#31
![]() There you go, think outside the box! I was thinking about some substance that could be used that a small amount of matter when reacted would produce a large amount of "controllable" gas. Forget about plugging it in each night, just drop in a cartridge or something. (Hey I'm just an idea man - you work out the details) Carbide (like was formerly used in miner's headlamps)? David Johnson |
#32
![]() No. it has an optional gas-powered kicker motor that also recompresses the carbon-fiber air tanks. Just caught something about it on television the other day. Plus, it's loud as hell; sounds like somebody's driving an air compressor. Noisy they are. I have been around air tuggers (large winches) in marine operations, and also air starters for diesels. Deafening. David Johnson |
#33
Despite all these problems, though, I would think it would be much
easier to get a steam engine to work with actual steam than with compressed air. -- Waddling Eagle World Famous Flight Instructor No one seems to be designing anything to run on steam anymore - despite it's being a proven technology that will operate on any source of heat. Is high maintenence the reason? Or is it high initial cost? David Johnson |
#34
Dave wrote:
Despite all these problems, though, I would think it would be much easier to get a steam engine to work with actual steam than with compressed air. -- Waddling Eagle World Famous Flight Instructor No one seems to be designing anything to run on steam anymore - despite it's being a proven technology that will operate on any source of heat. Is high maintenence the reason? Or is it high initial cost? Well, other than the energy efficiency is pretty poor, they take relatively forever to start up, and boilers are heavy and dangerous, they would work just fine to run a car as long as you have a coal tender. The Army doesn't use crossbows or the trebuchet any more either and they're also proven technology. -- Jim Pennino Remove .spam.sux to reply. |
#35
#36
Dave wrote in
: There you go, think outside the box! I was thinking about some substance that could be used that a small amount of matter when reacted would produce a large amount of "controllable" gas. Forget about plugging it in each night, just drop in a cartridge or something. (Hey I'm just an idea man - you work out the details) Carbide (like was formerly used in miner's headlamps)? Carbide produced Acetylene. I wouldn;'t care to try and run a IC engine on acetylene! I have used it in lamps however and the light they produce is brilliant! Bertie |
#37
#38
#39
In article
, Dave wrote: Despite all these problems, though, I would think it would be much easier to get a steam engine to work with actual steam than with compressed air. -- Waddling Eagle World Famous Flight Instructor No one seems to be designing anything to run on steam anymore - despite it's being a proven technology that will operate on any source of heat. Is high maintenence the reason? Or is it high initial cost? David Johnson Poor energy efficiency. Steam partitions the power generation from the heat source -- you lose energy in the transformation processes. |
#40
On Nov 15, 10:06 pm, Bertie the Bunyip wrote:
Dave wrote in news:97dd61d9-9e9e-46f0-9034- : Despite all these problems, though, I would think it would be much easier to get a steam engine to work with actual steam than with compressed air. -- Waddling Eagle World Famous Flight Instructor No one seems to be designing anything to run on steam anymore - despite it's being a proven technology that will operate on any source of heat. Is high maintenence the reason? Or is it high initial cost? It's a PITA for a car which is why it died out in the early years of the last century. You had to go out and light the fire 20 minutes before you went driving. The simple cars like the Stanley had no condensers and you had to top them up with water after about 30 miles and the cars that recycled like the White were extremely complex to operate (even the stanleys were pretty daunting) The performance was amazing, though and they are smooth and almost silent. Serpollet held the land speed record several times and that was taken off them once or twice by electric cars IIRC. In the end the convienience of the IC engine won out after they were simplified enough to be easy for almost anyone to use. Steam lasted up to about 1930 for at least one make (I think it was Doble), White lasted up at least through the first war with steam (they still exist , of course) and Stanley into the 20s I believe. Nifty contraptions and beautiful pieces of engineering.. Bertie Here is some steam power for you: http://www.youtube.com/watch?v=aphQNGOz7v8 |
Compressed air as fuel? | Dancing Fingers | Home Built | 15 | July 14th 07 07:20 AM |
Electric DG | Robbie S. | Owning | 0 | March 19th 05 03:20 AM |
Pre-Rotator Powered by Compressed Air? | nuke | Home Built | 8 | July 30th 03 12:36 PM |
Pre-Rotator Powered by Compressed Air? | Gil G. | Rotorcraft | 9 | July 30th 03 12:36 PM |
Pre-Rotator Powered by Compressed Air? | nuke | Rotorcraft | 0 | July 28th 03 12:52 AM |
