787 Story by Dan Rather
Old September 20th 07, 07:20 PM posted to rec.aviation.piloting
Bertie the Bunyip[_19_]
Default 787 Story by Dan Rather
Mxsmanic wrote in
Larry Dighera writes:
While it is evident that Mr. Vincent A. Weldon is qualified to issue
his concerns in his comment on this issue, I fail to see how the
carbon-fiber composite construction of the Boeing 787-8 is
significantly different from that used in many military aircraft.
It's not ... but military aircraft and personnel are considered much
more expendable than civilian aircraft and personnel, so the threshold
of acceptable risk is much higher. Hmm.
He raises some points about Boeing's cost cutting to reduce assembly
time and weight, but those should be easily addressed.
My major concern about the 787 is that so little of it is actually
produced by Boeing, and is actually farmed out to all sorts of foreign
contractors of questionable reliability, either to increase profit
margins or for political reasons.
You are an idiot
Bertie
  #33
Old September 20th 07, 10:35 PM posted to rec.aviation.piloting
On Sep 20, 11:59 am, Mxsmanic wrote:
My major concern about the 787 is that so little of it is actually produced by
Boeing, and is actually farmed out to all sorts of foreign contractors of
questionable reliability....
How could you possibly know this?
F--
  #34
Old September 20th 07, 11:13 PM posted to rec.aviation.piloting
On Sep 20, 2:55 pm, Mxsmanic wrote:
writes:
Which is different from the 777 how? Most of the 777 is made by
external suppliers.
I was under the impression that this was much more extreme in the case of the
787. Does Boeing build the wing for the 777?
Yes, Boeing makes the wing and the 41 section on the 777, but most of
the fuselage sections and empenage are made by suppliers, as are the
engines, avionics, hydraulics system components, etc. etc.
Boeing designs it, contract suppliers build most of the sub
assemblies, and then Boeing puts all the pieces together to make the
airplane. The 787 is not much different in this regard except for
doing the wings in Japan this time, mostly because they are composite.
  #38
Old September 21st 07, 06:14 PM posted to rec.aviation.piloting
Mxsmanic
Bertie the Bunyip writes:
Yes, that's why they call it a Boeing Aircraft fjukktard.
So, given that Boeing doesn't build the wing for the 787, what should it be
called? The Mitsubishi 787?
Does Citroen forge the wrist pins for youe 2CV?
The 2CV ended production long ago. I've been in one, but I've never driven
one, and I have no desire to do so.
  #40
Old September 21st 07, 06:20 PM posted to rec.aviation.piloting
Mxsmanic wrote in
it be called? The Mitsubishi 787?
Doesn't matter, fjukktard. Boeing designed it and Boeing oversee it's
manufacture. The place of manufacture is unimportant.
Your dearth of knowledge about manufacturing is simply breathtaking,
fjukkwit.
So what, that doesn't anser the question, fjukkwit.
driven one, and I have no desire to do so.
Because you couldn't.
Bertie
story behind Mal[_4_] Soaring 8 July 18th 07 05:07 AM
Another Story Michelle P Piloting 8 September 28th 05 02:13 PM
another "either you are with us ..." story Jeff Franks Piloting 2 December 31st 03 12:04 AM
WW2 Story Mike Marron Military Aviation 2 September 15th 03 05:45 PM
WW2 Story Mike Marron Military Aviation 1 September 1st 03 10:25 PM
