mobile phones
Old March 4th 07, 09:37 PM posted to rec.aviation.soaring
Peter[_4_]
Default mobile phones
What is the maximum altitude (about) when the mobile phone becomes useless?
PeterK
Old March 4th 07, 10:58 PM posted to rec.aviation.soaring
chipsoars
PeterK
I've had it ring at 2500'agl at which point I told whoever (my wife
and curtly too) that I was busy flying and then shut it off (I forgot
to shut it off prior to launch). If many consider it unsafe to drive
and talk, why do it in the air?
Old March 4th 07, 11:11 PM posted to rec.aviation.soaring
Michael Ash
PeterK
There was a study* done on cell phone use in airliners which determined
that an average of 1-4 calls are made on each commercial flight in the
northeast US. If you can get a signal at 35,000 feet inside an aluminum
spam can, I'm sure you can get one just about anywhere in your glider.
* Briefly mentioned on http://www.post-gazette.com/pg/06060/662669.stm , I
didn't find the original study.
Michael Ash
Rogue Amoeba Software
Old March 4th 07, 11:28 PM posted to rec.aviation.soaring
Eric Greenwell
useless? PeterK
It varies enormously in the USA. My experience is the closer I get to a
big city, the lower I have to be to get a signal, maybe 3000' agl. In
the country, I've used it at 15,000' agl during wave flights. My
explanation is the smaller cells and lower powers used in areas with a
lot of people just don't reach upwards very high.
drive and talk,
Driving requires constant attention because obstacles are so close to
you, like oncoming traffic and the ditch beside the road. This isn't
true for most glider flying. So, it's easier to do safely.
I usually do it because I can't reach my crew on the radio; e.g., my
radio or theirs has failed, I am too far away, or there's a mountain in
the way. Recently, our local ASOS was off the air but it still reported
over it's phone number - most pilots dialed it up when they were inbound
for a landing.
I don't suggest using it to chit-chat, or when you need to concentrate
on flying the glider, but if it will significantly improve your safety,
it seems like a good use of the phone.
Old March 5th 07, 12:45 AM posted to rec.aviation.soaring
Peter[_4_]
While sitting around yesterday morning sipping coffee with the Caracole
group(Cal City), the conversation came up again about the use of mobile
phones as an alternate to radio communications namely when we loose them.
Most of us that fly cross country may have experienced this phenomena and it
is a rather lonely feeling when for example we fly over the decollate Nevada
sky and our crews are trying to follow us through rugged mountains.This loss
of contact may cause us to land prematurely as this is the responsible thing
to do in respect to the crew when we lose total contact. I admit have tried
to use my mobile phone (voice) while flying in the passed but never with
much success.
But than Cindy Brickner (once again) comes up with this idea of text
messaging! As far as I understand her thoughts correctly ( I never sent a
text message in my life), if the pilot or crew sends a short text message
even if there is just a week signal the message will go through in a matter
of second. The same way as soon as there is the slightest signal on their
other end it will be received.
I am certainly not advocating this method as an everyday remedy but
certainly would be better than calling out on 121.5 for assistance and maybe
alarming a bunch of folks (as I read previously onR.A.S.) I would like your
thoughts once again. PeterK
news:wCIGh.1223$mI6.1220@trndny08...
useless? PeterK
I've had it ring at 2500'agl at which point I told whoever (my wife and
drive and talk,
Driving requires constant attention because obstacles are so close to you,
like oncoming traffic and the ditch beside the road. This isn't true for
I usually do it because I can't reach my crew on the radio; e.g., my radio
or theirs has failed, I am too far away, or there's a mountain in the way.
Recently, our local ASOS was off the air but it still reported over it's
phone number - most pilots dialed it up when they were inbound for a
landing.
I don't suggest using it to chit-chat, or when you need to concentrate on
flying the glider, but if it will significantly improve your safety, it
Old March 5th 07, 01:58 AM posted to rec.aviation.soaring
Mike the Strike
Both text messages and some 911 calls will go through with much weaker
signals than needed to complete a regular call.
911 operators will relay non-emergency messages if you explain the
problem.
Old March 7th 07, 04:14 AM posted to rec.aviation.soaring
Why?
Is this a technical fact or just a wishfull speculation?
rk
Old March 11th 07, 10:14 PM posted to rec.aviation.soaring
Martin Gregorie
There was a good example of this recently in NZ. A girl rolled her car
and ended 3.5m down a bank with the car upside down and supported over a
river by the bank and some trees, which were evidently fairly thin,
because she wasn't about to try getting out in case the car fell into
the river while she was getting out.
Her phone wouldn't raise anybody, including emergency services, due to
poor signal from where she was, but she was able to text a friend, who
passed the emergency call on.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old March 5th 07, 03:06 PM posted to rec.aviation.soaring
Tuno
As Mike said, text messages and some 911 signals require much less
power and signal to go through. (Mobile phone software enforces a
"quality of service" threshold; if it cannot be met or exceeded for a
voice call, it will not go through, but this threshold is very
different for text and emergency calls.)
I landed out ~50 miles south lf Moriarty a couple of years ago and my
mobile didn't work; it showed a weak analog signal but wouldn't place
calls. But 911 worked, and when I explained by situation to the
operator, she got called my crew number and we got hooked up.
~ted/2NO
Old March 5th 07, 03:24 PM posted to rec.aviation.soaring
Lew Hartswick
~ted/2NO
Where were you? about Claunch? That is some desolate country.
...lew...
Cell phones on GA aircraft Mxsmanic Piloting 18 October 16th 06 08:12 PM
GET FREE CELL PHONES and CAMERA PHONES! ssgg Home Built 0 February 13th 06 02:34 AM
Fun with Wx on Cell Phones B4RT Rotorcraft 0 October 9th 05 02:45 PM
Cell phones in the air Roger Worden Soaring 35 March 30th 05 11:01 PM
Cell phones with GPS Roger Halstead Piloting 0 December 24th 03 03:04 AM
