peld wrote:
Like you I thought I would have problems. I used to think that the leg would catch on the panel and come off, but that wasn't a problem at all. I have a "naked" limb (no cosmetic wrappings, just an anodized shaft) and, as a result, often have to disengage the heel of my shoe while getting out after a flight. It catches on the lip on the cross-beam that supports the stick and front of the seat pan in my Libelle. I've always wondered if that would be a problem during emergency egress. I imagined that the shoe would depart before my leg came off: the liner seems to have a pretty good grip on my remaining bits. As for landing, I came down on my backside, don't ask me how, and the leg was no problem at all then. However, I badly bruised my coccyx and jarred my back pretty bad. My sympathies: damaged backs are no joke, but as you say getting down in one piece is all that matters. Thanks for the explanation of why your leg wasn't affected. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
I've always thought it would be a good idea to take
hold of the rip-cord handle before finally leaving the glider. Did you do that, and, if you didn't, did you get hold of the handle quickly and easily? At 11:00 12 September 2007, Peld wrote: Dan, I had the unfortunate experience of having to leave my glider in January after a mid air. The other glider had impacted my left wing and severed it about half a metre from the root,and also broke the tail boom midway between the wing and the tail. He was able to land but I had to make a quick exit, which was my first parachuting experience. I had no doubts that I would have to jump, and previous training and preparation took over. The glider had started a spin to the left and it took some time to get rid of the canopy (PUSH on it after you activate the releases!), but I was actually surprised how easy it was to get out of the cockpit. Having undone the harness it seemed like no trouble at all to just roll over the canopy rail and out into the wild blue yonder. I have a below knee artificial right leg so I had considered this scenario for some time, expecting to have a lot of trouble just getting my leg past the instrument panel, but no, it was really a piece of cake. I put it down to the fact the gravitational force was less as the glider was diving and all I had to do was push away from it. A NOAH sytem would have been redundant I feel. Luckily, the spin hadn't developed to the stage where the centrifugal forces were high, even though it had seemed to take forever to get out; in fact it was probably only seconds. The chute worked as advertised (it had been repacked 2 months previously), opening in 3 seconds (or so it seemed) and there was no way I was going to do any stabilising. I used that ripcord as soon as I could. Adrenalin does amazing things. I was upside down when the chute opened, but the shock of it soon had me the right way up. I did get some pretty severe bruising around the groin and shoulders, but I was alive and thats what counted. Then there was the landing. I couldn't see the ground properly because the shock of the opening chute ripped my glasses off, and I hit before I was ready, and I hit very heavily, once again with absolutely no proper tecnique, but I was alive. As far as I am concerned everything worked and the end result was good. I just hope no one else has to try out their parachute. Phil |
Probably not a good idea, for a couple of reasons:
1. You may need both arms to get out, or may only have one working (or free) arm available to get out. And you HAVE to get out before using the chute (with one possible exception). 2. If you are holding the rip-cord during egress, you probably increase the chance of an early chute deployment, and possible entaglement with the glider. A better plan is to practice finding your rip-cord while wearing your chute - using your eyes to guide your hands to where it should be. This should be tried both standing up, crouching, spread-eagled; any position you think you might assume after exiting the glider. Also, note that the rip-cord handle (D-ring) may be jarred loose from it's housing during the bailout, and you might have to locate it by finding where the rip-cord exits the chute housing and following the rip-cord wire to the D-ring. Think about it, look carefully at your parachute, and practice actually deploying it when you drop it off to get it repacked - you may be surprised how hard (or easy) it is to pull. I like to setup a scenario with my rigger, then talk myself through the timeline of a mid-air and bailout (CANOPY, STRAPS, EXIT, FIND D-RING, PULL, CHECK CANOPY etc), until I pull the rip-cord and the chute "deploys". My chute always surprises me with an "easy" pull, compared to some military training jumps I did long ago that required two hands to move the D-ring! The exception mentioned above? You can't get out of the cockpit. Last resort,(canopy gone) is to unstrap, lean forward as far as you can (pull youself using the instrument panel), then pull the rip- cord. You WILL be extracted from the glider. It may not be pretty, thought! Ref FLARM: Unfotunately, we pathetic Americans are specifically prohibited from using it. Not that it would do much good in most parts of the US, glider density is way too low. And I can't even get most pilots in my club to set their altimeters to QNH! So the chance of there being pressure to introduce a similar system in the US is pretty low, IMHO... Kirk 66 |
On Sep 12, 11:04 pm, Mark Dickson
wrote: I've always thought it would be a good idea to take hold of the rip-cord handle before finally leaving the glider. Did you do that, and, if you didn't, did you get hold of the handle quickly and easily? At 11:00 12 September 2007, Peld wrote: Mark, I didn't have a hold of the ripcord as I left the cockpit, I was too busy trying to hold my glasses on. I think my priorities may have been a bit askew at that stage. Also I was using as much energy as I could to get over the side, and also looking to see that I wasn't going to hit the wing on the way out. The wing that wasn't there any more by the way. To be quite honest, I don't even recall pulling the ripcord, but as has been mentioned on here, I had practised doing that plenty of times on the ground and obviously the practise paid off. I did hang on to the ripcord all the way down to the ground and I fully intend to frame it! |
At 19:00 12 September 2007, Toad wrote:
On Sep 12, 12:46 pm, Tim Taylor wrote: On Sep 11, 4:33 pm, Paul Hanson wrote: For the really safety minded (and thick walleted) a BRS, NOAH, a personal chute, a helmet (might have saved more lives than you may think) and all the other gizmos mentioned already, including the condom, although admittedly the helmet may significantly reduce the need for that one ![]() Paul, I have been thinking it would be nice to have a study of crashes to determine if a helmet wold have saved many lives. We fly at speeds up to 200 mph, yet do not require a helmet of pilots. I have been looking at helmet types that would allow good vision and movement in gliders without excessive weight for the G's we pull. Has anyone done this type of study and/or tried flight helmets etc in gliders? Tim How many pilots could have been saved by a helmet ? I can't recall reading too many accident reports that claim the pilot died of head injuries, when there wasn't enough other injuries to be fatal. Data any one ? Todd Smith 3S Look up the details (if you can find them) of the most recent US glider fatality (Ridge Soaring Gliderport, July 14 2007). That pilot was still alive when rescue crew got to him, but died of his head injuries by the time he arrived at the hospital according to the newspaper article I read. I have heard of others as well, but that one comes to mind off the top of my unprotected head. Paul Hanson "Do the usual, unusually well"--Len Niemi |
"Paul Hanson" wrote in message
... At 19:00 12 September 2007, Toad wrote: On Sep 12, 12:46 pm, Tim Taylor wrote: ... I have been thinking it would be nice to have a study of crashes to determine if a helmet wold have saved many lives. We fly at speeds up to 200 mph, yet do not require a helmet of pilots. I have been looking at helmet types that would allow good vision and movement in gliders without excessive weight for the G's we pull. Has anyone done this type of study and/or tried flight helmets etc in gliders? ... See http://iac78.org/newsletter/Newsletter_May_2007.pdf for info on some of the available helmets. -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. |
Pretty much the only pilots that wear helmets are military
pilots, and that is probably due to the excessive g they experience and the forces involved in ejecting. Also for attaching sun visors, oxygen masks, headphones and mics. Glider pilots definately do not need helmets; not in the air anyway, maybe on the ground to protect against walking into trailing edges. |
Mark Dickson wrote:
Pretty much the only pilots that wear helmets are military pilots, and that is probably due to the excessive g they experience and the forces involved in ejecting. Also for attaching sun visors, oxygen masks, headphones and mics. Glider pilots definately do not need helmets; not in the air anyway, maybe on the ground to protect against walking into trailing edges. I do know of one pilot that wears a helmet while wave flying. It looks like a military jet pilot's helmet, including the darkened "goggle" portion that covers the eyes. He does it for the warmth in normal wave flying, for protection from the bright sun (he doesn't fly wave where I fly!), to support the oxygen mask, to provide protection from a canopy that shatters in the cold, and for protection from the wind and cold if he has to bail out at high altitudes. He doesn't have any problems with clearance to the canopy, but I think a lot of pilots would. I rarely fly above 18,000 in wave, but if I did it routinely, I'd consider wearing a helmet. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * "Transponders in Sailplanes" http://tinyurl.com/y739x4 * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
I know of some bush pilots who wear helmets. I opted for the Amsafe air-bag
system when I bought my Husky, figuring it would provide better protection overall, and be less hassle than a helmet. I don't have headroom in the glider for a helmet. I do use 1/4" of Confor (NASA, Tempur etc) foam in the top of my floppy terri hat. It helps keep my bald noggin from bonking the canopy too hard in rotor and probably helps protect the canopy too. One might not think that just 1/4" of extra-firm Confor would do much, but it does! You can test this by putting the Confor on concrete and then hitting it with your fist. Hint - don't hit it as hard as you can - - makes an amazing difference. bumper "Eric Greenwell" wrote in message news:gr2Gi.8312$Ic3.1085@trndny09... Mark Dickson wrote: Pretty much the only pilots that wear helmets are military pilots, and that is probably due to the excessive g they experience and the forces involved in ejecting. Also for attaching sun visors, oxygen masks, headphones and mics. Glider pilots definately do not need helmets; not in the air anyway, maybe on the ground to protect against walking into trailing edges. I do know of one pilot that wears a helmet while wave flying. It looks like a military jet pilot's helmet, including the darkened "goggle" portion that covers the eyes. He does it for the warmth in normal wave flying, for protection from the bright sun (he doesn't fly wave where I fly!), to support the oxygen mask, to provide protection from a canopy that shatters in the cold, and for protection from the wind and cold if he has to bail out at high altitudes. He doesn't have any problems with clearance to the canopy, but I think a lot of pilots would. I rarely fly above 18,000 in wave, but if I did it routinely, I'd consider wearing a helmet. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * "Transponders in Sailplanes" http://tinyurl.com/y739x4 * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
70 kg 31:1 glider is here to stay? | Andre Volant | Soaring | 57 | November 27th 04 11:21 AM |
Region 1 Contest - will trade place to stay | Quebec Tango | Soaring | 0 | May 10th 04 03:17 PM |
How Aircraft Stay In The Air | Sarah Hotdesking | Military Aviation | 145 | March 25th 04 05:13 PM |
The Bud Light logo will stay | Cub Driver | Military Aviation | 8 | November 24th 03 01:08 AM |
The Bud Light logo will stay | Cub Driver | Piloting | 7 | November 24th 03 01:08 AM |
