Controller screwed up?
Old September 11th 07, 11:26 PM posted to rec.aviation.piloting
Larry Dighera
Default Controller screwed up?
On Tue, 11 Sep 2007 14:42:56 -0500, "Maxwell"
wrote in :
Do you mean to tell me someone actually posted an uninformed opinion around here????
Are your expectations too low?
  #32
Old September 12th 07, 03:25 PM posted to rec.aviation.piloting
Andrew Gideon
On Tue, 11 Sep 2007 08:59:35 -0600, Newps wrote:
Experience. But if you miss an exit he'll just cancel the takeoff
clearance and have the MD80 hold in position.
So there's no chance that two things will go wrong? I'm thinking, for
example, of a blown tire in the just-landed aircraft combined with a
communication failure (either "mechanical" or human) which prevents the
aircraft taking off from hearing the clearance cancellation.
How would that sort of thing be handled?
FWIW, I've never received a t/o clearance until someone is clear of the
runway. At best, I'll get "position and hold". But I can start my roll
in a 182 a hell of a lot more quickly than can an MD-80 grin. Makes me
wonder why people bother with the lumbering beasts laugh.
- Andrew
  #33
Old September 12th 07, 04:31 PM posted to rec.aviation.piloting
Newps
Anything can happen at anytime. But it usually doesn't. When something
happens we'll adjust, but until then we'll use what is known to work.
  #34
Old September 13th 07, 01:39 PM posted to rec.aviation.piloting
donzaemon
Thanks for the warm welcome and vote of confidence Larry.
The point is, that maybe some people , and maybe you're included in this
group, should not just blindly assume that because something is written in
a book that is is almighty and the absolute very best way to do things.
I offered a logical approach that made sense to me to be a much more
effective catchall for runway incursion type accidents.
Newps, demonstrating his clear understanding of both sound logic and in
depth knowledge of the regulations as well as real life operations has shed
light on how it works in the real world. So it seems clear to me that
there's always a compromise , if you do things the absolute safest way ,
you lose a lot in terms of delays and inefficient use of time. but if you
are too loose with the regs , then you start having more accidents
statistically. So the FAA has come up with what is probably the best
balance between the two to keep us moving and keep the potential for
accidents at a low level. So the way things are , I can see sequences of
several things that come together which would still cause an accident. for
example, the pilot in the light aircraft leans for taxi and accidently
stalls the engine on the runway at the same time the heavy with a newbie
first officer has a checklist problem that gets the captain funbling around
the panel as he starts the roll and the tower controller spills his coffee.
etc. etc. My proposal would probably keep us away from accidents caused by
this scenario , but , it would also slow us down greatly in day to day
normal operations.... so we have to decide after crunching some numbers
that the probability chance that all these bad things will come together for
an accident does not balance the benefit we get on a regular basis. So I
guess the moral of the story is that the law of large numbers says that
given enough time there WILL be accidents caused by various different
scenarios like the one I described above so PAY ATTENTION to what you're
doing at all times.
"Larry Dighera" wrote in message
On Tue, 11 Sep 2007 22:02:50 +0900, "donzaemon" wrote
in :
I'm not sure what the regulations technically say
Then perhaps you might consider looking up the appropriate
regulation/order instead of admitting your ignorance publicly in an a
worldwide forum.
  #35
Old September 13th 07, 04:18 PM posted to rec.aviation.piloting
Larry Dighera
[top posting repositioned so the flow of thought is chronological]
in :
worldwide forum.
On Thu, 13 Sep 2007 21:39:10 +0900, "donzaemon" wrote
in :
While you may feel that you are entitled to respect solely by virtue
of your ability access this forum, until a participant has
demonstrated his worth, I'll reserve my warm welcome.
My admonishment was meant to cause you think, and perform some
_research_, BEFORE committing your follow up comments to Deja's
eternal Usenet database archive: http://www.deja.com.
It's a simple matter to lookup the pertinent regulation* on the FAA
web site before you post your (admittedly uninformed) opinions. After
all, aviation has trundled along for over a century now, and it is
reasonable to think that most of the gotchas have been addressed by
FAA regulations, that have been continually honed and amended over the
decades, so as to have created the safest, most efficient ATC system
existent.
To think that your opinion would be superior to those regulations,
without you even bothering to expend the effort to consult them, seems
the height of blind hubris to me.
Without even bothering to consult the regulations, how can you
possibly be qualified to pass judgment on what others assume or not?
To be so presumptuous as to think your idea would be superior to the
existing regulation, without even knowing what it is (and so
admitting), reveals a certain self-assured certainty reminiscent of
the only US president to hold office by virtue of Judicial Department
decision, who consulted a "higher source" to reach the decision to
plunge our nation into an unjustified, $3-billion per week war for at
least the next decade. Thankfully, the scientific mind consults
reality (not his imaginary friend) before reaching a conclusion. And
so should airmen.
doing at all times.
As a certificated airman, you should be aware, that it is your
responsibility to operate your aircraft safely at all times. That's
why FAA regulations make room for the PIC to deviate from regulations
when his judgment dictates it. If you are only coming to the
realization of that responsibility now, I must conclude that you
haven't too much experience yet, or ...
Too many airmen act as though piloting is an inconsequential "hobby"
worthy of no more concern than a game of Chess. In my opinion, if the
act of becoming a pilot didn't change an airman's life, s/he has not
fully appreciated the responsibility expected of him by the FAA, his
passengers, his fellow airmen, and the public over whom he navigates.
A blasé attitude toward regulations reveals a lack of appreciation
for that responsibility.
Over the past couple of decades, the level of cognitive, informed
discourse in this newsgroup has declined to where now there are many
who feel that inane, prattling chit-chat (I'm accusing you of this.)
is appropriate here. Due to that influx of noise, it appears that
many newly among the readership of this newsgroup have very low
expectations for participation in this forum. These lowered standards
lead to further lowering standards, and most importantly, drive away
those with valuable experience and insights to share. After all, who
want's to who want's to "cast his pearls" among those unworthy of
them?
http://www.faa.gov/regulations_polic...a/7110.65R.pdf
3-9-5. ANTICIPATING SEPARATION
Takeoff clearance needs not be withheld until
prescribed separation exists if there is a reasonable
assurance it will exist when the aircraft starts takeoff
roll.
3-9-6. SAME RUNWAY SEPARATION
Separate a departing aircraft from a preceding
departing or arriving aircraft using the same runway
by ensuring that it does not begin takeoff roll until:
a. The other aircraft has departed and crossed the
runway end or turned to avert any conflict. (See
FIG 3-9-1.) If you can determine distances by
reference to suitable landmarks, the other aircraft
needs only be airborne if the following minimum
distance exists between aircraft: (See FIG 3-9-2.)
1. When only Category I aircraft are involved-
3,000 feet.
2. When a Category I aircraft is preceded by a
Category II aircraft- 3,000 feet.
3. When either the succeeding or both are
Category II aircraft- 4,500 feet.
4. When either is a Category III aircraft-
6,000 feet.
5. When the succeeding aircraft is a helicopter,
visual separation may be applied in lieu of using
distance minima.
  #36
Old September 13th 07, 05:12 PM posted to rec.aviation.piloting
Richard Carpenter
Huh. Well folks, I'm very new to this particular Usenet group, having
just last week started my Cessna pilot training program, but I have
been around the Usenet block a time or two, and thought I might offer
up my own take on this particular issue...
in :
worldwide forum.
in :
existent.
First off, if everyone meticulously poured over all relevant FAA
guidelines and came to their own conclusions prior to posting their
thoughts here for feedback, two things would happen:
1) As you mention, the signal to noise ratio would very likely
increase, but only at the cost of actual productive discussion. The
"knuckleheads" will still be showing their "knuckleheadedness".
2) Many misinterpretations of FAA rules and established protocols
would occur, as people would, in the interests of avoiding any
incidental offenses to the sensibilities of hard-liners such as
yourself, creating unecessary risks as the pilots proceed to operate
under their own, possibly mistaken, understanding of established code.
This, IMHO, is not worth the Usenet utopia for which would strive.
Why would such prejudicial inclinations even be expected? Good Lord, I
can only imagine if my CFI were to follow your line of reasoning on
every uninformed question I might think to ask. Sure, there is a
rec.aviation.student group, but, gee, where do I go once I receive my
certificate? Would you suggest that the newly-certified pilot be left
to make their own sense out of FAA regulations??
so should airmen.
Textbook non-sequitur.
doing at all times.
You said it yourself - "when his judgement dictates it". Yet when a
pilot comes here seeking clarity and feedback on just such a judgement
call, both on their part and on the part of the ATC at the time, you
chide them? I'd say that hubris is at fault here, but not on the part
of the one seeking enlightenment.
Wow. Did you have to file a flight plan before making a leap of that
magnitude? Seriously. Did you honestly take the OP's post as a slap in
the face of the FAA and GA in general??
them?
Really?? "Unworthy"? There are many different standards that can
decline for a community such as this. I might point out fellowship,
civil discourse and a healthy, on-going desire to both learn and teach
as appropriate being right up there near the top of the list.
*http://www.faa.gov/regulations_polic...air_traffic_or...
roll.
3,000 feet.
6,000 feet.
distance minima.- Hide quoted text -
- Show quoted text -
"...if there is a reasonable assurance it will exist when the aircraft
starts takeoff roll."
You could have stopped right there and had all the topic you needed
for discussion. "Reasonable assurance" is nothing if not subjective.
I really don't mean to over-step my bounds or imply a higher level of
knowledge or experience than I possess, but this just seem to me to be
more of an issue of social skills, than whether or not a particular
point of discussion is justified.
Rich
  #37
Old September 13th 07, 05:30 PM posted to rec.aviation.piloting
donzaemon
well , you certainly have something to prove. Aside from commenting that
I'm sorry to hear you favor erring on the side of being 'less safe' than
more I'll leave the last word to you , You and whomever else might want to
play your immature name calling games. If this kind of hostility is a
regular occurance with you I might also suggest a psychologist to help you
along before your problems at home and work get too out of hand.
  #38
Old September 13th 07, 06:44 PM posted to rec.aviation.piloting
Larry Dighera
Best of luck in your "Cessna pilot training program."
On Thu, 13 Sep 2007 16:12:08 -0000, Richard Carpenter
wrote in
.com:
So you find explicitly stated uninformed opinion contributes to
productive discussion?
I find it reveals a mind that is too lazy to become informed.
The "knuckleheads" will still be showing their "knuckleheadedness".
If the readership tolerates such, there is no question that it will
continue. Usenet is built upon self-governance after all.
I'm having some difficulty parsing that "sentence." But without
researching the governing regulations, how can one intelligently
discuss them?
Huh? You find the expectation that the author of an article perform
some research before publishing it to be a "prejudicial inclination?"
I believe it is an airman's responsibility to be aware of the
regulations and orders governing aviation. If that's "a "prejudicial
inclination" in your opinion, than so be it.
Good Lord,
Oh, now you're going to invoke your deity....
I can only imagine if my CFI were to follow your line of reasoning on
Questions are not uninformed opinion. Why do you raise that issue?
Sure, there is a rec.aviation.student group, but, gee, where do I go once
I receive my certificate? Would you suggest that the newly-certified pilot
be left to make their own sense out of FAA regulations??
Talk about "textbook non-sequitur" ...
I suggesting that authors make an effort to research the subject
before offering their opinion. Do you find that unreasonable?
so should airmen.
You are entitled to your opinion, as am I.
doing at all times.
chide them?
Please provide an example of my words that you feel supports that
allegation.
My comments were regarding stated uninformed opinion, not an author
"seeking clarity and feedback." Here's the text of the offending
article so that you can see that there was no real request for
clarity; there was effectively a proposal by the author to amend FAA
Order 7110.65 without a clear understanding of the responsibilities of
air traffic controllers and pilots in command:
Message-ID:
How does the controller know you won't have a problem and not get
off the runway ?
I'm not sure what the regulations technically say about it but it
doesn't sound right logically.
-- A better policy would be to give position & hold until the other
plane is actually in the process of turning off, then when some
clear action toward the turnoff is commenced, anticipate it as
cleared and give a takeoff clearance.
Air traffic controllers issue their clearances based on their
judgment, and they amend them based on their judgment. The PIC uses
his certified visual acuity to assure that the takeoff path is clear
before commencing takeoff. It's simple. It works. And it emphasizes
the crucial role of situational awareness incumbent on the PIC.
If the OP's suggested policy thesis were to be spread among the
existing regulations, the increases in separation requirements in the
misguided attempt to increase safety, and resulting delays would make
the National Airspace System unworkable.
At what point would YOU implement pilot judgment in lieu of failsafe
operations? As long as humans are involved in the decision making
process, it's inevitable that compromises are made.
One does not seek enlightenment through proselytizing uninformed
opinion.
I believe the OP fails to appreciate the wisdom contained in
regulations honed by decades of experience.
them?
Really??
You find it surprising?
"Unworthy"?
Serious airmen take airmanship seriously. Those who don't are
unworthy of being an airman.
There are many different standards that can decline for a community such
as this.
To which specific "community" are you referring, the community of
airman, the readership of this newsgroup, the participants in Usenet,
I might point out fellowship, civil discourse and a healthy, on-going
desire to both learn and teach as appropriate being right up there near
Why do you feel that it is appropriate for the standards of
"fellowship, civil discourse and a healthy, on-going desire to both
learn and teach" to decline. (If that wasn't what you meant to say,
perhaps you can rephrase your statement.)
roll.
3,000 feet.
6,000 feet.
for discussion.
I'm not sure what you're trying to say. Did you notice, that I had
posted the regulations in a follow up article in this message thread
previous to the in question?
You seem to have a firm grasp of the obvious. Is there a reason you
mention that?
It's not either.
You claim to have "been around the Usenet block a time or two,"
therefore you are probably familiar with newsgroup charters. Here's
the charter that was hammered out and agreed upon for
rec.aviation.piloting"
Subject: CHARTER: rec.aviation.piloting
Newsgroups: rec.aviation.piloting
The charter of rec.aviation.piloting is:
* Information pertinent to pilots of general aviation aircraft
* which would not fall into one of the other non-misc
* rec.aviation groups. Topics include, but are not limited to
* flying skills, interesting sights, destinations, flight
* characteristics of aircraft, unusual situations, handling
* emergencies, working with air traffic control, international
* flights, customs and immigration, experiences with
* ground support facilities, etc.
I call your attention to the first word of the newsgroup charter:
INFORMATION. Uninformed opinion is not information.
"Let thy speech be better than silence, or be silent."
- Dionysus the Elder
  #39
Old September 13th 07, 07:04 PM posted to rec.aviation.piloting
Larry Dighera
On Fri, 14 Sep 2007 01:30:56 +0900, "donzaemon" wrote
in :
I called no names.
And apparently, you didn't learn anything. Oh well....
  #40
Old September 13th 07, 07:11 PM posted to rec.aviation.piloting
Kloudy via AviationKB.com
just a few lines clipped ; )
Perhaps you could help ease the load on the database (noise) by putting this
degenerating thread to rest.
Message posted via AviationKB.com
http://www.aviationkb.com/Uwe/Forums...ation/200709/1
Don't Want to be Screwed [email protected] Home Built 5 May 22nd 04 06:58 AM
Screwed by Helicopter Support Inc. Becky DeWind Owning 3 May 18th 04 01:14 PM
