Jim Carter wrote:
If the aircrew "needed to get on the ground right away", why did they overfly other suitable airports? That action alone could have suggested to ATC that this wasn't that big an issue. Love Field has equipment to deal with air carrier class aircraft and they flew right past it even after being asked about landing there. I don't know. It isn't relevant to what happened. During a declared emergency the PIC gets what he or she needs. The questions come later. That didn't happen in this case and that is all that matters. Matt |
"Jim Carter" wrote in message
t... If the aircrew "needed to get on the ground right away", why did they overfly other suitable airports? That action alone could have suggested to ATC that this wasn't that big an issue. Love Field has equipment to deal with air carrier class aircraft and they flew right past it even after being asked about landing there. Between Tulsa and DFW, which airports would those be? -- Matt Barrow Performance Homes, LLC Colorado Springs, CO |
I believe the closest would have been Love based on the point at which he
mentioned the fuel problem. This has already been addressed in this thread so I suspect you already knew that Matt. I'm not condoning what ATC did or how they responded, but like the UK pilot that continued on single-engine across the pond I wonder why AA continued on past a suitable airport once they knew they had a problem. That's all I'm questioning. -- Jim Carter Rogers, Arkansas "Matt Barrow" wrote in message ... "Jim Carter" wrote in message t... If the aircrew "needed to get on the ground right away", why did they overfly other suitable airports? That action alone could have suggested to ATC that this wasn't that big an issue. Love Field has equipment to deal with air carrier class aircraft and they flew right past it even after being asked about landing there. Between Tulsa and DFW, which airports would those be? -- Matt Barrow Performance Homes, LLC Colorado Springs, CO |
that continued on single-engine across the pond I wonder why AA continued on past a suitable airport once they knew they had a problem. That's all I'm questioning. In fact, it was a British Airways 747 that continued on three engines, not one. Here's an interesting column about that the incident: http://www.avweb.com/news/pelican/193882-1.html |
You're right - my mistake.
-- Jim Carter Rogers, Arkansas "Barry" wrote in message . .. I'm not condoning what ATC did or how they responded, but like the UK pilot that continued on single-engine across the pond I wonder why AA continued on past a suitable airport once they knew they had a problem. That's all I'm questioning. In fact, it was a British Airways 747 that continued on three engines, not one. Here's an interesting column about that the incident: http://www.avweb.com/news/pelican/193882-1.html |
Jim Carter wrote:
I believe the closest would have been Love based on the point at which he mentioned the fuel problem. This has already been addressed in this thread so I suspect you already knew that Matt. Did you see the plot I posted in a similar thread? DAL and DFW 17C were the same distance from his position at declaration. Check the message I left pointing to the graphic, in which I give the Part 121 perspective. |
Just saw it Sam. Nice perspective and probably pretty accurate too. I am no
way advocating that ATC did right, I was just wondering if the actions of the aircrew might seem inconsistent with their declarations. I'm not sure that can be answered, but it really shouldn't matter either. -- Jim Carter Rogers, Arkansas "Sam Spade" wrote in message ... Jim Carter wrote: I believe the closest would have been Love based on the point at which he mentioned the fuel problem. This has already been addressed in this thread so I suspect you already knew that Matt. Did you see the plot I posted in a similar thread? DAL and DFW 17C were the same distance from his position at declaration. Check the message I left pointing to the graphic, in which I give the Part 121 perspective. |
![]() "Jim Carter" wrote in message t... I believe the closest would have been Love based on the point at which he mentioned the fuel problem. This has already been addressed in this thread so I suspect you already knew that Matt. How does the distance to DFW compare to the distance to DAL from that point? I'm not condoning what ATC did or how they responded, but like the UK pilot that continued on single-engine across the pond I wonder why AA continued on past a suitable airport once they knew they had a problem. That's all I'm questioning. He continued on with three engines, not one. |
Sam Spade wrote:
http://www.kvue.com/sharedcontent/Vi...2817&catId=104 I listened to the tape all the way through. FIRE THE CONTROLLER. I'd have been yelling at him, at that point. |
Handling Characteristics of the Flight Design CTSW | John | Piloting | 9 | March 14th 07 03:38 AM |
American Flight 191 - Recovery Procedure | Rick Umali | Piloting | 17 | November 5th 06 03:35 AM |
Angel Flight fuel discounts | John Doe | Piloting | 4 | January 20th 06 01:24 PM |
Passenger attempts to hijack American Eagles flight | C J Campbell | Piloting | 5 | January 11th 04 04:04 PM |
American Safety Flight Systems seat belts -- Help! | Paul Millner | Owning | 1 | July 7th 03 10:10 PM |
