#31
John,
The second answer is, the instructor was referring to controlling the aircraft in flight. In a taildragger, you lead a turn with rudder before adding the aileron. You still don't get Bob's point, I'm afraid. The point is: How would the air and the plane "know" that it's a taildragger, once the plane is flying? And thusly, how would the plane "know" to behave differently in the air because it has a different wheel (!) configuration? -- Thomas Borchert (EDDH) |
#32
![]() The first answer is, in a taildragger your don't use the brakes to turn. If you do use the brakes, you are going too fast. If your instructor didn't teach you how to do a one-wingspan turn in a taildragger, your education is not complete. One of the great things about a taildragger is the ability to turn in tight spaces. I'd go get some tailwheel time from a real taildragger instructor. The second answer is, the instructor was referring to controlling the aircraft in flight. In a taildragger, you lead a turn with rudder before adding the aileron. I'll not argue with you for the same reason I don't mudwrestle with pigs. However, just for our amusement why don't you give us the aerodynamics of the differences in inflight turns between taildraggers and trainingwheel aircraft. Jim |
#33
Thomas Borchert wrote: You still don't get Bob's point, I'm afraid. The point is: How would the air and the plane "know" that it's a taildragger, once the plane is flying? And thusly, how would the plane "know" to behave differently in the air because it has a different wheel (!) configuration? It's the way the airplanes were designed then and now. Alot of it has to do with adverse yaw and how the ailerons were hinged then compared to how they are hinged now. Find an old Champ and see how much of the forward portion of the aileron extends above/below the wing surface when the aileron is deflected down on the upgoing wing/down on the down going wing. |
#34
I don't think so. Find a C-170 and set it next to a C-172 and compare the
two. Besides, adverse yaw is not WHEN you apply rudder to compensate for it but HOW MUCH. Again, get yourself some decent taildragger instruction. Jim "john smith" wrote in message ... In article , Thomas Borchert wrote: You still don't get Bob's point, I'm afraid. The point is: How would the air and the plane "know" that it's a taildragger, once the plane is flying? And thusly, how would the plane "know" to behave differently in the air because it has a different wheel (!) configuration? It's the way the airplanes were designed then and now. Alot of it has to do with adverse yaw and how the ailerons were hinged then compared to how they are hinged now. Find an old Champ and see how much of the forward portion of the aileron extends above/below the wing surface when the aileron is deflected down on the upgoing wing/down on the down going wing. |
#35
![]() The second answer is, the instructor was referring to controlling the aircraft in flight. In a taildragger, you lead a turn with rudder before adding the aileron. Really, so this applies with a 180 versus a 182? |
#36
aircraft in flight. In a taildragger, you lead a turn with rudder before adding the aileron. Newps wrote: Really, so this applies with a 180 versus a 182? I don't know. I learned in a taildragger, I always lead with rudder regardless of what I am flying. |
#37
![]() "RST Engineering" wrote in message ... I don't think so. Find a C-170 and set it next to a C-172 and compare the two. Besides, adverse yaw is not WHEN you apply rudder to compensate for it but HOW MUCH. Again, get yourself some decent taildragger instruction. Are there any certified planes (or even experimental) that need zero rudder input to do a coordinated turn? -- Jim in NC |
#38
Rudder pedalless Ercouples come quickly to mind.
Jim -- "Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, with chocolate in one hand and wine in the other, loudly proclaiming 'WOO HOO What a Ride!'" --Unknown "Morgans" wrote in message ... Are there any certified planes (or even experimental) that need zero rudder input to do a coordinated turn? -- Jim in NC |
#39
Your passengers must enjoy the barf-inducing yaw that this provides to them.
I learned in a taildragger too, and I've rarely come across such puppycock. Jim -- "Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, with chocolate in one hand and wine in the other, loudly proclaiming 'WOO HOO What a Ride!'" --Unknown "john smith" wrote in message ... I don't know. I learned in a taildragger, I always lead with rudder regardless of what I am flying. |
#40
"RST Engineering" wrote: Your passengers must enjoy the barf-inducing yaw that this provides to them. I learned in a taildragger too, and I've rarely come across such puppycock. Jim Okay, how about this answer... I apply whatever control inputs are required to keep the ball centered throughout the turn. I don't think about it, I just do it. :-) |
Eating in New Jersey | G.R. Patterson III | Piloting | 15 | September 30th 04 01:58 PM |
Getting rid of turbines. (grin) | ArtKramr | Military Aviation | 15 | December 6th 03 05:25 AM |
