![]() I'd sure rather swap a bladder in a Bonanza than fix a leaking Mooney tank. Working with very bad chemicals thru a small hole is no fun at all. On the Bonanza, doing the snaps in the correct order helps. You can also snap them from the TOP of the bladder which is much easier than working through the fuel cap hole. Bill Hale Despite Jay's tale of woe, pulling a Cherokee wing tank is a matter of removing some 10-32 structural machine screws and sliding the whole thing out (in one piece) out of the wing. Repairs are just like any other "wet-wing" structure, but you have the piece of wing laying on the workbench, with ready access to the majority of the rivets. Getting the screws out can be a real bitch, but it doesn't involve any rivets, snaps or duct tape. The composite Cherokee tip tank is another story-I'd rather have a bladder any day of the week. BTW, why did you charge yourself labor for changing out a bladder? TC |
Newps wrote:
How do you get a Cherokee tank out? Derivet? Remove a wing? Cherokee tanks don't have bladders. The tank forms a portion of the leading edge of the wing. It is held in by about 70 screws around the edge of the tank. After taking out the screws the tank slides forward, often with the help of a 2x4 place along the rear edge on top of the spar and a rubber mallet. Assuming the screws haven't corroded into place, it takes about a half hour to pull an empty tank off a Cherokee. The tanks do start to leak at the seams sometimes. They can be resealed by drilling out all the rivets, cleaning up the pieces and putting them back together with new sealing compound at the seams, which is typically done by a shop that specializes in rebuilding cherokee tanks. |
![]() How do you get a Cherokee tank out? Derivet? Remove a wing? Actually, it ain't bad. You remove the 48 structural screws that make it a part of the wing (been there, done that to both tanks). If you can spot the leak and it is one of the "usual" suspects (overflow hose or sending unit gasket) you are home free. If it is one of the rivets you have a little longer trip home. Jay was able to get at it and rebuck it down. Most times, you send the thing out to get completely dismantled, reriveted back together and sealed. Around $400 per tank. Mike |
![]() "Mike Spera" wrote in message hlink.net... How do you get a Cherokee tank out? Derivet? Remove a wing? Actually, it ain't bad. You remove the 48 structural screws that make it a part of the wing (been there, done that to both tanks). If you can spot the leak and it is one of the "usual" suspects (overflow hose or sending unit gasket) you are home free. If it is one of the rivets you have a little longer trip home. Jay was able to get at it and rebuck it down. Most times, you send the thing out to get completely dismantled, reriveted back together and sealed. Around $400 per tank. Mike Or.............................You get at it, rebuck it, reinstall it..........then wait 5 weeks till it starts leaking again. Then you send it out to be done correctly! Karl |
Jay - Put a drop of antisieze on the threads (and maybe under the head
too) of each screw that has to go back into a threaded insert. Don't let ANY antisieze get near the Philips driver or the screwheads or driver will cam out on reassembly. Antisieze seals the thread from further corrosion and does wonders for the next time they have to be removed. Stainless screws especially need this treatment, as they too will corrode in the presence of aluminum. |
the next time they have to be removed. Stainless screws especially need this treatment, as they too will corrode in the presence of aluminum. Thanks for the tip! -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
chicago area residential airpark and maintenance facility good deals on annual inspections | [email protected] | Owning | 7 | September 15th 05 02:55 AM |
Good morning or good evening depending upon your location. I want to ask you the most important question of your life. Your joy or sorrow for all eternity depends upon your answer. The question is: Are you saved? It is not a question of how good | Excelsior | Home Built | 0 | April 22nd 05 01:11 AM |
Is a 152 a good start? | AliR | Piloting | 17 | April 20th 05 05:52 PM |
[US: PA/NY/NJ] Governor's Cup off to a good start | Papa3 | Soaring | 0 | April 13th 05 10:36 PM |
'Good' Annual This Year | Ben Smith | Owning | 38 | July 26th 03 05:44 AM |
