C J Campbell wrote:
Not that I have done this or given it much thought. :-) Okay, I was a navigator/bombardier on C-130 Hercules planes, and had one of the most consistently accurate drop records in our wing. But aside from that.... So, bottom line, the only reason you need to know you are over an exact point is indeed if you are going to drop something (or photograph something straight down) and the way you tell you are there is to line up on two objects in front -- so that they are line with each other -- and two objects in line with each other to the side. Roads work well. So do utility lines, fences, buildings, and rows of crops or trees. Man likes straight lines, and that makes it easier for other men to drop things on him. Hmmm. So my golf ball accuracy can become far better. So basically, make crosshairs with landmarks, then calculate forward travel and wind. Check. My neighbor's car is in real trouble now. |
![]() "Erik" wrote in message ... C J Campbell wrote: Not that I have done this or given it much thought. :-) Okay, I was a navigator/bombardier on C-130 Hercules planes, and had one of the most consistently accurate drop records in our wing. But aside from that.... So, bottom line, the only reason you need to know you are over an exact point is indeed if you are going to drop something (or photograph something straight down) and the way you tell you are there is to line up on two objects in front -- so that they are line with each other -- and two objects in line with each other to the side. Roads work well. So do utility lines, fences, buildings, and rows of crops or trees. Man likes straight lines, and that makes it easier for other men to drop things on him. Hmmm. So my golf ball accuracy can become far better. So basically, make crosshairs with landmarks, then calculate forward travel and wind. Check. My neighbor's car is in real trouble now. Just stick with CJ, he'll have you dropping par in no time. |
... ... Hmmm. So my golf ball accuracy can become far better. So basically, make crosshairs with landmarks, then calculate forward travel and wind. Check. My neighbor's car is in real trouble now. http://cgi.ebay.com/NORDEN-BOMBSIGHT-Rate-End-Computer-Manual-and-Book_W0QQitemZ110104630178QQihZ001QQcategoryZ585QQ rdZ1QQssPageNameZWD1VQQcmdZViewItem -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. |
On 2007-04-18 14:02:31 -0700, Erik said:
C J Campbell wrote: Not that I have done this or given it much thought. :-) Okay, I was a navigator/bombardier on C-130 Hercules planes, and had one of the most consistently accurate drop records in our wing. But aside from that.... So, bottom line, the only reason you need to know you are over an exact point is indeed if you are going to drop something (or photograph something straight down) and the way you tell you are there is to line up on two objects in front -- so that they are line with each other -- and two objects in line with each other to the side. Roads work well. So do utility lines, fences, buildings, and rows of crops or trees. Man likes straight lines, and that makes it easier for other men to drop things on him. Hmmm. So my golf ball accuracy can become far better. So basically, make crosshairs with landmarks, then calculate forward travel and wind. Check. My neighbor's car is in real trouble now. Grasshopper, the acme of skill is not in hitting your neighbor's car with a golf ball. The acme of skill is hitting the sunroof of your neighbor's car with the golf ball. Of course, when we lived in McCormick Woods, we had golf balls in our driveway all the time. So we would not have noticed one dropped from an airplane. A tomato, however... -- Waddling Eagle World Famous Flight Instructor |
![]() "C J Campbell" wrote in message news:2007041813510751816-christophercampbell@hotmailcom... On 2007-04-18 12:02:54 -0700, Erik said: Maxwell wrote: "Mxsmanic" wrote in message ... How do you know when you are exactly overflying a specific spot on the ground? It's it just a matter of knowing your particular aircraft, or are there tricks that can help to determine this? I know you can look off the tip of your wing to see if you're abeam something (such as a runway), but how can you tell when you're right over something? I presume there's no way to look straight down from most aircraft, and it seems like the view over the nose is often several miles away. Why would a pilot care? You don't want to pelt noncombatants with errant golf balls! A golf ball (or anything else) doesn't drop straight down. You have to release it before you reach your target as it continues to move forward at the speed of the aircraft. Damn good stuff snipped... Not that I have done this or given it much thought. :-) -- Waddling Eagle World Famous Flight Instructor Our EAA chapter has a blue tarp that we use as a target for "flour bombing". Actually we use gypsum in an ice cream bag. The tarp remains unscathed after many years of use. In fact, standing directly on the aim point might be the safest spot. Al G |
"Al G" wrote in message
... ... Our EAA chapter has a blue tarp that we use as a target for "flour bombing". Actually we use gypsum in an ice cream bag. The tarp remains unscathed after many years of use. In fact, standing directly on the aim point might be the safest spot. Al G Apparently not: http://www.alexisparkinn.com/photoga...s_reporter.wmv -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. |
Maxwell writes:
Why would a pilot care? When reporting position, or when following instructions to "cross XYZ at 6000," or whatever. Or when giving the location of a family in distress next to their SUV below. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Mxsmanic wrote:
Maxwell writes: Why would a pilot care? When reporting position, or when following instructions to "cross XYZ at 6000," or whatever. Or when giving the location of a family in distress next to their SUV below. Reporting position is all about just letting people know what direction to look for you. I'm not IFR, but I've never heard anyone get a request to cross a particular point, I have heard them tell pilots to turn left/right to a particular heading. If I tell an airport that I'm 6 miles east inbound and will enter a 45 for downwind, they know what direction to look, they generally know the area and what approach I'm going to use to enter the pattern. I never say my altitude unless I'm crossing over an airport or in a situration where there's a high likelyhood of having company close by. Coming into a pattern, your altitude changes a lot. Do not be one of these people that call every damn thing you do. I don't care if you were at 3000 and are going to 2000. If you call that you're entering the pattern, I care where you are and how you're entering. I already know your altitude (should be) is at TPA by the time you get there. If you call that you're leaving the pattern, I don't care where you're going. You can say that you're departing to the north or whatever, but there's plenty of people out there that make completely useless calls. I'm departing to the north. Now I'm heading north at 2500. Now I'm 5 miles north of the airport. Now I'm at 3000. I DON'T CARE GO AWAY. If you were directly overhead of an SUV and a family, you wouldn't see them. You'd really make a turn around a point and look for landmarks around them. |
Erik writes:
Reporting position is all about just letting people know what direction to look for you. Telling them that you're crossing the XYZ VOR or the football stadium is one way to do that. I'm not IFR, but I've never heard anyone get a request to cross a particular point, I have heard them tell pilots to turn left/right to a particular heading. I've regularly heard "cross XYZZY at or below 12000." Do not be one of these people that call every damn thing you do. Why not? You can never be too aware of your situation. I don't care if you were at 3000 and are going to 2000. Someone who is at 2000 and things I'm still at 3000 might care a lot. ... but there's plenty of people out there that make completely useless calls. I'm departing to the north. Now I'm heading north at 2500. Now I'm 5 miles north of the airport. Now I'm at 3000. I DON'T CARE GO AWAY. If you were in their path, you'd care a lot. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Mxsmanic wrote:
Erik writes: Reporting position is all about just letting people know what direction to look for you. Telling them that you're crossing the XYZ VOR or the football stadium is one way to do that. I'm not IFR, but I've never heard anyone get a request to cross a particular point, I have heard them tell pilots to turn left/right to a particular heading. I've regularly heard "cross XYZZY at or below 12000." Do not be one of these people that call every damn thing you do. Why not? You can never be too aware of your situation. I don't care if you were at 3000 and are going to 2000. Someone who is at 2000 and things I'm still at 3000 might care a lot. ... but there's plenty of people out there that make completely useless calls. I'm departing to the north. Now I'm heading north at 2500. Now I'm 5 miles north of the airport. Now I'm at 3000. I DON'T CARE GO AWAY. If you were in their path, you'd care a lot. Has anyone used the word douchebag yet? |
overflying Canada along east coast of Lake Huron | akiley | Piloting | 3 | March 11th 07 08:25 PM |
overflying Canada along east coast of Lake Huron | akiley | Piloting | 0 | March 11th 07 03:17 AM |
[ATTN] Jim Weir or anyone knowing about old gyro compasses | B.B. | Home Built | 1 | November 22nd 04 05:49 PM |
