#31
Judah wrote:
Dudley Henriques wrote in : Judah wrote: Dudley Henriques wrote in : You DO realize of course that by bringing this up you have opened a whole new source of potential revenue for Al Sharpton and Jesse Jackson????????? :-)) So long as there are no Black aircraft that have been specifically attacked by White aircraft this should not be an issue. Well....could be......and I know Twanna Brawley isn't an airplane, and she most certainly wasn't attacked, but lo and behold......who shows up to "save the day and "make it all right again" but Sharpton!!!! :-)) DH Tawana Brawley claimed to have been raped, which certainly made Sharpton see Green. The allegations were later proved untrue and everyone involved (especially Sharpton) walked away quite Red-faced. I'm Green enough that before the incident, I saw the world through Rose- colored glasses. Quite frankly, this whole talk about Sharpton and Jackson is just a Red herring anyway, because they are both too Yellow to ever fly an airplane. I just hope this conversation doesn't give them the Green light to start profiteering from the aviation industry. Blue skies... I do believe this thread is getting to be quite colorful. -- Dudley Henriques |
#32
![]() "B A R R Y" wrote in message ... On Sat, 3 Nov 2007 09:31:29 -0400, "Morgans" wrote: Fiberglass airplanes almost demand it. If they get too hot, the epoxy gets hot, and gets weak. Very weak. Some of the new Cirrus versions are not white. Are they cured in autoclaves? Epoxy can be designed to stay stronger at higher temperatures, but generally, they are then required to cure in autoclaves, with the high temperature and pressure making the higher yield temperatures possible. -- Jim in NC |
#33
![]() It gives the manufacturer more options in selecting trim colors, just as all Boeing jets come out of the factory green. I thought Boeing jets come out of the factory covered in Zinc Chromate rather than paint? I thought Zinc Chromate is green. At least the Zinc Chromate I have is green. Right; and the problem (or reason) for that statement is...? -- Jim in NC |
#34
On 3 Nov, 21:26, Tony wrote:
No Jay, black is more absorbant and more emissive than a shiny surface. If it's sun light heating you're trying to reduce, you'd want to reflect away the energy with a reflective surface. If, though, the thing you're worried about is hotter than its surroundings and you are interested in radiating the heat away, you'd want increased emissivity, and make it black. A black body radiater is considered perfect, and it is very black indeed. On Nov 3, 5:22 pm, Jay Honeck wrote: I did read recently that the SR-71 was black to reduce the surface temperature by increasing radiation away from the aircraft. silverf sur ??? I thought black increased surface temperature? Mixed top and bottom posts -oh dear. I thought black increased surface temperature? It depends - is the most complete answer. I don't have a canned response but I will try to make something up. I think that it is true to say that a black surface both accepts incoming radiation more effectively and also radiates more effectively than a white surface. If you had an aeroplane with a heater inside it would be warmer inside (in any particular experimental setup) if it was white than if it was black. The SR-71 has an internal heater (even though the source is external air the heat we care about ends up inside the structure) that is heating it up and it is cooled more effectively if it is black. This is of course counterbalanced by a greater absorbtion of solar radiation but this effect is insignificant compared to the heating power (I incorrectly refered to enengy earlier but it is power - the rate of energy transfer - that matters here) delivered by the aerodynamic heating at mach whatever. In the case of a light aircraft where aerodynamic heating is negligable the incoming solar radiation effect dominates and white is cooler. By the way I don't know for a fact that the surface finish makes any difference to the outgoing radiation. I have heard that it does but I don't know from first hand measurements or through any reliable schooling (which would presumably have involved first hand measurements). I do know that it affects the absorbed radiation, well that's obvious to anybody. Finally, parked on the tarmac a SR-71 would be cooler if painted white. If you plan to take your machine to mach 3, better start planning that new paint job now. |
#35
![]() "Dudley Henriques" wrote I do believe this thread is getting to be quite colorful. I must say that I like it a lot more than the other recent thread that took a definite "brown" tone to it! -- Jim in NC |
#36
![]() "Richard Riley" wrote If you're talking about this one http://www.maddyhome.com/cozy/chapter?c=25&s=5 It's the same data, just recharted. No, I'm almost certain it was a study made by the fiberglass boat people. This version of the data is a bit easier to see, so that is a good thing. g The thing that really stuck out from the study that I remember is that there was a larger jump from white to yellow, even. It really pointed out why white is so important if you don't want solar gain. I don't know why it would be any different than the study you listed, and from how the data was gathered, I would imagine that this data is more accurate. Of course, it would also make a big difference in "how yellow" the yellow is, too. A very intense yellow could well be more heat absorbing than a "mellower yellow." g -- Jim in NC |
#37
better start planning that new paint job now. Dang. And here I just shot my budget on that Pulsar installation. Guess Atlas' new Mach 3.3 ablative paint will have to wait... ;-) -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
#38
Morgans wrote:
"Dudley Henriques" wrote I do believe this thread is getting to be quite colorful. I must say that I like it a lot more than the other recent thread that took a definite "brown" tone to it! Yes, that one DID seem to enhance a certain spirit of "comoderie" around here :-)) -- Dudley Henriques |
#39
![]() "Dudley Henriques" wrote Yes, that one DID seem to enhance a certain spirit of "comoderie" around here :-)) Well, that's one way to put it. I think the thread stunk! g -- Jim in NC |
#40
Morgans wrote:
"Dudley Henriques" wrote Yes, that one DID seem to enhance a certain spirit of "comoderie" around here :-)) Well, that's one way to put it. I think the thread stunk! g You win. I'm eating a Baby Ruth!!! -- Dudley Henriques |
Does it have to WHITE!!! | firstflight | Home Built | 33 | July 26th 05 06:17 PM |
Why are airplanes white? | gatt | Piloting | 30 | July 21st 04 02:55 PM |
*White* Helicopters??!!! | Stephen Harding | Military Aviation | 13 | March 9th 04 07:03 PM |
White over white is alright? | Ron Natalie | Piloting | 3 | July 16th 03 05:24 PM |
white lightning | mansour | Home Built | 16 | July 10th 03 08:46 PM |
