#31
On 4 Dez., 16:48, wrote:
On Nov 28, 12:32 pm, wrote: may be someone is interested in a small programm (http://ywtw.de/igcsim.html ) that allows you to replay IGC-files in Google Earth. It's a replay, without use of kml, best for flights in the mountains :-) Tobi, This is an absolutely brilliant add-on! Thanks so much for making it available. Please keep us posted on upgrades. Larry thanks for the kind comments. There is an upgrade available ( full time control, realtime drift eliminate for those who want to synch with seeyou and more). Probably there will be further upgrades during the winter, but not in spring and summer at all. You may take a fast look from the Help-Menu. Bye Tobias |
#32
Tobias, this is an absolutely brilliant piece of work! Thank you so
much for writing it and offering it to the gliding community. -John On Nov 28, 3:32 pm, wrote: may be someone is interested in a small programm (http://ywtw.de/igcsim.html ) that allows you to replay IGC-files in Google Earth. It's a replay, without use of kml, best for flights in the mountains :-) |
#33
On Dec 4, 1:33 pm, "Roger Kelly" wrote:
Great tool! Will it accept any other file format as input? I have an old Garmin unit which will produce mapsource files - either .gdb or tab delimited text. I know Gps Visualizer will convert some file types but I don't see .igc as an available output file type. You can convert the *.gdb files to *.igc files with g7towin.exe. A web search should find the source. Andy |
#34
On Nov 28 2007, 9:41 pm, "
wrote: On Nov 28, 5:15 pm, " wrote: On Nov 28, 2:18 wrote: sorry, I should have mentioned, you need Google Earth 4.2 and the current .NET installed It falls over with an immediate null reference exception on Windows XP SP2 on my ThinkPad. Anybody want the stack trace? email me. No cigar. I've got Google Earth 4.2 and the .NET 3.0 Framework with the very latest updates. When you say the current .NET exactly what version and update are you running against? On what OS platform? I'm on XP SP2 at the very latest public release updates. Anybody else got this to run? Darryl BTW a quick check with the debugger showed this apparently uses .NET 2.0, so you don't need to waste time downloading the NET 3.0 bloatware. I've emailedTobithe debug information. Darryl Tobias found the problem with his code and .NET strangeness on my laptop, seems like it may have affect some other laptops as well. Anyhow it is all working great on my ThinkPad now. Thanks Tobias for this great utility! Darryl Ramm |
#35
On Jan 1, 9:22 am, "
wrote: On Nov 28 2007, 9:41 pm, " wrote: On Nov 28, 5:15 pm, " wrote: On Nov 28, 2:18 wrote: sorry, I should have mentioned, you need Google Earth 4.2 and the current .NET installed It falls over with an immediate null reference exception on Windows XP SP2 on my ThinkPad. Anybody want the stack trace? email me. No cigar. I've got Google Earth 4.2 and the .NET 3.0 Framework with the very latest updates. When you say the current .NET exactly what version and update are you running against? On what OS platform? I'm on XP SP2 at the very latest public release updates. Anybody else got this to run? Darryl BTW a quick check with the debugger showed this apparently uses .NET 2.0, so you don't need to waste time downloading the NET 3.0 bloatware. I've emailedTobithe debug information. Darryl Tobias found the problem with his code and .NET strangeness on my laptop, seems like it may have affect some other laptops as well. Anyhow it is all working great on my ThinkPad now. Thanks Tobias for this great utility! Darryl Ramm Darryl, So does that mean there's an updated application to download from Tobias' site? I've been using it with a thinkpad, too, still think it's an absolutely great program but have noticed some strangeness, too. Thanks, Larry |
#36
On Jan 1, 8:15 pm, wrote:
On Jan 1, 9:22 am, " wrote: On Nov 28 2007, 9:41 pm, " wrote: On Nov 28, 5:15 pm, " wrote: On Nov 28, 2:18 wrote: sorry, I should have mentioned, you need Google Earth 4.2 and the current .NET installed It falls over with an immediate null reference exception on Windows XP SP2 on my ThinkPad. Anybody want the stack trace? email me. No cigar. I've got Google Earth 4.2 and the .NET 3.0 Framework with the very latest updates. When you say the current .NET exactly what version and update are you running against? On what OS platform? I'm on XP SP2 at the very latest public release updates. Anybody else got this to run? Darryl BTW a quick check with the debugger showed this apparently uses .NET 2.0, so you don't need to waste time downloading the NET 3.0 bloatware. I've emailedTobithe debug information. Darryl Tobias found the problem with his code and .NET strangeness on my laptop, seems like it may have affect some other laptops as well. Anyhow it is all working great on my ThinkPad now. Thanks Tobias for this great utility! Darryl Ramm Darryl, So does that mean there's an updated application to download from Tobias' site? I've been using it with a thinkpad, too, still think it's an absolutely great program but have noticed some strangeness, too. Thanks, Larry There was an update recently, it at least fixed a .NET startup problems on some laptops where the application would crash as I described earlier. I am guessing that is very unlikely to be related to any other problems - except Tobias told me that the left hand control panel may size wrong on laptop displays but can just be changed manually. I have no idea what other things if any changed. Why don't you try the latest build anyhow and then email him a description of the strangeness you are seeing. He is very responsive. Darryl |
#37
On Jan 2, 10:25 am, "
wrote: On Jan 1, 8:15 pm, wrote: On Jan 1, 9:22 am, " wrote: On Nov 28 2007, 9:41 pm, " wrote: On Nov 28, 5:15 pm, " wrote: On Nov 28, 2:18 wrote: sorry, I should have mentioned, you need Google Earth 4.2 and the current .NET installed It falls over with an immediate null reference exception on Windows XP SP2 on my ThinkPad. Anybody want the stack trace? email me. No cigar. I've got Google Earth 4.2 and the .NET 3.0 Framework with the very latest updates. When you say the current .NET exactly what version and update are you running against? On what OS platform? I'm on XP SP2 at the very latest public release updates. Anybody else got this to run? Darryl BTW a quick check with the debugger showed this apparently uses .NET 2.0, so you don't need to waste time downloading the NET 3.0 bloatware. I've emailedTobithe debug information. Darryl Tobias found the problem with his code and .NET strangeness on my laptop, seems like it may have affect some other laptops as well. Anyhow it is all working great on my ThinkPad now. Thanks Tobias for this great utility! Darryl Ramm Darryl, So does that mean there's an updated application to download from Tobias' site? I've been using it with a thinkpad, too, still think it's an absolutely great program but have noticed some strangeness, too. Thanks, Larry There was an update recently, it at least fixed a .NET startup problems on some laptops where the application would crash as I described earlier. I am guessing that is very unlikely to be related to any other problems - except Tobias told me that the left hand control panel may size wrong on laptop displays but can just be changed manually. I have no idea what other things if any changed. Why don't you try the latest build anyhow and then email him a description of the strangeness you are seeing. He is very responsive. Darryl The new update has speed and thermal indicators and a skip thermals function. Continues to improve with each update. For future updates a choice of units for speed and thermals would be great. Tim |
#38
For future updates
a choice of units for speed and thermals would be great. Tim, there is a new Build available with imperial units, diagrams and more. http://www.ywtw.de/igcsimen.html Tobias |
#39
On Jan 25, 4:35 am, tobi wrote:
For future updates a choice of units for speed and thermals would be great. Tim, there is a new Build available with imperial units, diagrams and more.http://www.ywtw.de/igcsimen.html Tobias Tobias, Thank you. The update is great. Tim |
#40
Agreed! Very cool! Thanks for creating it!
Paul Remde "Tim Taylor" wrote in message ... On Jan 25, 4:35 am, tobi wrote: For future updates a choice of units for speed and thermals would be great. Tim, there is a new Build available with imperial units, diagrams and more.http://www.ywtw.de/igcsimen.html Tobias Tobias, Thank you. The update is great. Tim |
Google Earth | Frank Whiteley | Soaring | 3 | November 16th 07 12:36 AM |
Google Earth fun | Al Denelsbeck | Aviation Photos | 4 | January 11th 07 04:31 PM |
Google Earth - Glider | David Pye | Soaring | 1 | June 8th 06 04:39 PM |
SeeYou 3D and Google Earth | [email protected] | Soaring | 4 | May 23rd 06 04:24 AM |
Google Earth | ttaylor at cc.usu.edu | Soaring | 8 | September 22nd 05 12:07 PM |
