Are 100% electric ultralights around?
Old November 20th 07, 03:47 AM posted to rec.aviation.homebuilt
Morgans[_2_]
Default Are 100% electric ultralights around?
"Wayne Paul" wrote
Put the Sonex electric power plant in a Xenos register it as a glider;
and, get a glider rating with a self launch log book endorsement. Problem
solved.
Can't argue with that.
I don't have a problem with an electric motor in an airplane, as long as it
makes sense.
In the current state of technology, electric makes no sense for a power
airplane. Not for the foreseeable future.
That all changes once you get to an electric motor in a sailplane. That
makes great sense. It is an improvement from a sailplane without a motor.
That's what it looks like to me, anyway.
The only thing that is a problem with the electric self launch sailplane
now, is the price. Ouch.
It's a hefty price to pay, to have the coolest toy on the block! g
  #32
Old November 20th 07, 03:57 AM posted to rec.aviation.homebuilt
Frank Stutzman[_2_]
Morgans wrote:
My point was, try telling the FAA that a NON glider could not divert or wait
for the airport to re-open because it had no reserve, and the pilot knew
there was no reserve, and see what they think of that.
Here is a bit of FAR trivia...
Find a referance in the FARs states that it is illegal
to land at a closed airport.
Other than the usual "careless or reckless" clause in part 91, I've
never found anything that prohibits it.
Frank Stutzman
Bonanza N494B "Hula Girl"
Boise, ID
  #33
Old November 20th 07, 04:46 AM posted to rec.aviation.homebuilt
"Morgans" wrote in message
Problem solved.
it makes sense.
Of course there are some of us who think the challenge of the sport of
soaring is vastly diminished with the addition of any engine. The sense of
accomplishment gained from completing a pre-defined 300
(http://tinyurl.com/2wkox8) or 500km triangle is wonderful. The only thing
more wonderful is a 750 or 1000km flight.
Oh, Oh, I have digress to far from the subject of this thread; however, you
can get a lot of fun for the dollar by simply flying an old restored
homebuilt sailplane.
HP-14 "6F"
http://www.soaridaho.com/Schreder
Nampa, Idaho
  #34
Old November 20th 07, 05:58 AM posted to rec.aviation.homebuilt
Morgans[_2_]
Yes, but it would seem to me (a non soaring type, but considering it in the
future) that the common thread of soaring is that you have to get up, first.
You could use self discipline, and agree on the altitude you want to self
launch to, then go from there without using the engine, again. Then the
challange would be the same.
A bunch of people with self launch ability could launch nearly
simultaniously, then really mix it up!
Can't do that with any other launch form, I would think.
you can get a lot of fun for the dollar by simply flying an old restored
I know it probably would be sacrilege, but you could add a self launch
electric motor onto an old restored sailplane. That might be a fun
challenge!
  #35
Old November 20th 07, 07:06 AM posted to rec.aviation.homebuilt
the future) that the common thread of soaring is that you have to get up,
first. You could use self discipline, and agree on the altitude you want
to self launch to, then go from there without using the engine, again.
Then the challange would be the same.
It would seem to be the same; however, the ability to start an engine does
affect the way you approach a mountainous wilderness area. Knowing you have
the ability to start an engine subconsciously, if not consciously, becomes
part of the decision process when you are close to the rocks with few
landing sites available.
http://www.soaridaho.com/Schreder/HP...0_Borah_Mt.jpg
http://www.soaridaho.com/Schreder/HP...ackay_ID_1.JPG
http://tinyurl.com/2p464s
We do that now. The first to launch wait in a local thermal for the rest of
the group to arrive, then we all head out on the agreed course.
challenge!
True, it would be a challenge not the least of which is the sailplane's max
gross weight. Cost is also a factor. Just how much are you going to be
willing to invest in a 40 year old $10,000 glider?
http://tinyurl.com/32yhew
HP-14 "6F"
  #36
Old November 20th 07, 08:19 AM posted to rec.aviation.homebuilt
cavelamb himself[_4_]
challenge!
Not fun at all!
Weight and balance.
Structural issues for the battery load.
where to put the motor and prop so as to not screw up the aerodymanics.
Sounds to me like a good way to ruin a fine flying machine.
YMMV
Richard
  #37
Old November 20th 07, 11:25 AM posted to rec.aviation.homebuilt
Vaughn Simon
"Frank Stutzman" wrote in message
That is an interesting question, but the answer may pivot on who "closed" the
airport and why. For one thing, airport management is not ATC.
Also, if you arrived at a closed field with barely legal reserves and then
passed up a safe (albeit closed) landing site for an uncertain trip to some
"open" landing site, what would the FAA/NTSB have to say about your decision?
Vaughn
  #38
Old November 20th 07, 04:47 PM posted to rec.aviation.homebuilt
Morgans[_2_]
then passed up a safe (albeit closed) landing site for an uncertain trip
to some "open" landing site, what would the FAA/NTSB have to say about
your decision?
It would seldom be the case that there is not an airport within 30 minutes
cruise, unless perhaps some places out west, or in Alaska.
Correct me if I'm wrong, someone, but isn't 30 minutes a minimum figure, but
you are supposed to have 30 minutes, or enough fuel to make an alternative
airport, which ever is greater?
If it isn't that way, it should be.
  #39
Old November 20th 07, 07:39 PM posted to rec.aviation.homebuilt
Mike Bamberg
your decision?
There is no requirement that you land with any fuel on board, only
that you PLAN the flight so that you have 30 minutes (daytime, VFR)
reserve fuel at the point of first intended landing. If in fact you
incounter "unexpected" circumstances then the only thing the FAA may
ask is what changed after your planning was done.
MB, CFI, CFII ,MEI, ad nauseum
Ultralights in Space? DABEAR Home Built 9 February 12th 07 08:26 PM
Best engine for ultralights Josip General Aviation 5 August 27th 04 06:02 PM
one medical away from Ultralights Gilan Owning 7 May 22nd 04 12:54 AM
one medical away from Ultralights Gilan Piloting 7 May 22nd 04 12:54 AM
Ultralights photo Mirco Landini Home Built 4 September 17th 03 06:08 AM
