#31
![]() "Bill Daniels" bildan@comcast-dot-net wrote For Dan's earlier question about performance at altitude, what I hear from Bob is that it looks pretty good. His real concern was restarts at altitude. He made a big improvement in that by switching from glo-plugs to spark igniters. As I understand it, the micomputer engine controller senses altitude and adjusts the engine to adapt. I also hear that the life of the engine, and especially the bearings (the most prone to need replaced first) have been much improved in many brands of engines, and that the little engines run happily for many hours. Some of the engines out there are getting pretty big, and with big thrust values to go along with it. I'm thinking that a pair of them would make self launching possible; if not completely unassisted, with an auto towing down the runway to, say, 30 or 40 feet of altitude? Then, if a cruise at the same altitude was needed to get home, or whatever, one could be shut down. -- Jim in NC |
#32
![]() "Morgans" wrote in message ... "Bill Daniels" bildan@comcast-dot-net wrote For Dan's earlier question about performance at altitude, what I hear from Bob is that it looks pretty good. His real concern was restarts at altitude. He made a big improvement in that by switching from glo-plugs to spark igniters. As I understand it, the micomputer engine controller senses altitude and adjusts the engine to adapt. I also hear that the life of the engine, and especially the bearings (the most prone to need replaced first) have been much improved in many brands of engines, and that the little engines run happily for many hours. Some of the engines out there are getting pretty big, and with big thrust values to go along with it. I'm thinking that a pair of them would make self launching possible; if not completely unassisted, with an auto towing down the runway to, say, 30 or 40 feet of altitude? Then, if a cruise at the same altitude was needed to get home, or whatever, one could be shut down. -- Jim in NC I think the whole thing is coming together. The neat thing is most of these engines only cost a few thousand dollars. Yes, they are thirsty but the sailplane application is unique in that they need not run very long. One thing seldom mentioned is that these little turbines whine at 150,000 RPM is way above human hearing. All you hear is the exhaust roar and that isn't too loud. Takeoff will be a problem until we get workable afterburners. (It's been done.) You'd only need the re-heat for a few seconds until liftoff. Another takeoff aid that has been proposed is a bungee launch. Although everybody in the know says the jet exhaust from a single piggyback engine aimed at the fin doesn't do any harm, I'd like a little more information on that. Bill Daniels |
#33
On Oct 17, 3:26 pm, "Bill Daniels" bildan@comcast-dot-net wrote:
"cavelamb himself" wrote in message ... Bill Daniels wrote: It's been done. Bob Carlton has an airshow act with a jet sailplane. Jet sailplanes may well have a real future. Although the specific fuel efficiency of model airplane dog whistles is terrible, (but improving) mating them with an extremely efficient airframe seems to work really well. Some 'back of the envelope' calcualtions show that a single RC model microjet in the 50 Lb thrust range would push my glider along at well over 100 knots. The 75 gallon wing tanks normally used for water ballast would provide a very nice range. If the 'dog whistle' quits, just retract it an you still have a 50:1 glide ratio. Bill Daniels Bill Daniels And what might those back of the envelope calculations say about climb rate??? Not bad, around 300 - 400 FPM. The problem is the takeoff roll. I would expect that with full tanks at a gross weight of 1422 pounds, full throttle wouldn't move the glider from a standstill. Even if the glider started rolling, the wing runner had better be able to do a 4-minute mile - the acceleration to an airspeed where I had reasonable aileron authority would take a fair amount of time and distance. I'd plan to use an aero tow or a winch launch before air-starting the engines. Bill Daniels- Hide quoted text - Think "upper surface blowing" and several across each wing. Does make retraction a problem though. |
#34
In article .com,
John Keeney wrote: On Oct 17, 3:26 pm, "Bill Daniels" bildan@comcast-dot-net wrote: "cavelamb himself" wrote in message ... Bill Daniels wrote: It's been done. Bob Carlton has an airshow act with a jet sailplane. Jet sailplanes may well have a real future. Although the specific fuel efficiency of model airplane dog whistles is terrible, (but improving) mating them with an extremely efficient airframe seems to work really well. Some 'back of the envelope' calcualtions show that a single RC model microjet in the 50 Lb thrust range would push my glider along at well over 100 knots. The 75 gallon wing tanks normally used for water ballast would provide a very nice range. If the 'dog whistle' quits, just retract it an you still have a 50:1 glide ratio. Bill Daniels Bill Daniels And what might those back of the envelope calculations say about climb rate??? Not bad, around 300 - 400 FPM. The problem is the takeoff roll. I would expect that with full tanks at a gross weight of 1422 pounds, full throttle wouldn't move the glider from a standstill. Even if the glider started rolling, the wing runner had better be able to do a 4-minute mile - the acceleration to an airspeed where I had reasonable aileron authority would take a fair amount of time and distance. I'd plan to use an aero tow or a winch launch before air-starting the engines. Bill Daniels- Hide quoted text - Think "upper surface blowing" and several across each wing. Does make retraction a problem though. Think RATO... -- Alan Baker Vancouver, British Columbia "If you raise the ceiling four feet, move the fireplace from that wall to that wall, you'll still only get the full stereophonic effect if you sit in the bottom of that cupboard." |
Century Ic Pinout | Grandmaster | Owning | 1 | November 28th 06 03:18 PM |
KR-21 pinout | Tri-Pacer | Piloting | 0 | September 9th 06 02:37 AM |
Pinout for StormScope WX-900 | epotenziani | Products | 0 | August 22nd 05 08:32 PM |
KAA 455 pinout | Mike Rapoport | Owning | 0 | February 28th 05 12:57 AM |
RT-540A pinout help | Billc851 | Home Built | 1 | December 12th 04 04:27 PM |
