Refuting blackbird folklore
Old December 2nd 03, 01:29 AM
Chad Irby
"Brian" wrote:
Missiles like the SA-12/20 and SM-2 have incredibly high speeds and
altitudes.....the SR-71 is not in a favorable position being up in the sky
with no clutter around. If it could reach M3.2 on the deck, there would be
more problems with targeting.
You have to remember that the SAM-20 tops out at about 4600 MPH, about a
third faster than the SR-71, which makes it a *lot* easier to spoof the
missile's radar, and doesn't give it enough of a speed advantage to make
a strong chance of catching a Mach-3+ aircraft from behind.
They *do* have a much better chance to hitting one nowadays, which is
part of the reason you wouldn't see many SR-71-type planes anywhere near
the big SAM sites. Or why there's that persistent rumor about an SR-71
followup out there...
cirby at cfl.rr.com
Remember: Objects in rearview mirror may be hallucinations.
Slam on brakes accordingly.
  #33
Old December 2nd 03, 02:14 AM
Scott Ferrin
Why the fixation of hitting the aircraft from behind? The idea with a
SAM is to hit the target from the front BEFORE it's dropped it's bombs
or hit the target. The reason I think the Bomarc would have a fair
chance is because it certainly had the altitude and head to head it
doesn't have to chase it down. They'd have seen it far enough out and
with that 400 plus mile range it's going to be at speed and altitude
well before the Blackbird would be overhead. Hell even the limited
maneuvering the Blackbird could do at Mach 3 wouldn't help it because
the Bomarc had the energy to maneuver too.
  #34
Old December 2nd 03, 02:52 AM
Chad Irby
Because about half of all engagements with long-range missiles happen
from the rear aspect, or from the side (which can be worse in some
cases). Very few aircraft drivers are going to run right down the
throat of a radar when they can sit off to one side and make the missile
work harder. Even with a very long range (400 kilometer) SAM, you have
to have about a 50% overlap with the systems on either side to make sure
you have good coverage, or the penetrating aircraft will just look at
signal strengths on their RWR and drive in between, forcing that
long-range tail chase (or avoiding your engagement ranges altogether).
Even at 7200 KPH, you're looking at a delay of a couple of minutes to
get out to a couple of hundred klicks, which can be a problem when the
target is doing 2/3 of that speed, jamming madly.
Most countries have no chance of affording to cover their entire border
with high-speed, high-altitude, long-range missile sites, especially
places like the former Soviet Union. Sure, you could ring your major
cities with them, but even that's too expensive in the long run. Even
putting one next to each major military target gets pretty darned
expensive.
....and if you do, and you turn those radars on at any time, you get
"tagged" for later attention, which is death on the modern battlefield.
Big radars and fast missiles are great in some cases, but they're easy
targets. They move slowly and they're easy to kill.
cirby at cfl.rr.com
  #36
Old December 2nd 03, 03:40 AM
Peter Stickney
(The Enlightenment) writes:
(Peter Stickney) wrote in message ...
(frank wight) wrote in message . com...
SNIP
The SR71 is limited in speed by the shock wave from the nose of the
aircraft impinging on the inlet lip of the engines over about Mach
3.5. The dash speed of the aircraft is not limited by either engine
thrust or or short term thermal issues.
Theoreticaly the A12 should be faster becuase of its shorter nose.
Uhm, Bernie -
Frederick actualy. Bernxard is my spanish blue cat. I use his email.
But it's pronounced Raymond Luxury-Yacht.
Bright cat.
If one of the limiting factors in an A-12/SR-71's speed
is shock impingement, (Which it is, a;though IIRC it's shoc
impingement on the leading edges of the wings, not the nacelles), how
is a shorter nose going to give you a higher Mach Number? A longer
nose would allow a steeper included angle. (Y'know, all that Opposite
vs. Adjacent stuff from High School Trig.) Unless, of course, Shock
Waves work backwards in Australia?
You got me there.
The shockwave story re impingingment on the nacels I though I read in
a review of sled driver published in Air International.
Are you sure its wing tips? The solution I think is in a protractor
and a photocopy of and SR71 outline.
Yep. That's how I figured it out. The wingtips would be impinged upon
first, then the chines on the outboard sides of the nacelles, then the
outer nafelle lip. Of course, you'd get some complicated shock
interactions going on in the region of the nacelle, so simple
straightedge and protracter stuff is only approximate.
There's a whole bunch of stuff going on that would limit the max speed
to somewhere between Mach 3.2 - 3.5. The shock impingement stuff, the
air temperature at the compressor face, the ability of the fuel to
carry heat away from critical components pop into mind at a first
stab. Those factors all meet at or about Mach 3.5.
Pete Stickney
A strong conviction that something must be done is the parent of many
bad measures. -- Daniel Webster
  #37
Old December 2nd 03, 06:40 AM
The Enlightenment
(Kevin Brooks) wrote in message . com...
(robert arndt) wrote in message . com...
Chad Irby wrote in message . com...
(robert arndt) wrote:
Funny how the all-white Mach 3 XB-70 seemed to hold up to kinetic
heating all right... and that was just simple nuclear anti-flash
white.
They did that by using a fairly scary system of pipes that ran through
high-heat areas, and used the plane's fuel as a heat sink, combined with
extensive use of titanium in the worst spots.
In a combat-ready version, you can safely assume that they would have
used the "iron ball" black paint for radar reduction and heat protection.
"Iron Ball" black paint was derived from the Third Reich's
radar-absorbing "Schornsteinfeger" (Chimney Sweep) carbon paint meant
for the Go-229 jet flying wing.
Rob
Geeze, you probably think the integrated circuit and microprocessor
were both derived from Nazi research, huh? What is it with this
Pavlovian reaction you demonstrate to all things (allegedly) Germanic?
It's quite possible that German research in this area influenced or
inspired later western work.
The Germans were using a sort of rubberised ironball for u-boat
snorkels and conning towers. Screens were also carried on board
u-boats that could be errected around the conning tower. Finaly the
Go 229 was to recieve a sort of carbon black based 3-ply skin that had
RAM properties and the aircraft showed use of re enterant structures.
Surely opperation paperclip must have made use of some of this or been
aware of German approaches to the issue.
German pre war doctrine held that radar or radio emisions would reveal
one to the enemy and empphsised passive techniques and this may have
influenced their neglect at maintaining their lead in radar.
It has to be rememberd that Randle and Boots magnetron was developed
because they wanted a cheap radar emiter for the detector and
direction finder they were developing.
If they had of been given a bigger budget they may not have stumbelled
upon it.
As far as Germans inventing the integrated circuit goes? Well that
never happened but it might have because an ex Luftwaffe technician
may actualy have invented a transistor. It's quite a sad story
actualy:
http://home.t-online.de/home/Benduhn/summary.htm
  #39
Old December 2nd 03, 10:00 AM
Keith Willshaw
"The Enlightenment" wrote in message
om...
. com...
. com...
. com...
Hardly since the Germans didnt actually do any work in this area.
The Germans's fell far behind the allies in terms of electronics
and electronic warfare as the war progressed.
The transistor came out of work done at Bell Labs that began in
1939 by Russel Ohl and the IC was invented at Texa Instruments
by Jack Kilby.
Hardly , the german countermeasures were almost entirely ineffective
since they were working on the assumption that allied radars
were operating in the metre band rather than the centimetric
radar that was actually being used.
That would be Randall and Boot who developed the cavity
magnetron at Birmingham University in 1940.
The Germans also developed active radar systems and Telefunken
had been working on just such a device as early as 1935 but had
been unable to get even close to the efficiencies and power levels
that Randall and Boot achieved.
upon it.
actualy:
What it describes is interesting but its not a transistor but a cold cathode
tube and that was first demonstrated by Philo Taylor Farnsworth II in 1934
Its entirly possible that your ex Luftwaffe technician was aware if it since
an article in Radio by Arthur Halloran described it in detail in the
issue published in October 1934.
http://www.borderlands.com/archives/arch/multipact.htm
The claim that the first tubeless radio was built in 1948 is so
wrong its farcical. The crystal set was common in the 1920's.
Keith
  #40
Old December 2nd 03, 11:46 AM
M. J. Powell
In message , Keith Willshaw
writes
snip
actualy:
The oscillating crystal was also discovered in the '20's.
M.J.Powell
SR- 71/ Blackbird lore Larry Dighera Military Aviation 28 July 31st 03 02:20 PM
Blackbird lore Air Force Jayhawk Military Aviation 3 July 26th 03 02:03 AM
