#31
BlackBeard wrote:
On Jun 14, 4:28 am, Vince wrote: BlackBeard wrote: On Jun 13, 7:55 pm, Vince wrote: don't worry these china dolls will be kept very far from any real combat. Vince Please clarify "china doll." As we use the term it applies to the fragility or lack of survivability of the platform. Are you now insinuating you know anything about it's combat survivability/susceptibility? Just wondering, because I know that most details of S/S for this platform are classified. And I don't remember you being present during the seven years I was involved with testing those specific systems. BB It will be kept far from anything that might scratch its paint this turkey is a political airplane. It has no clear "combat" mission in Iraq The problems of the V-22 are in its fundamental design. It uses heavy lift horsepower at ultra heavy cost to pick up medium lift cargo which must also fit in its small cabin through a rear door. The entire aft opens up similar to the C-130. The door doesn't increase the size of the cabin... IIRC they need a custom vehicle designed to pull any heavy equipment the Marines might try to use because the cabin is so small.. Is it really only 68 inches wide, and 66.23 inches high? That certainly counts as a small cabin.. Heck, two fully equipped Marines are going to have some trouble getting through side by side at the same time... (Equipped with MGs, ATGW, one shot AT weapons etc... |
#32
BlackBeard wrote:
On Jun 14, 10:43 pm, Rob Arndt wrote: Even stray fire that misses the troops or pilots, but hits a critical flight system will probably send the Osprey right into the ground. And this is different from any other aircraft how? Transitional flight in a combat zone is gonna be a bitch anyway, As in any troop carrying helicopter... but since Iraq is so large, just the regular flight in transit to the target area or base will expose the rotorcraft to small arms and RPG fire at low altitude. Why fly low, it has a higher ceiling than the helo it is meant to replace, and has more counter-measures and survivability systems than those helos. So it has a better chance of surviving if hit. If it is flying low, compare the chances of hitting something going by at 170 knots versus 240+ knots with an RPG. Go ahead and stand off the highway. Try to hit a VW beetle going by at the speed limit with a baseball. Then try that with a speeding Lexus going about 80. You don't get to practice either, they pass once. The time to hit it will be when it is hovering. Either landing or lifting off prior to forward transition.. Or when carrying a slung load... A helicopter can get forward motion almost as soon as it leaves the ground. How high does the V-22 have to be before entering transition? And conventional helis can just about land still travelling forward.. Can teh V-22? |
#33
BlackBeard wrote:
On Jun 14, 4:28 am, Vince wrote: BlackBeard wrote: On Jun 13, 7:55 pm, Vince wrote: don't worry these china dolls will be kept very far from any real combat. Vince Please clarify "china doll." As we use the term it applies to the fragility or lack of survivability of the platform. Are you now insinuating you know anything about it's combat survivability/susceptibility? Just wondering, because I know that most details of S/S for this platform are classified. And I don't remember you being present during the seven years I was involved with testing those specific systems. BB It will be kept far from anything that might scratch its paint this turkey is a political airplane. It has no clear "combat" mission in Iraq The problems of the V-22 are in its fundamental design. It uses heavy lift horsepower at ultra heavy cost to pick up medium lift cargo which must also fit in its small cabin through a rear door. The entire aft opens up similar to the C-130. BB you don't have to stoop to enter a C-130 the small cabin is what makes the rear door entry such a problem "The V-22 cabin comes with many constraints, Burkett explained in a presentation to an industry conference. Not only is the space limited, but whatever cargo is loaded in the aircraft must leave enough room for at least three passengers and for crews to enter and exit unencumbered. Without any cargo, the Osprey can hold 24 passengers. The Marines specified that the EFSS — including the mortar, the prime mover, a load of ammunition and a small crew — must be able to travel 110 nautical miles in the V-22. The weight of any vehicle to be flown on a V-22 cannot exceed 2,450 pounds per axle. By comparison, a Humvee weighs 4,500 pounds in the front axle and 6,500 pounds in the rear axle" http://www.nationaldefensemagazine.o...reys_Cargo.htm Vince |
#34
BlackBeard wrote:
On Jun 14, 10:43 pm, Rob Arndt wrote: Even stray fire that misses the troops or pilots, but hits a critical flight system will probably send the Osprey right into the ground. And this is different from any other aircraft how? Transitional flight in a combat zone is gonna be a bitch anyway, As in any troop carrying helicopter... but since Iraq is so large, just the regular flight in transit to the target area or base will expose the rotorcraft to small arms and RPG fire at low altitude. Why fly low, it has a higher ceiling than the helo it is meant to replace, and has more counter-measures and survivability systems than those helos. So it has a better chance of surviving if hit. If it is flying low, compare the chances of hitting something going by at 170 knots versus 240+ knots with an RPG. Go ahead and stand off the highway. Try to hit a VW beetle going by at the speed limit with a baseball. Then try that with a speeding Lexus going about 80. You don't get to practice either, they pass once. OFCS Im a klutz and Ive hit skeet doubles. The angular velocity of swinging the shotgun is far greater than hitting an osprey at 200 meters 240 knots is about 120 m/sec 2 second flight time The difference between 170 and 240 knots is trivial Vince |
#35
Kerryn Offord wrote:
BlackBeard wrote: On Jun 14, 4:28 am, Vince wrote: BlackBeard wrote: On Jun 13, 7:55 pm, Vince wrote: don't worry these china dolls will be kept very far from any real combat. Vince Please clarify "china doll." As we use the term it applies to the fragility or lack of survivability of the platform. Are you now insinuating you know anything about it's combat survivability/susceptibility? Just wondering, because I know that most details of S/S for this platform are classified. And I don't remember you being present during the seven years I was involved with testing those specific systems. BB It will be kept far from anything that might scratch its paint this turkey is a political airplane. It has no clear "combat" mission in Iraq The problems of the V-22 are in its fundamental design. It uses heavy lift horsepower at ultra heavy cost to pick up medium lift cargo which must also fit in its small cabin through a rear door. The entire aft opens up similar to the C-130. The door doesn't increase the size of the cabin... IIRC they need a custom vehicle designed to pull any heavy equipment the Marines might try to use because the cabin is so small.. Is it really only 68 inches wide, and 66.23 inches high? That certainly counts as a small cabin.. Heck, two fully equipped Marines are going to have some trouble getting through side by side at the same time... (Equipped with MGs, ATGW, one shot AT weapons etc... they have noticed that Vince |
#36
BlackBeard wrote: On Jun 14, 10:43 pm, Rob Arndt wrote: Even stray fire that misses the troops or pilots, but hits a critical flight system will probably send the Osprey right into the ground. And this is different from any other aircraft how? Transitional flight in a combat zone is gonna be a bitch anyway, As in any troop carrying helicopter... but since Iraq is so large, just the regular flight in transit to the target area or base will expose the rotorcraft to small arms and RPG fire at low altitude. Why fly low, it has a higher ceiling than the helo it is meant to replace, and has more counter-measures and survivability systems than those helos. So it has a better chance of surviving if hit. If it is flying low, compare the chances of hitting something going by at 170 knots versus 240+ knots with an RPG. Go ahead and stand off the highway. Try to hit a VW beetle going by at the speed limit with a baseball. Then try that with a speeding Lexus going about 80. You don't get to practice either, they pass once. The time to hit it will be when it is hovering. Either landing or lifting off prior to forward transition.. Or when carrying a slung load... A helicopter can get forward motion almost as soon as it leaves the ground. How high does the V-22 have to be before entering transition? And conventional helis can just about land still travelling forward.. Can teh V-22? The handling of the V 22 would be even marginal except that it is massively overpowered and overweight for the cargo load it can carry they use brute horsepower to overcome the inefficiency of the tilt rotor it lifts about half the load a ch 53 with 12000 hp lifts Vince |
#37
On Jun 14, 11:55?pm, BlackBeard wrote:
On Jun 14, 10:43 pm, Rob Arndt wrote: Even stray fire that misses the troops or pilots, but hits a critical flight system will probably send the Osprey right into the ground. And this is different from any other aircraft how? First of all it's a rotorcraft and it IS different b/c it is a complicated transitional flight machine. A main hit to its rotors and it won't be auto-rotating to safety but burning in a fiery wreckage of debris. Transitional flight in a combat zone is gonna be a bitch anyway, As in any troop carrying helicopter... Helos don't have to worry about vunerable transitional flight for t/o nor landings. Osprey has to slow down for transitional landings then descend vertically down. Helos can come in fast, slow, and still have some foward momentum when landing. Helos can t/o faster w/o need for the complicated transitioning part and t/o forward. Osprey has to go through the transitioning routine every single time and might as well have a target painted on it as it climbs and descends vertically before the rotors swing forward, horizontally. Not so with any helo. but since Iraq is so large, just the regular flight in transit to the target area or base will expose the rotorcraft to small arms and RPG fire at low altitude. Why fly low, it has a higher ceiling than the helo it is meant to replace, and has more counter-measures and survivability systems than those helos. So it has a better chance of surviving if hit. If it is flying low, compare the chances of hitting something going by at 170 knots versus 240+ knots with an RPG. Go ahead and stand off the highway. Try to hit a VW beetle going by at the speed limit with a baseball. Then try that with a speeding Lexus going about 80. You don't get to practice either, they pass once. It NEEDS more countermeasures and suvival aids as this is an exposed twin-engine transitional rotorcraft. Helos have their engines buried and are covered by armor. Osprey has a 50 ft wingspan with exposed transitional engines in nacelles at their tips. One does not need to take out the engine to kill it- just blow a wing off and the engine is gone too- end of flight. As for speed, the Osprey has to slow for the transition and even briefly hover in the process which is bad news for the 24 troops being transported in that sitting duck. Also, in forward flight the rotor diameter is 38 ft, a tempting target for an RPG as it slows to come in and land. Helos have none of these problems and have some measure of armor protection with the engines. BB I guess everybody has some mountain to climb. It's just fate whether you live in Kansas or Tibet... Rob |
#38
Kerryn Offord wrote: BlackBeard wrote: A helicopter can get forward motion almost as soon as it leaves the ground. How high does the V-22 have to be before entering transition? And conventional helis can just about land still travelling forward.. Can teh V-22? Haven't been around V-22 flight ops, but the XV-15 used to fly around Moffett Field near my old office, and it certainly could land while still traveling forward, just not with the nacelle's full-forward. It could also move forward before lifting off the runway; it didn't have to reach some arbitrary altitude before it could begin to transition to forward flight. |
#39
![]() Vince wrote: they have noticed that What they should have noticed is how that side-by-side rotor layout causes sand and dust to rise around the fuselage during landing, blinding the pilot. That problem should have been noticed back in the XV-15 days: http://en.wikipedia.org/wiki/Bell_XV-15 Pat |
#40
![]() Vince wrote: The handling of the V 22 would be even marginal except that it is massively overpowered and overweight for the cargo load it can carry they use brute horsepower to overcome the inefficiency of the tilt rotor it lifts about half the load a ch 53 with 12000 hp lifts Could be worse...could be this: http://www.vstol.org/wheel/VSTOLWheel/KamovKa-22.htm That didn't look right, and it didn't fly right either. Pat |
Desktop Wallpaper - "A covey of Osprey". | T. & D. Gregor, Sr. | Simulators | 0 | June 1st 07 08:41 PM |
"Marine Corps Grounds V-22 Osprey Aircraft" | Mike[_1_] | Naval Aviation | 0 | February 18th 07 03:40 PM |
V-22 Osprey "ground effect" question | Robert | Naval Aviation | 6 | January 2nd 07 03:44 PM |
OSPREY OPS - "ZIMG_1123.jpg" 123.1 KBytes | Stas | Aviation Photos | 0 | November 9th 06 07:33 PM |
OSPREY OPS - "ZIMG_1125.jpg" 163.7 KBytes | [email protected] | Aviation Photos | 0 | November 8th 06 03:16 PM |
