Almost got My Ticket Yesterday
Old April 5th 07, 07:04 PM posted to rec.aviation.piloting,rec.aviation.student
Mark T. Dame
Default Almost got My Ticket Yesterday
CareBear wrote:
Although I did not get the ticket, I still feel good about the overall
outcome. It's interesting in that I felt my weakest area would be the oral
but this went well. I did have a couple of slips (no pun intended) during
the oral but quickly regrouped and gave the correct response. The oral
lasted about 2.5 hours.
It sounds like your examiner is pretty thorough. That's a pretty long
oral for a private checkride. Slips and soft field landings are
probably the toughest things in the private checkride. In fact, before
I started working on my CFI ticket, I hadn't done a slip since I got my
private certificate, and I had a lot of trouble on the first couple.
So, look at it this way: your examiner is going to make sure you are
well qualified when he signs your ticket. Be proud of that and good luck!
-m
## Mark T. Dame
## VP, Product Development
## MFM Software, Inc. (http://www.mfm.com/)
100% - effort level demanded by coaches who majored in math or science
110% - effort level demanded by coaches who majored in physical education
-- Coach Jack Reed (http://www.johntreed.com/)
  #34
Old April 5th 07, 10:41 PM posted to rec.aviation.piloting,rec.aviation.student
Jose
Well....no. A side slip is used to compensate for crosswind drift, the
aircraft longitudinal axis is parallel to the runway centerline. A forward
slip is used to increase the descent rate, the aircraft nose will be at an
angle to the runway.
It's the same maneuver. The airplane can't tell the difference.
However, the word usage (as above) indicates the purpose of the maneuver.
Jose
Get high on gasoline: fly an airplane.
  #35
Old April 5th 07, 10:44 PM posted to rec.aviation.piloting,rec.aviation.student
Andrew Gideon
And, though I've heard about the "crab and kick" method, I'm a little
surprised that it works. As soon as one "kicks", one is drifting. Isn't
the side-loading at touch-down a problem? Or is that too small to matter?
- Andrew
  #36
Old April 5th 07, 11:23 PM posted to rec.aviation.piloting,rec.aviation.student
Jay Beckman
news
- Andrew
As you "kick," you lower the upwind wing and keep runway alignment with
rudder. No drift.
Jay B
  #37
Old April 6th 07, 03:51 AM posted to rec.aviation.piloting,rec.aviation.student
Steve Foley[_2_]
"Mark T. Dame" wrote in message
I second that. The only way to improve the signal to noise ratio is to
have more valuable posts, since the noise isn't going to go away.
What noise?
View-Current View-Show All Messages
OH! That noise!!!
View-Current View-Hide Ignored Message
ahhhhhh... That's better......
  #38
Old April 9th 07, 01:13 AM posted to rec.aviation.piloting,rec.aviation.student
Andrew Gideon
rudder. No drift.
Well, it's been a long time since that method has been described to me.
But I've long assumed that the "crab and kick" method didn't involve a
transition into a slip. If I'm wrong, then I've been doing "crab and
kick" for a while.
- Andrew
  #39
Old April 11th 07, 03:25 AM posted to rec.aviation.piloting,rec.aviation.student
Euan Kilgour
If you lower the into wind wing too much or not enough you run the
risk of sideloading the gear so it requires a steady hand and constant
adjustments to get it right. Its not rocket science though.
WTB: 135 Ticket AML General Aviation 2 May 30th 06 03:10 PM
WTB: 135 Ticket AML Piloting 28 May 26th 06 04:10 PM
WTB:135 Ticket AML Owning 1 May 24th 06 08:41 PM
WTB: 135 Ticket AML Aviation Marketplace 1 May 24th 06 03:32 PM
Got my ticket... now what? Cub Driver Piloting 3 July 10th 03 07:14 AM
