#31
Tim Hickey wrote:
I can tell no difference between running 100LL and Mogas. I could tell a big difference with my 182. Back then my cost to fill up was about 50% of the prevailing avgas price and that was a very noticeable difference! :-) Matt |
#32
![]() "Matt Whiting" wrote in message ... Tim Hickey wrote: I can tell no difference between running 100LL and Mogas. I could tell a big difference with my 182. Back then my cost to fill up was about 50% of the prevailing avgas price and that was a very noticeable difference! :-) Besides the plane being heavier (more money in the wallet g) could you tell if the mixture was different, if you ever ran one tank mogas and one with 100LL? -- Jim in NC |
#33
Morgans wrote:
"Matt Whiting" wrote in message ... Tim Hickey wrote: I can tell no difference between running 100LL and Mogas. I could tell a big difference with my 182. Back then my cost to fill up was about 50% of the prevailing avgas price and that was a very noticeable difference! :-) Besides the plane being heavier (more money in the wallet g) could you tell if the mixture was different, if you ever ran one tank mogas and one with 100LL? Never tried that. We typically ran something close to a 50/50 mogas/100LL mix most of the time. We always filled with mogas at the home drome, but we filled with 100LL at other airports. Since both my partner and me flew mostly cross country flights, nearly every other top-off was with 100LL. The airplane flew great on this mixture up to as high as 13,000 feet. Never had a hiccup of any sort related to fuel. Matt |
#34
#35
I sure could in my Continental A-65 Champ. The engine seemed sluggish with mogas. It didn't seem to have as much power. I know you probably realize this, but your observation makes no sense. There is no difference in "power" between avgas and mogas. If there were, the FAA would never have approved mogas as an aviation fuel in *any* aircraft. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
#36
![]() "Jay Honeck" wrote I know you probably realize this, but your observation makes no sense. There is no difference in "power" between avgas and mogas. Actually, there are slightly more BTU's in a gallon of mogas than in a gallon of avgas. If an engine was to have its fixed advanced spark too far forward, the lower octane mogas could produce less power. That is the only way I could think of, other than a high compression engine that needed the higher octane to keep from knocking. -- Jim in NC |
#37
No have mogas STC for said Arrow. Ergo, I must burn blue stuff :-)
-- Jack Allison PP-ASEL-Instrument Airplane "To become a Jedi knight, you must master a single force. To become a private pilot you must strive to master four of them" - Rod Machado (Remove the obvious from address to reply via e-mail) |
#38
Jay Honeck wrote:
I can tell no difference between running 100LL and Mogas. I sure could in my Continental A-65 Champ. The engine seemed sluggish with mogas. It didn't seem to have as much power. I know you probably realize this, but your observation makes no sense. There is no difference in "power" between avgas and mogas. If there were, the FAA would never have approved mogas as an aviation fuel in *any* aircraft. It is amazing what the mind can do once it decides that something is true. Look at all of the drug test results on the large sheet you now get with prescription drugs. Many show the results of both the placebo and the drug during the studies. I'm always amazed at how much the placebo "helps" as compared to the real drug. People who think they are taking the drug get better also! If you think mogas will reduce your power, then your mind will make it happen. :-) Matt |
#39
Morgans wrote:
"Jay Honeck" wrote I know you probably realize this, but your observation makes no sense. There is no difference in "power" between avgas and mogas. Actually, there are slightly more BTU's in a gallon of mogas than in a gallon of avgas. If an engine was to have its fixed advanced spark too far forward, the lower octane mogas could produce less power. How so? Matt |
#40
![]() "Matt Whiting" wrote How so? Whem I was much younger, an all cars had points and condensers, I would do my own tune-ups. Sometimes the timing would need to be adjusted. How to do it, if you did not have a timing light handy? I would loosen the distributor bolt, until it was tight enough to move by hand, but not so loose that it would not vibrate around. After that, I would get the engine warmed up, and take it out on the road, and punch it. It was not so obvious if the timing was retarded a bit, until it was really retarded. It was _quite_ obvious when it was too far advanced, as would not have much power, and would knock like crazy. That a good enough answer? -- Jim in NC |
Fuel Prices For The July Pilgrimage | RST Engineering | Piloting | 46 | June 15th 07 10:45 PM |
Fuel prices | Paul kgyy | Owning | 14 | October 19th 05 10:55 PM |
Fuel Prices | Ross Richardson | Owning | 60 | September 30th 05 02:06 AM |
Fuel Prices | ~R | Rotorcraft | 0 | September 10th 05 03:56 PM |
Fuel Prices | S Green | Piloting | 0 | May 9th 04 09:47 PM |
