#31
![]() wrote in message oups.com... Of course not. But unless you had a reasonable airspeed so that lots of 'up' was available in the airplane's kinetic energy, it would be mostly a climbing steeply banked turn, wouldn't it? And having an idea of what that turn diameter would be would be a useful hint when you either saw canyon walls closing in on you, or you were making a turn over the East River in NYC, wouldn't it? The walls could be concrete with windows in them. So I think the lesson might be if you're in a cruise configuration be sure there's nothing solid within a half mile in the direction you're turning, and pay attention to the wind direction. The other option is to be some kind of a macho hero, but airplanes should die of old age, not transitioned from something beautiful and aloft into a compressed mess containing bodies in a couple of seconds. A little trading of airspeed for altitude, and possibly back again, can make a lot more difference than you seems to believe. You can also make a huge difference without doing anything which might be regarded as acrobatic. Therefore, you are free to practice those non acrobatic maneuvers for proficiency--which will let you know what the airplane can safely accomplish, both turning into the wind and turning out of the wind. OTOH, like Jim, if my arse is on the line, I will do whatever appears necessary, acrobatic or not--especially in any circumstance where I am "dead anyway"! Peter |
#32
without a doubt a climbing turn, if you're going fast enough, is going
to tighten the turn. But how tight? Assume you're in a turn over the East River, and you're going to impact a builiding. Assume you're a good pilot and were distracted or whatever, and now you're within 500 feet of a wall. What then? Big pullup, bank, all of that? Will you be able to get 90 degrees around in 500 feet? We know of one case where whatever was done wasn't enough, and that was in VFR conditions, they had to have seen it coming. oups.com... Of course not. But unless you had a reasonable airspeed so that lots of 'up' was available in the airplane's kinetic energy, it would be mostly a climbing steeply banked turn, wouldn't it? And having an idea of what that turn diameter would be would be a useful hint when you either saw canyon walls closing in on you, or you were making a turn over the East River in NYC, wouldn't it? The walls could be concrete with windows in them. So I think the lesson might be if you're in a cruise configuration be sure there's nothing solid within a half mile in the direction you're turning, and pay attention to the wind direction. The other option is to be some kind of a macho hero, but airplanes should die of old age, not transitioned from something beautiful and aloft into a compressed mess containing bodies in a couple of seconds. A little trading of airspeed for altitude, and possibly back again, can make a lot more difference than you seems to believe. You can also make a huge difference without doing anything which might be regarded as acrobatic. Therefore, you are free to practice those non acrobatic maneuvers for proficiency--which will let you know what the airplane can safely accomplish, both turning into the wind and turning out of the wind. OTOH, like Jim, if my arse is on the line, I will do whatever appears necessary, acrobatic or not--especially in any circumstance where I am "dead anyway"! Peter- Hide quoted text - - Show quoted text - |
#33
![]() wrote in message oups.com... without a doubt a climbing turn, if you're going fast enough, is going to tighten the turn. But how tight? Assume you're in a turn over the East River, and you're going to impact a builiding. Assume you're a good pilot and were distracted or whatever, and now you're within 500 feet of a wall. What then? Big pullup, bank, all of that? Will you be able to get 90 degrees around in 500 feet? We know of one case where whatever was done wasn't enough, and that was in VFR conditions, they had to have seen it coming. A simple pull up would have been all that was needed, in that case. -- Jim in NC |
#34
It would be interesting for someone to run a simulation for that
airplane and track, to gain a sense of how much time the pilot and CFI would have had from the time the problem was obvious, and what they might have done about it. It might give some insight as to if they had the airspeed to climb fast enough. Did they have 2 seconds to react, or 15? On Jun 27, 1:14 am, "Morgans" wrote: wrote in message oups.com... without a doubt a climbing turn, if you're going fast enough, is going to tighten the turn. But how tight? Assume you're in a turn over the East River, and you're going to impact a builiding. Assume you're a good pilot and were distracted or whatever, and now you're within 500 feet of a wall. What then? Big pullup, bank, all of that? Will you be able to get 90 degrees around in 500 feet? We know of one case where whatever was done wasn't enough, and that was in VFR conditions, they had to have seen it coming. A simple pull up would have been all that was needed, in that case. -- Jim in NC |
#35
On 2007-06-24 07:51:51 -0700, "Dick" said:
After taking some rigorous Unusual Attitudes Training, now I can't do a smooth Lazy Eight to save my soul G (or comfort my wife). One item the course taught me was a Modified Wingover which allowed a blind canyon 180* turn within a wingspan. Entry at 30* pitch & 30* bank proceeding to 60* pitch & 60* bank at 90* point to entry. Then at 0 mph, the nose falls without rudder assist and ball is too the side. Yep. I can see how that would ruin your Lazy 8. Now you have a tendency to do Crazy 8s. My procedure for the Lazy 8: entry at 15/15* P&B, then up to 30/30* P&B at 90* to entry and down to 5-10 mph over stall using proper rudder control and centered ball. Unfortunately after I look left over the wing to line up with the entry point and initiate first pitch/bank, I'm then at the 90* point and still too fast..... My guess is you are overbanking without realizing it, maybe even trying to force it around. You might be entering it too fast, too. I enter at wings level and make very slow, smooth changes to pitch and bank. The Lazy 8 is not a chandelle or a wingover. It is a graceful, ballet-like maneuver that requires patience and fine, precise control. At no point should your pitch or bank be constant. So, I don't enter with a 15/15, because that is not a Lazy 8 to begin with -- it implies that you hold that pitch or bank at some point. AOPA has a good method for learning Lazy Eights that I use when teaching the maneuver. Practicing these steps will improve your Lazy Eights enormously. http://www.aopa.org/asf/publications...m?article=4147 -- Waddling Eagle World Famous Flight Instructor |
#37
On Wed, 27 Jun 2007 12:45:10 -0000, wrote in
.com: It might give some insight as to if they had the airspeed to climb fast enough. Did they have 2 seconds to react, or 15? It would also be good to know if the tops of the buildings were obscured in cloud or not, so they would have been aware that a pull-up could have cleared the building tops. |
#38
On 2007-06-24 19:35:43 -0700, Dudley Henriques said:
What I do with acro students having trouble with Lazy 8's is to have them concentrate on doing a good wingover first. This way, they can concentrate on the 90 degree reference point, the 45 degree point and the 135 degree point on one side only at a time. When you can consistantly perform good wingovers to one side, then the other, you should then put them together and do Lazy 8's. Basically, you are dealing with pitch and bank and what you have to do with varying control pressures with BOTH these parameters to achieve the desired result. Dudley, I am not sure I understand this as a teaching technique for a Lazy Eight. You get examiners who complain that people doing Lazy Eights are actually doing Wingovers instead of Lazy Eights. You see comments like this, for example, in Ken Medley's article on the AOPA web site: "Examiners complain that many applicants actually do wingovers when they think they are doing lazy eights. A wingover is a good, easy aerobatic maneuver, but it isn't a lazy eight. In lazy eights you fly the airplane throughout. In wingovers, you slip the airplane during the turnaround. For lazy eights, fly the airplane throughout the turns - no slipping - and be sure to allow for torque." -- Waddling Eagle World Famous Flight Instructor |
#39
![]() C J Campbell wrote: In wingovers, you slip the airplane during the turnaround. For lazy eights, fly the airplane throughout the turns - no slipping - and be sure to allow for torque." You are saying that a wingover is not coordinated, but it is. |
#40
![]() wrote It would be interesting for someone to run a simulation for that airplane and track, to gain a sense of how much time the pilot and CFI would have had from the time the problem was obvious, and what they might have done about it. It might give some insight as to if they had the airspeed to climb fast enough. Did they have 2 seconds to react, or 15? I remember seeing some radar tracks, and although I do not remember what the speed was, I thought that they were going way faster than needed, and that excess speed could have been partially responsible (among other factors, such as the wind, just naming one) for not being able to turn in a tight enough radius. If that is the case, and there was a speed reserve, they would have been able to do a zoom climb, and avoid the building. As to when they should have recognized the problem, I would guesstimate that they should have realized there was a problem, say, 2/3rds or 3/4ths of the way around the turn. How many seconds would it take to execute a 180? 30 or 40 seconds? If that is the case, then 3/4ths of the way around would be at worst 7.5 seconds. & seconds would have been enough time, to climb (or change the bank angle and fly past it) and avoid crashing. This all hinges on realizing that there was a severe problem, which it seems obvious they did not. All in all, it was a tragic incident, and it really does not matter to them what the mistake was. They are dead, and that is the end as far as they are concerned. -- Jim in NC |
Somebody Terrified of Compound Curves ---- Or Just Lazy | Larry Smith | Home Built | 8 | October 31st 03 02:40 PM |
"Lazy Dogs" | Mike Yared | Naval Aviation | 1 | August 15th 03 06:00 PM |
