After dealing with the doctors and the FAA for the last six months I finally got my class 3 renewed. It's been a year since I last flew. and I can't believe how fast that time went by. So this month I am getting back into the cockpit and in addition to all of the standard maneuvers, I feel I especially need to work on emergency off-field landings. I've had my ticket for over 8 years, but financial concerns always seem to keep me from flying as much as I would like. So I do not get to practice as much as I should. Which brings me to the point of this post. While doing emergency off-field landing practice I am still trying to get some consistency in planning the descents from different altitudes to be at 1000' agl heading downwind and abeam the touchdown point. Seems like most of the time I was doing them last year, it was hit or miss. (perhaps a poor choice of words). Trying to put all the variables together to put the aircraft in the right place at the right time on a consistent basis is still an elusive endeaveor. Do you experienced pilots just have a sixth sense about how to get the aircraft exactly where it needs to be? Is it something you consciously analyze throughout the descent or just instinctlvely do? Kirk PPL-ASEL |
On Oct 14, 7:44 pm, Kirk Ellis
wrote: After dealing with the doctors and the FAA for the last six months I finally got my class 3 renewed. It's been a year since I last flew. and I can't believe how fast that time went by. So this month I am getting back into the cockpit and in addition to all of the standard maneuvers, I feel I especially need to work on emergency off-field landings. I've had my ticket for over 8 years, but financial concerns always seem to keep me from flying as much as I would like. So I do not get to practice as much as I should. Which brings me to the point of this post. While doing emergency off-field landing practice I am still trying to get some consistency in planning the descents from different altitudes to be at 1000' agl heading downwind and abeam the touchdown point. Seems like most of the time I was doing them last year, it was hit or miss. (perhaps a poor choice of words). Trying to put all the variables together to put the aircraft in the right place at the right time on a consistent basis is still an elusive endeaveor. Do you experienced pilots just have a sixth sense about how to get the aircraft exactly where it needs to be? Is it something you consciously analyze throughout the descent or just instinctlvely do? Kirk PPL-ASEL It just takes years of flight time and alot of practice. When flying you need to consciously analyze everything from the time you untie the plane till it's tied back down again. Best practice I have found for spot landings is to visit an out of the way small airport and pick a spot on the runway and fly the plane right to that spotseveral times, using both directions if the wind is not too strong will help you compansate for any drift/ tailwind componant, gusts,etc. The fact that you asked the question shows your sincere desire for getting it right. That's a good trait for a pilot.... :-) Ben |
Great advice.
The other thing I'll do is on longer, empty runways, I'll practice hot approaches and extended flares - that is, coming over the fence fast (100+ knots in a PA-28-140) and clean, chopping the power, and then establishing and holding my flare, deploying flaps, and holding it to a full-stall touchdown. With power off landings, flexibility is life. The wider the range of speeds your comfortable safely getting the plane down on the ground during approach, the more options you have when it comes time to make the choice to dive for the runway or do another 360. (assuming a long enough runway). (yes, this is easier with "dirty" planes like my piper, but widening your personal envelope of approach speeds in any aircraft isn't necessarily a bad thing to do if you want options in an emergency, no matter what the aircraft). On Oct 14, 7:24 pm, " wrote: On Oct 14, 7:44 pm, Kirk Ellis wrote: After dealing with the doctors and the FAA for the last six months I finally got my class 3 renewed. It's been a year since I last flew. and I can't believe how fast that time went by. So this month I am getting back into the cockpit and in addition to all of the standard maneuvers, I feel I especially need to work on emergency off-field landings. I've had my ticket for over 8 years, but financial concerns always seem to keep me from flying as much as I would like. So I do not get to practice as much as I should. Which brings me to the point of this post. While doing emergency off-field landing practice I am still trying to get some consistency in planning the descents from different altitudes to be at 1000' agl heading downwind and abeam the touchdown point. Seems like most of the time I was doing them last year, it was hit or miss. (perhaps a poor choice of words). Trying to put all the variables together to put the aircraft in the right place at the right time on a consistent basis is still an elusive endeaveor. Do you experienced pilots just have a sixth sense about how to get the aircraft exactly where it needs to be? Is it something you consciously analyze throughout the descent or just instinctlvely do? Kirk PPL-ASEL It just takes years of flight time and alot of practice. When flying you need to consciously analyze everything from the time you untie the plane till it's tied back down again. Best practice I have found for spot landings is to visit an out of the way small airport and pick a spot on the runway and fly the plane right to that spotseveral times, using both directions if the wind is not too strong will help you compansate for any drift/ tailwind componant, gusts,etc. The fact that you asked the question shows your sincere desire for getting it right. That's a good trait for a pilot.... :-) Ben |
On Sun, 14 Oct 2007 19:24:49 -0700, "
wrote: On Oct 14, 7:44 pm, Kirk Ellis wrote: After dealing with the doctors and the FAA for the last six months I finally got my class 3 renewed. It's been a year since I last flew. and I can't believe how fast that time went by. This is all I can find of the original post so I'll start from here. I can relate what I was taught and it has served me well. So this month I am getting back into the cockpit and in addition to all of the standard maneuvers, I feel I especially need to work on emergency off-field landings. I've had my ticket for over 8 years, Here we have to discern between the need to land off field and an emergency descent to get down as fast as possible and stay alive. I'm assuming you are referring to a power off, off field landing and not the cockpit fire, get this thing down NOW! but financial concerns always seem to keep me from flying as much as I would like. So I do not get to practice as much as I should. Which brings me to the point of this post. While doing emergency off-field landing practice I am still trying to get some consistency in planning the descents from different altitudes As Ben stated below, it takes practice and getting to know your plane very well. Much depends on the height of the engine failure, or emergency. Having plenty of altitude and time to consciously make decisions is quite different from close to the ground where your subconscious and ingrained training can save your life. I've mentioned it before and so did some one in this thread; with an engine failure on departure, my hands were taking care of lowering the nose, and flaps while I was looking over the situation. Basically by the time I could think it out I had already done what I needed to do. Lower the nose, evaluate landing options, go full flaps, fuel valve shut off, switches off, and I was on roll out. to be at 1000' agl heading downwind and abeam the touchdown point. Seems like most of the time I was doing them last year, it was hit or miss. (perhaps a poor choice of words). Nah, sounds appropriate. Trying to put all the variables together to put the aircraft in the right place at the right time on a consistent basis is still an elusive endeaveor. Do you experienced pilots just have a sixth sense about how to get the aircraft exactly where it needs to be? Is it something you consciously analyze throughout the descent or just instinctlvely do? I'd certainly not call it a sixth sense. The term, experienced does imply traits ingrained by...experience/practice, not some paranormal sense.. When I took pilot proficiency training, we'd end up with AT LEAST 3 simulated engine failures per flight. Best glide, pick a spot, evaluate the situation and try for a restart if possible. Two full days of intensive flying and at least one day with 10 hours of class room. Ingrained a lot of habits. One of the things emphasized was not to keep changing your mind after picking a spot. Of course it's possible you discover that green field is corn and the one a little ways over is bare, or possibly the bare field is freshly plowed. From high up you have time to think and make decisions. Oft times there is a tendency to over think and thus get into trouble. Kirk PPL-ASEL It just takes years of flight time and alot of practice. When flying you need to consciously analyze everything from the time you untie the plane till it's tied back down again. Best practice I have found for spot landings is to visit an out of the way small airport and pick a spot on the runway and fly the plane right to that spotseveral times, I tend to spiral down keeping close in, always keeping the landing site in view, and using slips where necessary. FULL flaps once the landing spot is made. I had this on a flight review immediately after some hood work. Hoods off, your engine quit, find a place to land. We were at 4000, it was 5 miles to the airport, airport elevation is 630 MSL, best glide is 120 at roughly 600 fpm. I chose the airport and had to slip aggressively to make the runway. Actually I put it down and stopped within 900 feet of the touchdown end of the runway. using both directions if the wind is not too strong will help you compansate for any drift/ tailwind componant, gusts,etc. The fact that you asked the question shows your sincere desire for getting it right. That's a good trait for a pilot.... :-) I think he's off to a good start. Roger (K8RI) Ben |
"Kirk Ellis" wrote in message ... After dealing with the doctors and the FAA for the last six months I finally got my class 3 renewed. It's been a year since I last flew. and I can't believe how fast that time went by. So this month I am getting back into the cockpit and in addition to all of the standard maneuvers, I feel I especially need to work on emergency off-field landings. I've had my ticket for over 8 years, but financial concerns always seem to keep me from flying as much as I would like. So I do not get to practice as much as I should. Which brings me to the point of this post. While doing emergency off-field landing practice I am still trying to get some consistency in planning the descents from different altitudes to be at 1000' agl heading downwind and abeam the touchdown point. Seems like most of the time I was doing them last year, it was hit or miss. (perhaps a poor choice of words). Trying to put all the variables together to put the aircraft in the right place at the right time on a consistent basis is still an elusive endeaveor. Do you experienced pilots just have a sixth sense about how to get the aircraft exactly where it needs to be? Is it something you consciously analyze throughout the descent or just instinctlvely do? Kirk PPL-ASEL There is no rule that says you have to fly a rectangular pattern. Vary it a bit and see how it works. My solution is to plan things so I'm always high on the base leg. That way, I can overshoot the base leg, fly S-turns, and perform other energy and altitude bleeding maneuvers to hit my target landing area. |
On Oct 14, 9:44 pm, Kirk Ellis
wrote: After dealing with the doctors and the FAA for the last six months I finally got my class 3 renewed. It's been a year since I last flew. and I can't believe how fast that time went by. So this month I am getting back into the cockpit and in addition to all of the standard maneuvers, I feel I especially need to work on emergency off-field landings. I've had my ticket for over 8 years, but financial concerns always seem to keep me from flying as much as I would like. So I do not get to practice as much as I should. Which brings me to the point of this post. While doing emergency off-field landing practice I am still trying to get some consistency in planning the descents from different altitudes to be at 1000' agl heading downwind and abeam the touchdown point. Seems like most of the time I was doing them last year, it was hit or miss. (perhaps a poor choice of words). Trying to put all the variables together to put the aircraft in the right place at the right time on a consistent basis is still an elusive endeaveor. Do you experienced pilots just have a sixth sense about how to get the aircraft exactly where it needs to be? Is it something you consciously analyze throughout the descent or just instinctlvely do? Kirk PPL-ASEL No it is not a sixth sense. It is the right combination of numbers and sight picture. Sight picture only helps when you are fairly low (ie 500' AGL) and on final approach. During downwind or base you don't have a good sight picture to tell whether you are going to be too high or too low. You have to rely on your altimeter and use several 'target' altitudes until you turn final. I use 1000' for the abeam- point, 800' for turning base and 600' for turning final. How you get down to 1000' is completely up to you, but you have to be facing the right direction at the right altitude. If you are doing 360's to lose altitude you should know how much altitude is lost in one turn. You have several tools at your disposal to control altitude such as flaps, airspeed and slip. On a normal approach (with power on) I aim for 400-500' for turning final. The trick is not to nail everything precisely, but to learn to identify deviations and make early corrections so that you don't get too far off track. After turning final, you do everything based on sight picture. Aim for 1/3 down the runway, but when you get close and the landing is assured, slip or flap aggressively to put it down on the numbers. |
Andrew Sarangan schrieb:
No it is not a sixth sense. It is the right combination of numbers and sight picture. Sight picture only helps when you are fairly low (ie 500' AGL) and on final approach. During downwind or base you don't have a good sight picture to tell whether you are going to be too high or too low. You have to rely on your altimeter and use several 'target' altitudes until you turn final. I disagree. Of course the alitmeter can be very helpful, but only if you know the ground elevation and if you are sure your current altimeter setting is correct. As this is often not the case, think in angles. Angles stay the same regardless of height and distance. |
'target' altitudes until you turn final. I disagree. Of course the alitmeter can be very helpful, but only if you know the ground elevation and if you are sure your current altimeter setting is correct. Correct. Additionally, altimeter will tend to stick with engine off. Glider pilots are taught to ignore altimeter during circuit and landing. Bartek |
brtlmj schrieb:
Glider pilots are taught to ignore altimeter during circuit and landing. Guess why I suggested the "looks about right" method... ;-) |
brtlmj wrote:
Correct. Additionally, altimeter will tend to stick with engine off. WHAT? |
| Thread Tools | |
| Display Modes | |
| Emergency landing at airfield | Danny Deger | Piloting | 10 | January 8th 07 07:31 PM |
| Emergency landing theoretical | gatt | Piloting | 21 | May 15th 06 04:07 PM |
| Live emergency landing on tv right now | C. Massey | Piloting | 7 | May 4th 06 03:49 AM |
| C-141 emergency landing Christchurch | Miche | Military Aviation | 11 | February 6th 04 05:04 AM |
| N30793, Emergency Landing | Tom Hughes | Piloting | 5 | August 21st 03 04:56 AM |
