Air Compressor Horsepower/Wattage/Amperage
Old June 21st 07, 06:49 PM posted to rec.aviation.homebuilt,rec.aviation.owning
Default Air Compressor Horsepower/Wattage/Amperage
On Jun 21, 10:40 am, "Private" wrote:
ps.com...
On Jun 20, 12:31 pm, "Private" wrote:
roups.com...
I built my own
compressor years ago using an old truck compressor, and drove it with
a 1-horse 3450 RPM jet-pump motor.
Dan
How did you supply oil pressure to lube the crankshaft? or did this
compressor have its own closed sump and pump or splash lube system?
TIA
It was a base-mounted belt-driven compressor that was supplied
oil from the engine's oil system. I made a steel base plate to close
it off, drilled the side of the case and tapped it for a 1/2" 90° pipe
elbow for a filler/level check plug, and drilled and tapped the con
rod caps for 1/8" pipe street ells that acted as scoops to grab the
oil from the sump and jam it into the bearings. The main bearings were
ball bearings and get plenty of splash to keep them happy. The thing
has run happily for probably 100 hours over the last 20 years and
shows no sign of distress.
Dan
I have had good luck and extensive service from these compressors, but
always by mounting them on engines where I was able to connect them to the
engine's pressure oil and coolant systems. I used an electric clutch pulley
so they did not need to run continuously, IMHO they are very good
compressors. The current high cost of fuel makes it an expensive way to
obtain pressure air in any quantity unless the engine will be operated
anyway.
Happy landings.
This was an old aircooled unit, circa 1950, that showed up
in some returned cores. Instead of the usual unloader pistons that
lifted the intakes, it has intake ports in the cylinder wall that the
piston uncovered near the bottom of the stroke. The unloaders are
separate small valves in the head similar to small-engine valves,
opened by a lever operated by metal diaphragm that received the air
signal from the governor.
The whole design of these old compressors resembled an
outboard motor powerhead, and in researching the origins of Bendix-
Westinghouse compressors I discovered that the first units were
converted Evinrudes. So much for the similarities.
By the way: of the thousands of compressors we rebuilt, I
would say that at least half of the cores had nothing wrong with them
except for worn unloader piston O-rings, damage caused by a worn-out
$20 governor. New O-rings were a few cents. A shot governor doesn't
apply the unloading pressure suddenly, as it should, and the intakes
bang the lifting pins and work the pistons up and down rapidly and
wear the o-rings out. Leaky o-rings cause a pressure drop in the
governor when it cuts the compressor out, it thinks the tank pressure
has dropped, and it cuts in again so that the compressor is on/off/on/
off rapidly and the driver or mechanic thinks it's shot.
About a fifth of cores were those off Detroit Diesels and had
the phenolic drove coupling that would shear internally off its steel
hub but remain attached to the hub and look perfectly normal. It
couldn't drive the compressor, a compressor that had nothing wrong
with it.
And the rest had been allowed to eat dust through old/missing/
cheap air filters, and dust destroys a compressor faster than it will
an engine. It sticks to the thin film of oil on the cylinder wall
instead of being vaporized and blown out, and the cylinder and rings
eat each other.
Maybe you guys aren't interested in all this, but the point is
that most of our troubles with machinery are our own fault, either
through ignorance or just being plain cheap.
Dan
  #32
Old June 21st 07, 09:30 PM posted to rec.aviation.homebuilt,rec.aviation.owning
Dan : Which models of truck compressors would work good for a
homemade,
engine driven unit? I need to have the capability of developing about
25-30 cfm at
70+ psig for s shop project. Tankage is a 650 gallon propane tank and
I don't mind
ganging two compressors together and having split cut-in/cut-out
pressures.
Craig
  #33
Old June 21st 07, 10:27 PM posted to rec.aviation.homebuilt,rec.aviation.owning
Maxwell
ps.com...
homemade,
25-30 cfm at
I don't mind
pressures.
I don't know what it would cost to buy and fit a truck compressor, but have
you seen this?
http://www.wttool.com/product-exec/p...ompressor_Pump
I built a 2 hp from a Mopar A/C compressor that I used for several years.
But I think if I had to do it all over, I might just buy a pump from China.
When my 5 hp Saylor Beal failed a few months ago, I bought a complete 10 hp
that I believe uses this same compressor. It makes a lot of air even at 175
psi. Almost 35 CFM I think.
  #34
Old June 22nd 07, 03:06 PM posted to rec.aviation.homebuilt,rec.aviation.owning
homemade,
25-30 cfm at
I don't mind
pressures.
Craig
None of the truck compressors will keep up with that. I've
been out of the business for 15 years now, but I don't think there's
anything bigger than the 24 CFM V-4 TF1000 made by Bendix or the 24
CFM Cummins twin. And it would cost so much that you could buy a
couple of big industrial compressors for the same money. The core
charges alone on these things were on the order of $750 15 years ago.
One of our shop compressors was an old deVilbiss originally
installed in a lighthouse to drive the foghorn. Around 50 CFM at 70
psi. I reset the thing to run at 150 psi to keep the bead blasters
going, and it had been running for five or six years like that when I
left. It wasn't supposed to be able to handle that load, since the con
rods and bearings were so slender, but it did. It had been bought at
auction by guys in the head office who didn't know any better and just
wanted to get something cheap. I had hoped to blow it up to teach them
to buy the right stuff in the first place, but the old thing wouldn't
cooperate.
Dan
  #35
Old June 23rd 07, 11:07 PM posted to rec.aviation.homebuilt,rec.aviation.owning
Morgans[_2_]
"RST Engineering" wrote
But then you multiplied that times two for "starting" wattage for a couple
of seconds to give 1725 watts under start and then times three for
starting under some volume of air left in the compressor reservoir or
about 2600 watts.
Most air compressors have a valve that lets off the air pressure in the line
between the pump and the tank, when they shut off.
You can tell if it has this feature, by seeing a little air line going to
the pressure on/off switch.
You may not need to multiply so big for starting with air in the tank.
  #36
Old June 24th 07, 12:20 PM posted to rec.aviation.homebuilt,rec.aviation.owning
Ron Rosenfeld
On Mon, 18 Jun 2007 13:49:59 -0700, "RST Engineering"
I thought I had this compressor power thing down to a pretty good science
until they started screwing around with "rated watts" and "peak power" and
all that crap that makes their compressor look really good until you go to
use it.
Back when we were using "real" horsepower I used a figure of 750 (to make it
easy to calculate, I believe 746 is the actual number) watts per horsepower
and an efficiency factor of 85% so that a one horse motor would take 860
watts to do the actual work.
of seconds to give 1725 watts under start and then times three for starting
under some volume of air left in the compressor reservoir or about 2600
watts.
That presses my 2200 watt continuous duty (2800 watts peak) fairly close to
the load limit, but certainly gives a margin for error that seems
reasonable.
Before I tell elebendy bazillion Kitplanes readers that the Harbor Freight
Subaru 2200 watt generator will drive the Sears 1 horse compressor (and even
worse, buy the Sears compressor only to not have it work), will somebody
please do a reality check on me for horsepower/watts for this lashup.
(Note ... convert watts to amperes by dividing watts by 120 volts).
860w=7a 1725w=14a 2600w=21a
Sears and Harbor Freight are damned near clueless about this sort of stuff.
If anybody has a source I can reference for running/starting/starting under
load for air compressors it would be well received.
I'd LIKE to buy a 3/4 horse compressor but they go from the kiddie's 1/4
horse toy straight to one horse with darned little in between.
Jim,
Living off-grid, and generating most of my own power from renewables, I am
somewhat familiar with your issue. Although your approach may make
theoretical sense, in the real world (as you found out) it frequently
doesn't work.
The startup surge for an electric motor is given by a parameter called
"locked rotor amps" (means pretty much what it says). This can either be
measured (with a clamp-on ammeter), or derived from a letter on the
nameplate of the actual motor multiplied by the running amps.
A compressor is one of the more difficult devices to start. Without
specific data, I would figure starting amps to be at least five times the
nameplate amperage rating. Fugedabout trying to convert nameplate HP to
startup surge. It might be less, or not.
So far as your generator is concerned, it is likely that the ratings assume
a power factor of 1. But an induction motor, such as is in your
compressor, will have a power factor considerably less than 1. This
further increases the amount of "real power" the generator must supply.
And may also explain why the nameplate amperage rating seems higher than
what you predict by using HP and an assumed efficiency.
I happen to have a Sears 1HP compressor (1.5HP Peak). Mine has a nameplate
rating of 10.5A @ 120V. I could not see/locate the nameplate on the motor
itself, so I figured a 52.5A startup surge (5X). My inverter has a 78A
peak capacity (46A continuous) so I figured things would work -- and they
have.
Your 2800W peak generator translates to 23.3A at 120VAC. If you have the
same Sears compressor as I do, I'm not surprised that the generator will
have a problem starting it.
Another issue that comes up with compressors has to do with flat spots on
the rotor as they age. This causes them to draw the locked rotor amp
startup current for a longer period of time when new. This can also cause
an otherwise adequately sized system to "blow" on startup, occasionally.
--ron
  #37
Old June 26th 07, 05:51 PM posted to rec.aviation.homebuilt,rec.aviation.owning
On Jun 24, 5:20 am, Ron Rosenfeld wrote:
Ron, what peak starting current should I expect on a single-phase,
240V, 3/4h.p., running current=7.8A motor used to lift my hangar door?
I want to rig up a genny to lift the door during a power failure. The
gear train on the door is rigged so that all of the cables are slack
(i.e. only motor inertial) when the motor starts.
  #38
Old June 27th 07, 02:56 AM posted to rec.aviation.homebuilt,rec.aviation.owning
Ron Rosenfeld
mgm17160, I really don't know. I'd be surprised if it were as much as
double the running amps, but there's no good way of telling without
measuring.
With no measurement, I would size the generator to be able to handle a
surge equal to the Locked Rotor Amps as calculated by the nameplate code
rating on the motor. Or just try a genny that can handle a surge of
15A/240V.
A problem with small, inexpensive, gasoline fueled generators is that,
unless you are religious about exercising them, they usually won't start
when you need them. And, unless you have a mission-critical situation,
it's overkill to put in something that you can set and forget.
I, too, have a door that is not amenable to any kind of mechanical backup.
I happen to have an extra 120V inverter I could hook up -- but the cost of
batteries and a step-up transformer to set up the system is excessive,
especially given that I've only been stymied by a power outage at the
hangar once or twice in the past seven years.
--ron
  #39
Old June 27th 07, 06:05 AM posted to rec.aviation.homebuilt,rec.aviation.owning
Morgans[_2_]
when you need them.
An exception to that rule is a Honda generator. I'm not a foreign car guy,
or anything like that; quite the opposite. My dad had one that would sit
for a couple of years, and it would start on the first or second pull, with
fresh gas in the tank.
It is amazing how many other uses come up, once you have a generator sitting
around.
  #40
Old June 27th 07, 06:25 AM posted to rec.aviation.homebuilt,rec.aviation.owning
Roger (K8RI)
On Wed, 27 Jun 2007 01:05:26 -0400, "Morgans"
when you need them.
around.
Mine is 9500 watts continuous. It doesn't even have the option of a
pull starter. I don't think I could pull it even if it did. I keep
the tank full. When I shut it down I turn the gas off and let it dry
out the carb. It's on wheels, but it'd take a truck to haul it so it
could be called portable. OTOH it'd take three and preferably four men
to put it in the truck. If it were in the shop I could do that with
an engine hoist. I fire it up about every other month and let it run
for about 10 minutes. In the winter I have to keep a small heat lamp
on the battery. It'll run about 10 to 12 hours powering the whole
house sans air conditioner (except for the little spare one stuck in
the bedroom window) on 10 gallons. I had a little 4000 watt Coleman
that used twice as much gas, but it was kinda portable and made a
whole lot more noise.
I purchased it new, *after* Y2K when there were lots of them available
at half price and less. In the last 6 1/2 years I have well over
100 hours on it powering the house. Lots of power outages due to poor
line maintenance and we are about 2 miles from the city limits and
just over a mile from the substation.
As for other uses, with help I some times pull it out of the generator
shed and use it to power my 180 amp MIG welder. It's been a while but
IIRC the engine doesn't even change pitch when welding.
Air Compressor Horsepower/Wattage/Amperage RST Engineering Owning 32 June 30th 07 12:47 AM
more horsepower T-Bone Piloting 11 March 20th 06 10:56 PM
Lycoming Horsepower Calculation? Mark Doble Home Built 1 June 20th 05 10:46 PM
Thermals and Horsepower Ken Kochanski (KK) Soaring 14 January 9th 05 05:50 PM
Horsepower Andre Home Built 3 July 18th 03 10:50 AM
