Glass cockpit hard to read
Old October 7th 07, 10:32 PM posted to rec.aviation.piloting
Union Thug
Default Glass cockpit hard to read
On Oct 7, 12:57 pm, "Robert M. Gary" wrote:
On Oct 6, 11:51 am, Bertie the Bunyip wrote:
People who prefer the numbers usualy don't fly very well at all.
Which is every test pilot the military has used since the 60's.
Minimum requirement is an engineering degree but most have PhDs.
Bob, This would be news to a couple of coworker buddies of mine. Both
of them did engineering and production test pilot work on two famous
fighters. One majored in music (you should hear him play gutair ) and
the other was political science. One of my ski buddies is former top
gun and he will be the first to tell you that the education thing is
highly over rated.
K B
Old October 7th 07, 10:51 PM posted to rec.aviation.piloting
Robert M. Gary
highly over rated.
K B
Which branch of the service where they in when they were test pilots.
-Robert
Old October 7th 07, 11:35 PM posted to rec.aviation.piloting
Bertie the Bunyip[_19_]
"Robert M. Gary" wrote in news:1191787050.286971.212410
@y42g2000hsy.googlegroups.com:
There's a difference between using the numbers and preferring them.
Bertie
Old October 6th 07, 08:06 PM posted to rec.aviation.piloting
On Oct 6, 9:21 am, Arno wrote:
Hello,
I am computer scientist and usually really like fancy technology. But
I just had my first flight with a "glass" PFD (Avidyne) and must say I
am not impressed. In particular reading altitude and airpeed from
these scrolling bands requires a lot more attention than with regular
gauges, just like reading a digital clock takes longer than reading an
analog one. Glancing at it and checking against a known picture, like
"speed at 3 o'clock is fine on final" or "altitude at 20 minutes past
midnight is minimum", just does not work anymore, instead I end up
reading the actual numbers every time I look. Does anyone feel the
same? Am I missing a particular technique?
Arno
You'll get used to it... there is a transition time to go from round
dial to tapes, but once you get used to tapes you will find that they
do have certain advantages. I worked on the 777 EFIS, which used the
tape format, and after several hours in the 777 simulator, the tapes
became as easy to read at a glance as the round dials. It just takes
conditioning your mind to be able to rapidly scan them, and being able
to pick up trend information from the tape motion instead of needle
motion. At least that was my experience.
A lot of human factors work went into the tape formats, and it was
with the understanding that training would be required for pilots to
adapt to them.
Dean
Old October 9th 07, 06:41 AM posted to rec.aviation.piloting
On Oct 6, 12:56 pm, john smith wrote:
In article . com,
adapt to them.
So do the numbers get bigger or smaller as the tape move down?
It does not get bigger when it moves down slowly. It only does
that when it moves down quickly, sucking the pilot to get closer
to the fast moving tape. It may be even bloodier, unless one is
trained
to slow down the fast moving tape before it displays a single digit 0.
Old October 6th 07, 09:14 PM posted to rec.aviation.piloting
Peter Dohm
Hello,
Arno
adapt to them.
Dean
I have never seen the system for the 777, but I did get a look at the low
end equipment at the LSA Expo in Sebring Florida, and felt that what I saw
was pure crap!
It is certainly possible to make a tape motion system that works well, and I
have seen some "physical" versions that I liked when I was an avionics tech
twenty years ago. However, those have a moving needle which moved in
opposition to the moving tape and at a slower rate than the tape. The
result was that the needle gave the coarse indication, at a glance, and the
tape gave the precise measurement when required--and, in the case of a
higher flying aircraft which would require a three needle altimeter, may
have been more intuitive to read.
However, on the implementations that I have seen, the representations of
needles were fixed and the numbers moved on a virtual card or tape. In my
opinion, they were egregeous!
Peter
Old October 6th 07, 09:18 PM posted to rec.aviation.piloting
Arno
adapt to them.
That's interesting. Do you have any reference of research comparing
various display methods? Tapes for speed and altitude in today's
cockpits are ubiquitous of course. So far I thought it was a case of
someone starting it and others just copying it.
Arno
Old October 6th 07, 09:35 PM posted to rec.aviation.piloting
Arno
Dean,
I just noticed something interesting, looking at pictures of recent
Boeing and Airbus PFDs. For altitude, they are both pretty much the
same, but for the speed tape, Airbus does not have a big number at the
center of the tape but instead the number on top of the tape and just
a thin line at the center. After my experience today I like the Airbus
better because it is less conducive to reading the numbers rather than
"get the picture":
Airbus A340:
http://simflight.nl/users/reviews/CL...nshots/PFD.jpg
Boeing 777:
http://www.meriweather.com/777/fwd/pfd.html
Arno
Old October 7th 07, 01:10 AM posted to rec.aviation.piloting
On Oct 6, 2:35 pm, Arno wrote:
Dean,
"get the picture":
Airbus A340:
Boeing 777:
Arno
Take a look at the speed tape on the 777. The tape itself gives you
the course rate of change, while the window gives you the fine
resolution changes with the 1's place on the airspace as a sliding
digit. The Airbus doesn't give you that.
OSH Homerun? Glass Cockpit for the Budget-Challenged Marco Leon Piloting 4 July 27th 07 11:27 PM
winter is hard. Bruce Greef Soaring 2 July 3rd 06 06:31 AM
Why Not Use PC To Make Glass Cockpit? Le Chaud Lapin Instrument Flight Rules 52 July 19th 05 03:45 AM
It ain't that hard Gregg Ballou Soaring 8 March 23rd 05 01:18 AM
Glass Cockpit in Older Planes Charles Talleyrand Owning 2 May 20th 04 01:20 AM
