On 22 Oct, 22:33, John Smith wrote:
Brian wrote: Frightening? Really? It actually works very well with a bit of head wind. Backcountry power pilots occasionally use this technique as well. It's a completely different thing in a power plane. (Although I wouldn't recommend it with power planes, either.) A short look at a typical glider polar is all that is needed to understand why your "technique" is a no-no. If you continue using it, then it's only a question of time that we'll hear about you in the news. Anyone tried option 4? Stuffing the nose right down for 3 or 4 seconds will easily lose you 50m or more with only a small increase in airspeed since Newton gets involved in the exercise. A bit of increased spoiler will overcome that increase quickly. What's more you are playing with the safe side of the energy curve! To the poster who said that condor may not be a good tool to test this. I suggest you try a copy. It really is a great sim and the flight dynamics are superb. I believe that Lasham gliding club took one ab-initio student right to solo standard on a sim before one or two real circuits to get him away. Sims have come a long way. Ian M |
On Oct 23, 6:30 am, nimbusgb wrote:
....snip... To the poster who said that condor may not be a good tool to test this. I suggest you try a copy. It really is a great sim and the flight dynamics are superb. I believe that Lasham gliding club took one ab-initio student right to solo standard on a sim before one or two real circuits to get him away. Sims have come a long way. Ian M I am planning on buying a copy and for general flying and basic training I see great value in simulators. But the original posting was about doing a flight test to determine performance such as descent rates with spoilers extended, turns back to the airport, etc. Any such data requires that not only does the simulator have all the right aerodynamics models, but that it has complete and accurate data for your specific model of glider. I doubt that Condor has test flown every glider model extensively enough to confirm the accuracy of their results. BTW, I program flight simulators for SIkorsky AIrcraft. One of my bosses has a rule "all simulators are guilty until proven innocent" Todd Smith |
On Oct 22, 9:12 am, Nyal Williams
Forward slip in glass gliders won't get you much descent; The ASW-19 and ASW-28 have a huge increase in sink rate in a full rudder slip compared with airbrakes alone. What glass gliders are you flying that do not slip well? Can you maintain a full rudder slip, and I mean rudder on the stop and never comes off it until you choose to exit the slip? Andy |
I first learned it in Minden and then refined it in
Cal City. What the objecters have not realized is just how fast you can bleed off tons of excess speed by lifting the nose to the horizon with full spoilers out. And again, the maneuver need not necessarily be carried out to the threshold, even, much less to the round out. You can use it to bleed off 200ft or 500ft when you are at 1000ft on final [No, this is not the everyday pattern or practice] and then you can lift the nose and lose the speed when it looks like you are at the normal height for that distance from the touchdown point. When the speed drops to proper approach speed you just adjust the spoilers and continue as normal. Once you have done it it no longer appears to be a dare-devil ride; it is entirely predictable. At 00:12 23 October 2007, 5z wrote: On Oct 22, 4:52 pm, Tom Gardner wrote: And I take the point that it's not usually necessary to finish the manoeuvre at ground level. IMHO, it's useful to demonstrate this on final approach, but a better place to apply it in real life would be earlier in the landing pattern. For example huge amounts of lift on downwind, so dive off the altitude on base. In the US southwest, where downbursts and the associated huge sink and sometimes lift can happen, I've found myself turning a high final expecting 40-50 knots headwind and it's vanished. I've also experienced huge lift on base / final as the outflow curl decided to position itself right at the end of the runway. So these are the cases where I might be tempted to use the dive while on final approach. -Tom |
Nyal Williams wrote:
I first learned it in Minden and then refined it in Cal City. What the objecters have not realized is just how fast you can bleed off tons of excess speed by lifting the nose to the horizon with full spoilers out. The objectors are pointing that there are some gliders whose spoilers don't produce quite enough drag to manage this maneuver effectively. In a glider that has effective spoilers (like a Ventus B) it's a blast. But, in my experience (which were usually at 8000+ foot density altitude), a Duo will accelerate rather quickly in a dive with full spoilers, then take you halfway down the runway while you bleed off 15 or 20 knots of excess speed, even out of ground effect. If you bleed it off more quickly, you're going up. I found a slipping turn to final that is held for as long as needed to be far more effective. Your mileage may vary... Marc |
Certainly there are some gliders with inadequate divebrakes.
A modification was applied to the Cirrus. I've not flown a Duo; perhaps it needs a mod; thin airfoils are not conducive to installing wide vertical plates. At 02:12 23 October 2007, Marc Ramsey wrote: Nyal Williams wrote: I first learned it in Minden and then refined it in Cal City. What the objecters have not realized is just how fast you can bleed off tons of excess speed by lifting the nose to the horizon with full spoilers out. The objectors are pointing that there are some gliders whose spoilers don't produce quite enough drag to manage this maneuver effectively. In a glider that has effective spoilers (like a Ventus B) it's a blast. But, in my experience (which were usually at 8000+ foot density altitude), a Duo will accelerate rather quickly in a dive with full spoilers, then take you halfway down the runway while you bleed off 15 or 20 knots of excess speed, even out of ground effect. If you bleed it off more quickly, you're going up. I found a slipping turn to final that is held for as long as needed to be far more effective. Your mileage may vary... Marc |
as an ex Duo owner I agree with Dave Nadler and Bill
Daniels; the Duo airbrakes are better than their reputation: The manual says the give a glide angle of 6.7:1 (which fits with my measurements of 800fpm descent rate) at approach speed which isn't barn door but should be adequate. My D2cT manual quotes the same approach glide angle (I observe the same sink rate of 800fpm) - and reviewers assess the D2c airbrakes as very good. I made the same observation as Bill about the Duo brakes taking a couple of seconds for the drag to build up - I thought it had something to do with a more turbulent airflow as the trim changes nose down with the brakes deployed(??) The Duo airbrakes need a very strong pull to fully open them - but this is aided on later ones by a mod to the control linkage (also available as a simple retrofit) Also, our Duo was delivered with the airbrake lever actuated hydraulic wheel brake picking up well before full airbrake and I initially found it almost impossible to pull full airbrake - it is easy to adjust the wheelbrake and this, along with the linkage mod, helped a lot. However our wheel brake was so effective that if the glider touched down on grass with the wheel brake fully on then the wheel didn't turn and the glider bounced as if it had hit a rock. As a result I always had to close the airbrakes a little before touch down which increased float. John Galloway At 15:18 23 October 2007, Bert Willing wrote: There are other big heavier gliders with lots of inertia, and they react very well and immediately to the deployment of airbreaks. Those on the original DuoDiscus are just a very bad design. But, as Marc pointed out, a sideslip works well AND gets you a visual on the airfield from the back seat (the second very bad design glitch of the Duo). Bert 'Bill Daniels' wrote in message I think the Duo's airbrakes are better than many people think. The Duo is a big heavy glider with lots of inertia. It doesn't like to change direction quickly. That includes its behavior on sudden airbrake deployment. You don't get a lot of sink right away. My first reaction was that the airbrakes were weak but a little more experience showed me that with a little patience, the brakes took effect and produced a respectable decent rate. The Duo just makes you plan ahead a little more than with a light single seater. Bill Daniels |
John Galloway schrieb:
The manual says the give a glide angle of 6.7:1 (which fits with my measurements of 800fpm descent rate) at approach speed Very interesting, indeed: JAR 22.75 Descent, approach It must be shown that the sailplane has a glide slope not flatter than one in seven at a speed of 1·3 VS0 with air brakes extended at maximum weight. |
John Galloway wrote:
as an ex Duo owner I agree with Dave Nadler and Bill Daniels; the Duo airbrakes are better than their reputation: Well, clearly, not all current and former Duo owners agree. Perhaps I'm used to gliders with very effective spoilers, including various DG models, ASW20s, Ventus Bs, etc. But, after 200 or so hours in our Duo (and a couple of others in the area), I'll simply say that the spoilers were workable with proper approach planning and airspeed, and that it remains the only glider I've ever felt the need to slip on a routine basis... Marc |
On Oct 23, 2:00 pm, Marc Ramsey wrote:
John Galloway wrote: as an ex Duo owner I agree with Dave Nadler and Bill Daniels; the Duo airbrakes are better than their reputation: Well, clearly, not all current and former Duo owners agree. My 2c: (Our club has a duo, so based on some experience.) The actual glide angle of the duo, with full spoilers out and at a stable approach speed, is decently steep. Looking at this angle at altitude is instructive. The duo seems not to lose speed as quickly as other gliders when you open the spoilers, especially in ground effect. "Too high" really often means "too fast". I think a lot of the perception that the duo has poor divebreakes is realy that it does not slow down fast, rather than the actual steady state glide angle is shallow. This all makes some aerodynamic sense. The duo is heavier than basic trainers, and much heavier than the single seaters we are used to. "Spoilers" work as much by "spoiling lift" as by "increasing drag", and much of the latter is induced drag due to the gap in the lift distribution anyway. John Cochrane |
MA-8 with parachute extended S63-00693.jpg | [email protected] | Aviation Photos | 0 | April 10th 07 02:52 PM |
spoilers vs. ailerons | [email protected] | Piloting | 36 | August 8th 05 11:24 AM |
Frozen spoilers | stephanevdv | Soaring | 0 | November 4th 04 05:24 PM |
Extended GPX Schema | Paul Tomblin | Products | 0 | September 25th 04 02:44 AM |
L-13 Spoilers | Scott | Soaring | 2 | August 27th 03 06:08 AM |
