"Randy Poe" wrote in message oups.com... As I said, I lean toward the angle-of-attack arguments now. Take a flat rectangle, tilt it into the wind. The wind blows against the front which is also the bottom, not the back/top. So the forces are on the bottom. The day the physics guys were passing out good wing designs, the aerospace designers were all out drinking beer, which is why every airplane since the Wright flyer has camber when they could have just used flat plywood. -c |
Gatt writes:
The day the physics guys were passing out good wing designs, the aerospace designers were all out drinking beer, which is why every airplane since the Wright flyer has camber when they could have just used flat plywood. Some wings do not have camber. Anyway, the purpose of the curve is to reduce drag and increase the stall angle, not to produce lift. |
Mxsmanic wrote in
: Gatt writes: The day the physics guys were passing out good wing designs, the aerospace designers were all out drinking beer, which is why every airplane since the Wright flyer has camber when they could have just used flat plywood. Some wings do not have camber. Name one, aside from a chuck glider. (and good chuck gliders have camber, BTW, fjukkwit Anyway, the purpose of the curve is to reduce drag and increase the stall angle, not to produce lift. Nope. Bertie |
"Mxsmanic" wrote in message ... Gatt writes: The day the physics guys were passing out good wing designs, the aerospace designers were all out drinking beer, which is why every airplane since the Wright flyer has camber when they could have just used flat plywood. Some wings do not have camber. Anyway, the purpose of the curve is to reduce drag and increase the stall angle, not to produce lift. That's simply not correct. Explain why sections for tailless aircraft curve both ways then. http://www.desktopaero.com/appliedae...image13_43.gif |
On Oct 9, 1:22 pm, Randy Poe wrote:
On Oct 9, 4:08 pm, Le Chaud Lapin wrote: Hi All, There is a long discussion ongoing in rec.aviation.piloting about what causes lift on a plane. Heh. I know the argument. I think it's broken out here (sci.physics) many times. (a) It's the Bernoulli effect due to the shape of the wing cross-section, the way we were all taught as kids. (b) No, it's just the angle of attack. Probably true, in large part anyway. Just consider that aerobatics pilots can fly their planes upside-down over considerable distances. If Bernoulli were the sole factor this couldn't happen. R.G. Vickson I'm no expert, but I heard enough in similar arguments here to convince me that the angle-of-attack people are right and the shape of the wing has more to do with controlling turbulence. There are people in the pilot's group, who think that lift on a wing is analyzed as such: 1. There is air on outside of top of wing that is pushing down, but reduced because of aerodynamics. 2. The *inside* of the wing contains air pushing up against the underside of top of wing . Er... that's a new one. OK, I haven't heard this argument then. 3. Let us ignore that the same air inside the wing pushes down on the overside of bottom part of wing. 4. The difference in pressure against the underside of the top wing on the inside of wing and top of wing on outside, is what gives plane lift. You can consider that last just a definition of lift. You won't get lift unless the upward forces are stronger than then downward forces. Note that they ignore the pressure inside the wing that pushes downward on the wing. A wing doesn't need to be hollow to fly. I am trying to convince them that, if there is air on the inside of the wing, it pushes against all sides of the inside of the wing, including both top underside and bottom overside, and thereby nullifying any effect it would have on the wing. Lift is caused by a difference in pressure between the underside of the bottom of the wing, and the overside of the top of the wing. I count 8-9 people in the group who are utterly convinced that I am inept at physics, mathematics, etc. Note that some of these people have been flying aircraft for years, even decades, while I am still a student pilot. Comments from anyone who knows physics welcome. As I said, I lean toward the angle-of-attack arguments now. Take a flat rectangle, tilt it into the wind. The wind blows against the front which is also the bottom, not the back/top. So the forces are on the bottom. Why does that translate into lift? I forget the exact arguments but from first principles if the effect is to change the direction of the incoming air molecules, then by conservation of momentum that translates into equal and opposite change of momentum of the surface, i.e. pressure with an upward component. - Randy |
Ray Vickson wrote in news:1191971717.488856.299560
@g4g2000hsf.googlegroups.com: On Oct 9, 1:22 pm, Randy Poe wrote: On Oct 9, 4:08 pm, Le Chaud Lapin wrote: Hi All, There is a long discussion ongoing in rec.aviation.piloting about what causes lift on a plane. Heh. I know the argument. I think it's broken out here (sci.physics) many times. (a) It's the Bernoulli effect due to the shape of the wing cross-section, the way we were all taught as kids. (b) No, it's just the angle of attack. Probably true, in large part anyway. Just consider that aerobatics pilots can fly their planes upside-down over considerable distances. If Bernoulli were the sole factor this couldn't happen. Bernoulli still works when you're upside down. Even with a flat bottomed wing.. Doesn't work so good, BTW, which only strengthens the bernoulli position, but it does work. Bertie |
On Oct 9, 7:33 pm, Bertie the Bunyip wrote:
Ray Vickson wrote in news:1191971717.488856.299560 @g4g2000hsf.googlegroups.com: On Oct 9, 1:22 pm, Randy Poe wrote: On Oct 9, 4:08 pm, Le Chaud Lapin wrote: Hi All, There is a long discussion ongoing in rec.aviation.piloting about what causes lift on a plane. Heh. I know the argument. I think it's broken out here (sci.physics) many times. (a) It's the Bernoulli effect due to the shape of the wing cross-section, the way we were all taught as kids. (b) No, it's just the angle of attack. Probably true, in large part anyway. Just consider that aerobatics pilots can fly their planes upside-down over considerable distances. If Bernoulli were the sole factor this couldn't happen. Bernoulli still works when you're upside down. Even with a flat bottomed wing.. Doesn't work so good, BTW, which only strengthens the bernoulli position, but it does work. But the Bernoulli position works best with helicopters. That's why they were invented for winged weirdos, who know kust about nothing about Bernoulli. Other than he once made a principle for Newton idiots. c Bertie - Hide quoted text - - Show quoted text -- Hide quoted text - - Show quoted text - |
" wrote in
ups.com: On Oct 9, 7:33 pm, Bertie the Bunyip wrote: Ray Vickson wrote in news:1191971717.488856.299560 @g4g2000hsf.googlegroups.com: On Oct 9, 1:22 pm, Randy Poe wrote: On Oct 9, 4:08 pm, Le Chaud Lapin wrote: Hi All, There is a long discussion ongoing in rec.aviation.piloting about what causes lift on a plane. Heh. I know the argument. I think it's broken out here (sci.physics) many times. (a) It's the Bernoulli effect due to the shape of the wing cross-section, the way we were all taught as kids. (b) No, it's just the angle of attack. Probably true, in large part anyway. Just consider that aerobatics pilots can fly their planes upside-down over considerable distances. If Bernoulli were the sole factor this couldn't happen. Bernoulli still works when you're upside down. Even with a flat bottomed wing.. Doesn't work so good, BTW, which only strengthens the bernoulli position, but it does work. But the Bernoulli position works best with helicopters. That's why they were invented for winged weirdos, who know kust about nothing about Bernoulli. Other than he once made a principle for Newton idiots. c I see Bertie |
On Oct 9, 6:15 pm, Ray Vickson wrote:
On Oct 9, 1:22 pm, Randy Poe wrote: On Oct 9, 4:08 pm, Le Chaud Lapin wrote: Hi All, There is a long discussion ongoing in rec.aviation.piloting about what causes lift on a plane. Heh. I know the argument. I think it's broken out here (sci.physics) many times. (a) It's the Bernoulli effect due to the shape of the wing cross-section, the way we were all taught as kids. (b) No, it's just the angle of attack. Probably true, in large part anyway. Just consider that aerobatics pilots can fly their planes upside-down over considerable distances. If Bernoulli were the sole factor this couldn't happen. Hmm..more reasoning going on in sci.physics. R.G. Vickson I am beginning to think I should have posted my OP in rec.aviation.piloting to sci.physics. Very comforting to see people focusing on physics to guide their arguments. -Le Chaud Lapin- |
Le Chaud Lapin wrote in
oups.com: On Oct 9, 6:15 pm, Ray Vickson wrote: On Oct 9, 1:22 pm, Randy Poe wrote: On Oct 9, 4:08 pm, Le Chaud Lapin wrote: Hi All, There is a long discussion ongoing in rec.aviation.piloting about what causes lift on a plane. Heh. I know the argument. I think it's broken out here (sci.physics) many times. (a) It's the Bernoulli effect due to the shape of the wing cross-section, the way we were all taught as kids. (b) No, it's just the angle of attack. Probably true, in large part anyway. Just consider that aerobatics pilots can fly their planes upside-down over considerable distances. If Bernoulli were the sole factor this couldn't happen. Hmm..more reasoning going on in sci.physics. R.G. Vickson I am beginning to think I should have posted my OP in rec.aviation.piloting to sci.physics. Very comforting to see people focusing on physics to guide their arguments. Just as long as you **** off there and don't ever fly an airplane. All of the posts I have seen in reply to yours are either completely wrong, partially wrong or just off the wallm so you'll be in good company. Bertie |
| Thread Tools | |
| Display Modes | |
| Pilot's Assistant V1.6.7 released | AirToob | Simulators | 2 | July 7th 07 11:43 AM |
| A GA pilot's worst nightmare? | Kingfish | Piloting | 49 | February 1st 07 03:51 PM |
| Pilot's Political Orientation | Chicken Bone | Piloting | 533 | June 29th 04 01:47 AM |
| Update on pilot's condition? | Stewart Kissel | Soaring | 11 | April 13th 04 10:25 PM |
| Pilot's Funeral/Memorial | TEW | Piloting | 6 | March 17th 04 04:12 AM |
