"I'll spend as much of YOUR money as I want!" - Bu$h's Sunday Presidential Address
Old September 11th 03, 02:13 AM
Bob McKellar
B2431 wrote:
I suppose I should.
It amazes me an adult in his 50s can't admit he's wrong and switches sides and
says he was correct all along despite the evidence.
Why are you bringing GWB into this discussion? I thought we were talking about
Tarver.
Bob McKellar
Actually, he's not amusing anymore. I didn't killfile him before because it
amazed me what he would come up with in this and other NGs.
Dan, U. S. Air Force, retired
  #32
Old September 11th 03, 02:24 AM
Tarver Engineering
"Bob McKellar" wrote in message
B2431 wrote:
I suppose I should.
sides and
about
Tarver.
Dan is just making a fool of himself, do you plan to join him?
  #33
Old September 11th 03, 03:59 AM
B2431
B2431 wrote:
I suppose I should.
and
about
Tarver.
Bob McKellar
Boo, hiss etc
Dan, U. S. Airforce, retired
  #36
Old September 11th 03, 05:22 AM
Walt BJ
Gentleman, the F4E does indeed have static ports, two of them. They
are located ON the pitot boom. FYI I logged 2000+ hours in the F4
series and was an F4E maintenance test pilot besides an instructor in
both the F4D and E. FWIW The F104A's static ports were in the same
place on the late-model pitot head installed on that airplane.
As for P1 and T0, they refer to the turbine engine stations where the
readings are taken. As for gasoline (piston) engines not needing such
information, the latest electronic fuel controls for reciprocating
engines do indeed use that information to compute air density for
precision fuel metering. Most likely if you drive a new car it also
has that type of control.
Walt BJ
  #40
Old September 11th 03, 07:20 PM
(B2431) wrote:
(Walt BJ)
snip
Walt BJ
Walt, that's why I referred to it as the "pitot-static" tube. I guess I could
have been more clear in referring to static ports as a separate entity. I was
referring to the static ports flush mounted on the fuselage eg; KC-135. The
KC-135 has pitot tubes and the static ports are elsewhere on the fuselage. A
pitot-static tube has static ports a few inches back from the inlet as in F-4E,
T-39 etc.
As for the static ports on the F-4E pitot-static tube there were 4 small holes
in pairs on opposite sides of the tube IIRC(it's been 23 years since I last
worked on an F-4E). In any event the ports were all routed to a single fitting
extending out the back of the pitot-static tube coaxially with the pitot
fitting and heater connector. The pitot and static fittings were -4 and were
connected to lengths of nylon tubing running aft along the right side of the
radome.
That reminds me...there was an odd setup on the C-119 with
respect to static ports...there was one on each side of the big
flat sides of the fuselage which were connected together then
"teed" off to feed the ASI, altimeter and VSI. It was a little
'trick' question as to the reason for this.
Apparently it's purpose was to cancel out the effect of
'skidding' the fuselage. With those huge 'barn door' sides the
effect of skid was quite large. Could this have been why the
F-4E's static ports were 'doubled up'?
-Gord.
how much money have you lost on the lottery? NOW GET THAT MONEY BACK! shane Home Built 0 February 5th 05 07:54 AM
Start receiving MONEY with this simple system. Guaranteed. Mr Anderson Aviation Marketplace 0 February 2nd 04 11:55 PM
