bank angle in a coordinated turn will always produce a heading change at the same speed. If the speed at which the horizon is moving varies, the turn is not coordinated. Also, it seems that in a coordinated, level turn, this V should stay at the same distance above the horizon throughout the turn. As I roll into a turn, the speed of movement of the V along the horizon should increase in precise relationship to the bank angle. The opposite should occur as I roll out of the turn, with the speed along the horizon slowing as I return to level flight. Any problems with this? The only remaining problem is to figure out _how_ fast the V should be moving for a given bank angle. Maybe that can come with practice. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Mxsmanic wrote in
: I'm still in a bit of a quandry as to how to learn to make coordinated turns in a PC simulator that does not include a motion platform. Please don't reply to this troll.... If your desire is so bad to reply, set the followups to the sim groups! Thanks! Allen |
Mxsmanic wrote:
I'm still in a bit of a quandry as to how to learn to make coordinated turns in a PC simulator that does not include a motion platform. I've turned on the visual alignment indicator that MSFS provides, which is a red "V" that sits squarely ahead in the visual field, effectively bolted to the airframe. I've been trying to turn such that this V always moves along the horizon at a constant speed for a given bank angle. Logically, a specific bank angle in a coordinated turn will always produce a heading change at the same speed. If the speed at which the horizon is moving varies, the turn is not coordinated. Also, it seems that in a coordinated, level turn, this V should stay at the same distance above the horizon throughout the turn. As I roll into a turn, the speed of movement of the V along the horizon should increase in precise relationship to the bank angle. The opposite should occur as I roll out of the turn, with the speed along the horizon slowing as I return to level flight. Any problems with this? The only remaining problem is to figure out _how_ fast the V should be moving for a given bank angle. Maybe that can come with practice. In the real world we don't have that little V superimposed on the wind sheild. What we do have is that little dodad ball in most cases in the turn coordinator. Keep that little ball so it looks like this |O| and you will be in a coordinated turn. If you want to know how to make that V do what you want you are going to have to ask in a flight sim newsgroup. |
Gig 601XL Builder writes:
In the real world we don't have that little V superimposed on the wind sheild. What we do have is that little dodad ball in most cases in the turn coordinator. Keep that little ball so it looks like this |O| and you will be in a coordinated turn. I know, but under VFR I'm supposed to be looking out the window, not staring at the ball. I found some Web pages on this; one of them suggests looking out the side of the aircraft at the wing. If I'm in level flight, the extension of the wing out the window points to the horizon, and it moves forward (very slowly, depending on the distance of terrain). If I turn, however--and if the turn is coordinated--it seems that the extension of the wing will point to a spot on the ground that remains stationary. This spot is the center of my turn. The steeper the turn, the closer this spot will be to my aircraft, but it will always be aligned with the wing. If no spot above the wing is stationary in the turn, the turn is uncoordinated. Does that seem logical? If you want to know how to make that V do what you want you are going to have to ask in a flight sim newsgroup. The pages I read suggest making a mark on the windshield for the purpose, with a grease pencil or something. The sim provides a more perfect mark than one can achieve in real life (because in real life one moves one's head, etc.), but the same technique can be used in real life. The problem with it, though, is that I'm not sure how fast the heading should be changing for a given degree of bank, and it's not clear that there is a way to recognize this intuitively. Watching the extension of the wing out the side of the aircraft seems to work, although it's more awkward. The page I read said you can fly the aircraft all day by watching the wingtip, and this does indeed seem to be true, although I suppose one would finish the day with a sore neck. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Your model is wrong.
You might check with the sim group on how they do it. On Feb 7, 6:24 pm, Mxsmanic wrote: Gig 601XL Builder writes: In the real world we don't have that little V superimposed on the wind sheild. What we do have is that little dodad ball in most cases in the turn coordinator. Keep that little ball so it looks like this |O| and you will be in a coordinated turn. I know, but under VFR I'm supposed to be looking out the window, not staring at the ball. I found some Web pages on this; one of them suggests looking out the side of the aircraft at the wing. If I'm in level flight, the extension of the wing out the window points to the horizon, and it moves forward (very slowly, depending on the distance of terrain). If I turn, however--and if the turn is coordinated--it seems that the extension of the wing will point to a spot on the ground that remains stationary. This spot is the center of my turn. The steeper the turn, the closer this spot will be to my aircraft, but it will always be aligned with the wing. If no spot above the wing is stationary in the turn, the turn is uncoordinated. Does that seem logical? If you want to know how to make that V do what you want you are going to have to ask in a flight sim newsgroup. The pages I read suggest making a mark on the windshield for the purpose, with a grease pencil or something. The sim provides a more perfect mark than one can achieve in real life (because in real life one moves one's head, etc.), but the same technique can be used in real life. The problem with it, though, is that I'm not sure how fast the heading should be changing for a given degree of bank, and it's not clear that there is a way to recognize this intuitively. Watching the extension of the wing out the side of the aircraft seems to work, although it's more awkward. The page I read said you can fly the aircraft all day by watching the wingtip, and this does indeed seem to be true, although I suppose one would finish the day with a sore neck. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Tony writes:
Your model is wrong. What is wrong with the model? -- Transpose mxsmanic and gmail to reach me by e-mail. |
Look up the meaning of coordinated flight and the errors in your model
should be obvious. On Feb 7, 6:54 pm, Mxsmanic wrote: Tony writes: Your model is wrong. What is wrong with the model? -- Transpose mxsmanic and gmail to reach me by e-mail. |
![]() Mxsmanic wrote: Tony writes: Your model is wrong. What is wrong with the model? It's wrong. |
On Feb 8, 12:24 pm, Mxsmanic wrote:
Gig 601XL Builder writes: In the real world we don't have that little V superimposed on the wind sheild. What we do have is that little dodad ball in most cases in the turn coordinator. Keep that little ball so it looks like this |O| and you will be in a coordinated turn. I know, but under VFR I'm supposed to be looking out the window, not staring at the ball. I found some Web pages on this; one of them suggests looking out the side of the aircraft at the wing. If I'm in level flight, the extension of the wing out the window points to the horizon, and it moves forward (very slowly, depending on the distance of terrain). If I turn, however--and if the turn is coordinated--it seems that the extension of the wing will point to a spot on the ground that remains stationary. This spot is the center of my turn. The steeper the turn, the closer this spot will be to my aircraft, but it will always be aligned with the wing. If no spot above the wing is stationary in the turn, the turn is uncoordinated. Does that seem logical? If you want to know how to make that V do what you want you are going to have to ask in a flight sim newsgroup. The pages I read suggest making a mark on the windshield for the purpose, with a grease pencil or something. The sim provides a more perfect mark than one can achieve in real life (because in real life one moves one's head, etc.), but the same technique can be used in real life. The problem with it, though, is that I'm not sure how fast the heading should be changing for a given degree of bank, and it's not clear that there is a way to recognize this intuitively. Watching the extension of the wing out the side of the aircraft seems to work, although it's more awkward. The page I read said you can fly the aircraft all day by watching the wingtip, and this does indeed seem to be true, although I suppose one would finish the day with a sore neck. -- Transpose mxsmanic and gmail to reach me by e-mail. Step on the ball... You may or may not know about adverse yaw - when you use the ailerons they are producing more lift on the upgoing wing, and lift produces drag so the wing initially moves the wrong way. You need to apply rudder in the direction of the turn as you are using the ailerons, then back off the rudder as you centre the yoke / stick. You will then find you need to apply a small amount of left rudder, no rudder or right rudder depending on the angle of bank. You will soon work it out. I still have to glance at the ball from time to time, but it is something you do get used to.. Every aircraft is different with regards to how much rudder you need to apply. |
Mxsmanic wrote:
Gig 601XL Builder writes: In the real world we don't have that little V superimposed on the wind sheild. What we do have is that little dodad ball in most cases in the turn coordinator. Keep that little ball so it looks like this |O| and you will be in a coordinated turn. I know, but under VFR I'm supposed to be looking out the window, not staring at the ball. It isn't a binary set solution. One of the things you learn in basic flight training is to use the instruments you have without fixating on them. |
Air Force One Had to Intercept Some Inadvertent Flyers / How? | Rick Umali | Piloting | 29 | February 15th 06 04:40 AM |
I want to build the most EVIL plane EVER !!! | Eliot Coweye | Home Built | 237 | February 13th 06 03:55 AM |
Most reliable homebuilt helicopter? | tom pettit | Home Built | 35 | September 29th 05 02:24 PM |
Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 11:35 AM |
Nearly had my life terminated today | Michelle P | Piloting | 11 | September 3rd 05 02:37 AM |
