On Jul 12, 9:58 am, James Sleeman wrote:
The potential for *exactly* this accident sequence had been identified by the ATC unit at that very airport in the 90s and instructions were given at the time that would have avoided it basically that ATC should only ever tell club/student pilots to "go around, say again, go around" which is the offical phrase and procedure for which students are trained. New ATC personell having joined the unit after this instruction was promulgated were not made aware of it. The instruction has subsequently been re-issued. Thanks for the excellent summary and commentary! When I began soloing, my instructor forbade me to engage in any low- altitude maneuvering on final approach (e.g. 360s for spacing, which the tower sometimes called for). He explained clearly that any such request from ATC should be met with "Unable, student pilot, going around", followed by a standard go-around. I think that's an excellent policy for students until they have extensive solo-landing experience. |
![]() When I began soloing, my instructor forbade me to engage in any low- altitude maneuvering on final approach (e.g. 360s for spacing, which the tower sometimes called for). He explained clearly that any such request from ATC should be met with "Unable, student pilot, going around", followed by a standard go-around. I think that's an excellent policy for students until they have extensive solo-landing experience. I would respectfully disagree with this line of reasoning from an instructor and would never recommend this or condone this procedure from any instructor within shouting distance of my voice :-) The entire purpose of teaching people to fly airplanes is to teach them to operate safely within a constantly changing dynamic. This means both the aerodynamic AND the ATC dynamic. Students learning to fly in a controlled traffic environment are not well served by instructors who encourage them to deny an ATC request as a routine procedure based on the fact that the pilot is a student. This should in no way be misconstrued into meaning that a student shouldn't take whatever action is necessary to maintain flight safety if contrary to an instruction from ATC. It does mean however that student pilots are better taught to function in the traffic environment as PILOTS rather than students right from the gitgo, as in any and all situations encountered in that environment they will have to act as pilots and not students. The only time a student should not follow an instruction from ATC is when that instruction over rides a flight safety issue that is immediately apparent to the student. In that case, an "unable to comply" followed by a brief transmission as to why is the protocol, but doing this should always be the abnormal situation not the norm! In the specific instance you have used as an example, there might very well be a valid reason known to the controller ONLY as to why a specific instruction was given at a specific moment in time. There could ALSO be a valid reason why a go around from a present position when the ATC request was made would be inadvisable due to traffic separation or an aircraft sequencing on a crossing runway. The reasons why something can be valid or invalid in the ATC environment are many and varied. The bottom line on this is that a student pilot should be trained to respond to any and all reasonable requests made by ATC when in the traffic pattern of a controlled field, NOT taught to change or deny an ATC request based on a student pilot status. If the student is dual, the instructor is PIC. If the student is solo, that student should know how to deal with any and all ATC requests and be functioning as a normal aircraft in the traffic environment. That responsibility is also the instructor's. Dudley Henriques Dudley Henriques |
On Jul 12, 2:38 pm, Dudley Henriques wrote:
I would respectfully disagree with this line of reasoning from an instructor and would never recommend this or condone this procedure from any instructor within shouting distance of my voice :-) The entire purpose of teaching people to fly airplanes is to teach them to operate safely within a constantly changing dynamic. This means both the aerodynamic AND the ATC dynamic. Students learning to fly in a controlled traffic environment are not well served by instructors who encourage them to deny an ATC request as I see your point. Thanks. I'll reconsider. |
On 2007-07-12 11:38:43 -0700, Dudley Henriques said:
When I began soloing, my instructor forbade me to engage in any low- altitude maneuvering on final approach (e.g. 360s for spacing, which the tower sometimes called for). He explained clearly that any such request from ATC should be met with "Unable, student pilot, going around", followed by a standard go-around. I think that's an excellent policy for students until they have extensive solo-landing experience. I would respectfully disagree with this line of reasoning from an instructor and would never recommend this or condone this procedure from any instructor within shouting distance of my voice :-) The entire purpose of teaching people to fly airplanes is to teach them to operate safely within a constantly changing dynamic. This means both the aerodynamic AND the ATC dynamic. Students learning to fly in a controlled traffic environment are not well served by instructors who encourage them to deny an ATC request as a routine procedure based on the fact that the pilot is a student. Besides, as Rod Machado so infamously pointed out, your credibility as a student pilot starts to wear a little thin when you are calling ATC from a 747. :-) -- Waddling Eagle World Famous Flight Instructor |
James,
I think what should be learned from this is that especially low-time students still circuit bashing have very set procedures they are following in thier minds, Only after bad instruction. -- Thomas Borchert (EDDH) |
okay he only had 15 hours of flying time and it was only his
second solo, but I was doing touch and go's and going around from about my third hour onwards. D. My instructor and I practiced aborted approaches ( go-arounds) at least once every session. FROM THE SECOND LESSON. I never knew when the command would come. Seemed it was most often when I had the entire approach nailed... perfect! _ I do remember that as soon as power was applied, it took a LOT of forward yoke force in the C152 to keep the nose down and let A/S build since we were in landing config. Flaps out, trim and all. Maybe this poor chap hadn't experienced that effect enough. I was instructed that after reaching climb speed I must manuever away from RW centerline, start climb, s-l-o-w-l-y bring in the flaps and establish normal climb config. My glider instructors would also frequently abort aerotow unexpectedly which totally saved my cheese when I experienced my first real rope break. Bless 'em. Too bad for this kid. A real shame. -- Message posted via AviationKB.com http://www.aviationkb.com/Uwe/Forums...ation/200707/1 |
On Jul 12, 3:56 am, "David Wright"
wrote: http://news.bbc.co.uk/1/hi/england/essex/6294778.stm Interesting that a "Go Around" is considered here as an "unfamiliar manoeuvre" - and that the pilot was "put in a situation beyond his experience" - okay he only had 15 hours of flying time and it was only his second solo, but I was doing touch and go's and going around from about my third hour onwards. D. I just read the news report. Man, flying in the UK must be exciting if the tower can ask you do perform a loop to avoid traffic!! No wonder the poor kid crashed. -Robert |
On 2007-07-12 12:00:49 -0700, "Robert M. Gary" said:
On Jul 12, 3:56 am, "David Wright" wrote: http://news.bbc.co.uk/1/hi/england/essex/6294778.stm Interesting that a "Go Around" is considered here as an "unfamiliar manoeuvre" - and that the pilot was "put in a situation beyond his experience" - okay he only had 15 hours of flying time and it was only his second solo, but I was doing touch and go's and going around from about my third hour onwards. D. I just read the news report. Man, flying in the UK must be exciting if the tower can ask you do perform a loop to avoid traffic!! No wonder the poor kid crashed. -Robert You think that is bad. I once had to do an Immelman as a solo student at Boeing Field! -- Waddling Eagle World Famous Flight Instructor |
![]() Back to the OT. I read the report and this discussion. To me this accident looks like a perfect example of the "Swiss cheese model" which describes how several small individual mistakes may combine to cause an accident. A question to the CFIs in the group: Do you normally include a set of "unexpected events" such as the abnormal go-around that was a factor in this accident, in your flight training syllabus before solo, even though the regulations might not require it? Here are some examples that I have experienced either as watcher or pilot, that might be useful to rehearse with each student before solo. (Note that some of them need cooperation from ATC): - Orbit in the pattern (for spacing) in various locations and aircraft configurations. - Go-around with a heading change and nonstandard pattern re-join (like in this accident). - Taxi into position ("Line up" for the Europeans) then ATC orders a/c to expediently vacate runway. - In a touch and go, after the "touch" the a/c is ordered to make it a full stop landing. - Landing clearance simply omitted. (should result in go-around) - Landing clearance only after a/c is beyond the threshold. - A/c is requested to land long, in order to be able to vacate runway more expediently. - Low fly-by to enable tower to inspect a/c (with binoculars) for possible landing gear defect. In my own case I had rehearsed only some of these events during training, so when they eventually occurred it was "exciting", with probably increased risk level. So maybe they would be good to rehearse before solo? |
Snowbird wrote:
Back to the OT. I read the report and this discussion. To me this accident looks like a perfect example of the "Swiss cheese model" which describes how several small individual mistakes may combine to cause an accident. A question to the CFIs in the group: Do you normally include a set of "unexpected events" such as the abnormal go-around that was a factor in this accident, in your flight training syllabus before solo, even though the regulations might not require it? Here are some examples that I have experienced either as watcher or pilot, that might be useful to rehearse with each student before solo. (Note that some of them need cooperation from ATC): - Orbit in the pattern (for spacing) in various locations and aircraft configurations. - Go-around with a heading change and nonstandard pattern re-join (like in this accident). - Taxi into position ("Line up" for the Europeans) then ATC orders a/c to expediently vacate runway. - In a touch and go, after the "touch" the a/c is ordered to make it a full stop landing. - Landing clearance simply omitted. (should result in go-around) - Landing clearance only after a/c is beyond the threshold. - A/c is requested to land long, in order to be able to vacate runway more expediently. - Low fly-by to enable tower to inspect a/c (with binoculars) for possible landing gear defect. In my own case I had rehearsed only some of these events during training, so when they eventually occurred it was "exciting", with probably increased risk level. So maybe they would be good to rehearse before solo? It should be common practice for instructors to use part of every dual period spent with a student covering possible situations that could be encountered by ANY pilot engaging in the maneuver or scenario being taught. In other words, everything an instructor teaches in the air should be considered and covered from two directions; first, what to do to make it come out right, and secondly, things to consider if things DON'T come out right. This is instruction 101 for any good instructor. Dudley Henriques |
Safety pilot "flight time" | kevmor | Instrument Flight Rules | 71 | January 30th 07 07:03 PM |
Old polish aircraft TS-8 "Bies" ("Bogy") - for sale | >pk | Aviation Marketplace | 0 | October 16th 06 07:48 AM |
Aviation Accident - No "Excellent Pilot" Mention | Judah | Piloting | 3 | February 7th 06 09:53 PM |
