#31
Ron Natalie writes:
No you are confused. Magnetic SOUTH is the exact opposite of magentic north you fool. The fact that the MAGNETIC SOUTH POLE is not exactly opposite the MAGNETIC NORTH POLE is a different issue. I assumed that others would understand this, but I often get into trouble when I assume others will understand things. The fact that the poles aren't aligned with the arbitrary "true" datum just means that the variation equations aren't as simple as they might be. They are more than just misaligned: they are not at opposite points in terms of longitude and latitude, either. A line drawn between them does not intersect the center of the Earth. Really, like what? GPS and inertial reference platforms, VORs, NDBs, you name it. Compasses are still damned reliable compared to anything else. Cheap too. The only thing that presumes to do better perhaps is GPS. And it's easier to program that to deal with the magnetic measurements than to try to force everybody else the other way. So how often do you fly using just your magnetic compass alone? -- Transpose mxsmanic and gmail to reach me by e-mail. |
#32
Ron Natalie writes:
Because we don't have a TRUE NORTH indicator in the cockit. You do if you have systems like GPS or INS. Just a magnetic compass and instruments derived from it. Real flying ain't a stupid-assed computer simulation. Maybe you should take a tranquilizer; you seem very upset. -- Transpose mxsmanic and gmail to reach me by e-mail. |
#33
On Apr 4, 9:06 am, "Kev" wrote:
On Apr 4, 2:32 am, Tauno Voipio wrote: It's a nuisance for maintenance, but it frees the pilot from calculating the variation at the operative time. Just to off-load the pilot. A good answer. Same for winds in flight, etc. Everything is based on the magnetic to make it easier for the pilot. [..] Oops! I can't believe I wrote that about winds in flight. Of course they're true, so they can be used over a wider area. Winds at the _airport_ are magnetic, is what I meant to say... so the pilot doesn't have to convert while landing. Hmm. So if we switched to true North navigation, then runways would all need repainting... but at least they and the VORs wouldn't have to be changed ever again ;-) Seems like something the government would come up with to save money! Kev |
#34
#35
On Wed, 04 Apr 2007 16:28:41 GMT, "Steven P. McNicoll"
wrote: "Ron Natalie" wrote in message om... Huh? What does the wind have to do with VOR's. If the needle is centered, you're within the tolerance of the VOR. The tolerance is primarily 4-6 degrees. This keeps you inside the airway at moderate distances from the VORs. What about at more than moderate distances from the VOR? At 40 miles from the VOR 6 degrees is 4 miles. Under the heading of "Enquiring Minds Want to Know: In defining an intersection, what's the maximum distance from a VOR that's allowed? Does an intersection in a GPS database represent the actual intersection of VOR radials, or is it defined in LAT/LON terms? (I.e., can there be two locations for an intersection, depending on whether you're using VORs or GPS? Apart from shifting declination, what is the mechanism by which VORs drift out of calibration? Isn't the phase shift for each antenna in the array set by the length of coax between it and the transmitter? Does Velocity Factor change significantly as the coax ages? If it is a matter of aging cable, does that mean the error is uniform and the pattern is shifted consistently around the compass rose, or are the longer cables affected more? And in the latter case, how would that affect the error? (I would think that the higher the radial, the greater the error, if this were the case.) (Or do I not understand how a VOR array is phased?) Don |
#36
Steven P. McNicoll writes:
"The magnetic variation of the earth changes at a rate of 50.27 seconds of arc per year." That seems a bit low to me. At that rate six degrees of change would take 430 years. It changes at a variable rate, and once it approaches a degree, charts and navaids have to change. It's a tremendous amount of extra work, an additional source of error, and an imprecise and fickle basis for navigation. -- Transpose mxsmanic and gmail to reach me by e-mail. |
#37
That would be true if VORs were set to local magnetic variation. They rarely are. Which variation are they set to, and how useful can they be if their orientation doesn't match the local magnetic variation? That doesn't happen until they differ by 6 degrees with local variation. Where did you get this figure? -- Transpose mxsmanic and gmail to reach me by e-mail. |
#38
Ron Natalie writes:
So that they line up with the compass. All in-flight navigation is magnetic based. Some transoceanic flights might disagree. -- Transpose mxsmanic and gmail to reach me by e-mail. |
#39
Some of you guys are a *lot* more trusting than I am. I was really hoping
for some of the current airmen to say this, but most have only nibbled around the edges--so here goes: The magnetic compass has exactly one thing in its favor, and that is just plain old Brute Reliability. It requires no power from the aircraft's systems, it is not subject to happenstance or whim concerning any transmitting stations, and wide spread interference with (the) signal is unimaginable. Learn to love it, because it is here to stay! Peter Well, Peter, in 40 some years and 5000 some hours in everything from no-electric system gliders to modern jet fighters, I've never had to resort to only a whiskey compass to navigate. Sure I cross check it, but I view it as an emergency system. And I've actually seen more inoperative whiskey compasses than other bits of more complicated navigation equipment. If you are worried about system failure, then carry a handheld backup GPS and radio. About the same cost as a good mag compass, by the way - but will tell you where you are, or let you ask someone where you are if the GPS gods take a nap. All that mag compass will tell you is which way you are kinda going. Anyone out there who (honestly) uses only his mag compass as his primary navigation equipment, let's hear from you. And using the whiskey compass to set the DG doesn't count - we're talking navigation by charted heading and mag compass. Tried rolling out on and holding an accurate heading using only your whiskey compass lately? Fun, isn't it...That's why they invented the DG. Don't have a fancy nav system that figures out true north? Gee, apply local variation to your mag heading and presto, true north! Easy to set a DG to true that way. Bottom line, if the mag compass was demoted to emergency heading reference, we could accept the mag var problem and use true heading for day to day use. Heck, most whiskey compasses swing as much as the local variation inflight, anyway! But as has been stated; inertia, old habits, and existing equipment all work against moving to the use of True instead of Magnetic. Kirk |
#40
Peter Dohm writes:
Some of you guys are a *lot* more trusting than I am. I was really hoping for some of the current airmen to say this, but most have only nibbled around the edges--so here goes: The magnetic compass has exactly one thing in its favor, and that is just plain old Brute Reliability. It requires no power from the aircraft's systems, it is not subject to happenstance or whim concerning any transmitting stations, and wide spread interference with (the) signal is unimaginable. It's already so inaccurate without interference that that's bad enough. There are plenty of spots on charts where the compass will be 6-8 degrees off even from the already irrgular declination over larger areas. Anyway, if you push this concept to its limit, you should be able to complete a trip without an engine, since engines are not 100% reliable. Obviously, that's not a practical reality, and at some point you have to recognize that a compass alone, no matter how reliable in the sense of always working to some extent, may simply not be enough to get you home. -- Transpose mxsmanic and gmail to reach me by e-mail. |
RANT! | wise purchaser | Owning | 2 | March 27th 07 10:04 PM |
Random thoughts 2 | Bill Daniels | Soaring | 6 | September 1st 06 05:37 AM |
A Jeppesen rant | Peter R. | Piloting | 4 | January 17th 05 03:54 AM |
Why didn't GWB [insert rant] | Jack | Military Aviation | 1 | July 15th 04 11:30 PM |
Random Hold Generator... | Tina Marie | Instrument Flight Rules | 0 | November 5th 03 04:21 PM |
