#31
On 2007-05-20, Dan wrote:
What are the proper control inputs to correct the situation? Whatever it takes (including FULL control deflection) to keep it going straight. If you're starting to weather vane to the right, and are still weather vaning with the amount of left rudder you have, adding more left rudder until you start going straight won't make you ground loop. On the contrary - it'll stop you ground looping to the right! The C182 has quite an effective rudder (good enough for a 20 kt direct crosswind, when running just on the main wheels) - don't be shy about using it! Never give up - if it looks like you need more control input to keep it from going off the runway, use it. If you find yourself in a situation with a sudden very strong crosswind gust, don't forget the wheel brake also counts for directional control. -- Yes, the Reply-To email address is valid. Oolite-Linux: an Elite tribute: http://oolite-linux.berlios.de |
#32
Alan Gerber wrote:
In rec.aviation.student B A R R Y wrote: Most of the non-towered fields I use have either an AWOS or ASOS (maybe Belfort? G), that updates every minute, but the same caveats apply about the location of the instrument taking the reading vs. the runway. Besides that, the wind can *change* between the time the reading is taken and the time you flare. Absolutely! Each landing was different from the one before That's the thing about landings. G |
#33
Recently, Dan posted:
I've got a question for the group. Suppose you find yourself in the following situation: You are flying a C182, landing on runway 22. The ATIS lists the winds as 240 at 10. The windsock is not visible. [...] That is not a lot of wind, and it's certainly not a lot of crosswind (get out the whiz wheel). The result that you were experiencing has to be from some other cause... perhaps ATIS was wrong? So... what I'd suggest is to pay attention to what the plane *is* doing rather than the theory of what it should be doing based on ATIS. Neil |
#34
Matt Whiting wrote: Newps wrote: Peter Dohm wrote: I am pretty sure that there is also more wind six feet from the graound than there is three feet from the ground. You're kidding. Presumably there are plenty of statistics on the subject, You'll never find that as it isn't true. It absolutely is true. Wind velocity drops dramatically as it approaches a surface. I better get my digital handheld windmeter recalibrated becxause at 4 feet, the top of the wing on my Bo and six feet, the top of the wing on a typical Cessna the wind is the same. |
#35
On May 21, 5:23 am, "Neil Gould" wrote:
Recently, Dan posted: I've got a question for the group. Suppose you find yourself in the following situation: You are flying a C182, landing on runway 22. The ATIS lists the winds as 240 at 10. The windsock is not visible. [...] That is not a lot of wind, and it's certainly not a lot of crosswind (get out the whiz wheel). The result that you were experiencing has to be from some other cause... perhaps ATIS was wrong? So... what I'd suggest is to pay attention to what the plane *is* doing rather than the theory of what it should be doing based on ATIS. Neil OK... However, it does sound like the consensus from the group is that aileron does nothing to correct drift once the plane has touched down... --Dan |
#36
On May 21, 5:23 am, "Neil Gould" wrote: Recently, Dan posted: I've got a question for the group. Suppose you find yourself in the following situation: You are flying a C182, landing on runway 22. The ATIS lists the winds as 240 at 10. The windsock is not visible. [...] That is not a lot of wind, and it's certainly not a lot of crosswind (get out the whiz wheel). The result that you were experiencing has to be from some other cause... perhaps ATIS was wrong? So... what I'd suggest is to pay attention to what the plane *is* doing rather than the theory of what it should be doing based on ATIS. Neil OK... However, it does sound like the consensus from the group is that aileron does nothing to correct drift once the plane has touched down... I agree, if all wheels are on the ground and the wind is light. OTOH, if you are touched down on one main, the ailerons are rather important. If the winds are heavy, they can also keep both of your mains planted on the runway. IMO, there is no pat answer that supercedes paying attention to what the plane is doing. You've gotten some good feedback, and I'd second the suggestion that you to get some more x-wind experience with an instructor. Neil |
#37
"Dan" wrote in message oups.com... On May 21, 5:23 am, "Neil Gould" wrote: Recently, Dan posted: I've got a question for the group. Suppose you find yourself in the following situation: You are flying a C182, landing on runway 22. The ATIS lists the winds as 240 at 10. The windsock is not visible. [...] That is not a lot of wind, and it's certainly not a lot of crosswind (get out the whiz wheel). The result that you were experiencing has to be from some other cause... perhaps ATIS was wrong? So... what I'd suggest is to pay attention to what the plane *is* doing rather than the theory of what it should be doing based on ATIS. Neil OK... However, it does sound like the consensus from the group is that aileron does nothing to correct drift once the plane has touched down... --Dan Saying ailerons do "nothing" to correct drift after touchdown is probably an oversimplification. If you land in a banked condition, the ailerons can help you maintain that condition. Also, even if you've got all of the wheels on the ground, correct aileron input will reduce the aircraft's tendency to raise the upwind wing. To a smaller extent, aileron deflection after touchdown will result in *some* bank angle, because the left and right gear will have different loading. This is particularly true at higher speeds, such as right after touchdown. KB |
#38
"Newps" wrote in message . .. Matt Whiting wrote: You'll never find that as it isn't true. It absolutely is true. Wind velocity drops dramatically as it approaches a surface. I better get my digital handheld windmeter recalibrated becxause at 4 feet, the top of the wing on my Bo and six feet, the top of the wing on a typical Cessna the wind is the same. I'm sure Whiting will come back that there's 0.05 MPH difference and that difference should be taken into account. |
#39
"Dan" wrote in message oups.com... On May 20, 6:34 am, john smith wrote: Dan wrote: I am working on a checkout in this C182 after about 400 hours in Pipers. Compared to what I am used to, the Cessna ground handling (especially after touchdown) seems very squirrley. I've had the same experience with the couple hours I have in 152s and 172s as well. Pipers will always feel much more "sure footed" compared to Cessnas, it's all in the landing gear. Walk up to both aircraft when they are untied and try rocking the wings. Big difference. The narrow stance and spring steel landing gear is a completely different ballgame. The Piper will feel more agile on a nice paved runway, but it's hard to beat the ride of a Cessna when the surface starts getting rough. Just boils down to personal preference and where you fly most I guess. |
#40
Matt Barrow wrote:
"Newps" wrote in message . .. Matt Whiting wrote: You'll never find that as it isn't true. It absolutely is true. Wind velocity drops dramatically as it approaches a surface. I better get my digital handheld windmeter recalibrated becxause at 4 feet, the top of the wing on my Bo and six feet, the top of the wing on a typical Cessna the wind is the same. I'm sure Whiting will come back that there's 0.05 MPH difference and that difference should be taken into account. Plonk. |
| Thread Tools | |
| Display Modes | |
| directional gyro inlet filter | dlevy | Owning | 2 | October 9th 06 04:00 PM |
| Is every touchdown a stall? | Mxsmanic | Piloting | 84 | October 4th 06 06:16 PM |
| Directional Traffic System | Rich | Products | 3 | October 10th 05 11:04 AM |
| Shipping damage to directional gyro? | Marv | Home Built | 2 | April 20th 05 02:34 PM |
| FA:Directional Gyro 4000C-1 Autopilot Mitchell | Joel Stolarski | Aviation Marketplace | 0 | July 18th 04 07:43 AM |
