Has there ever been an off-center gun?
Old December 9th 03, 01:20 AM
"Bob Martin" wrote:
Of course, I
also seem to recall that the shell basically traces a straight line
from barrel to "effective range", and doesn't need drop factored in.
Eh?... surely you're not saying that the rounds don't drop in
flight?...I hope?...
Well, I know the firing barrel is centered laterally, but I think the gun
itself may be angled down a couple degrees (though still passing through the
center of gravity of the aircraft, so as to not produce any pitching
moment), though probably not more than 2 or 3. This would help with gun
tracking and make strafing runs a little safer.
As far as the "straight line" from the barrel... the muzzle velocity of the
GAU-8/A is such that, although the bullets do drop in flight (to not do so
would either imply lift being generated, or laws of physics being violated),
the drop is considered negligible, and therefore the gunsight is a simple
fixed reticle in the HUD.
For example... at 4000 feet, the bullets will only drop about 10
feet--random dispersion will be greater than that.
But that puts the centre of the dispersion pattern ~ten feet
below the aim point at that range doesn't it?
-Gord.
  #32
Old December 9th 03, 01:31 AM
Tarver Engineering
"B2431" wrote in message
It amazes me I can't remember 24 hours ago yet I can remember 35 years
ago.
Yet the rest of us are amazed when you make up things from 35 years ago,
Dan.
  #33
Old December 9th 03, 04:30 AM
Bob Martin
Yeah, but that's only about a sixth of a degree of arc...
also, a tank is what, 6-8 feet tall at least? Ten feet at that range is
very little to be concerned about... anyways, the point being that gravity
drop is less of a factor with the GAU-8 than with other guns.
  #35
Old December 9th 03, 06:01 AM
John Keeney
"Cub Driver" wrote in message
This is wonderful. Can either of you or anybody point me to more
information about this service?
I realize there are only 12 issues of Geographic a year, but it would
help if I could narrow it down.
I've read about the same technique being used in Oz for back country
mail.
  #38
Old December 9th 03, 04:56 PM
Jeb Hoge
"Bob Martin" wrote in message ...
Right, that was basically it. Operationally speaking, at ranges where
the A-10 intiates/presses an attack, the GAU-8 fires a straight shot.
I also remember a graphic detailing muzzle velocity of the 23mm round
from the ZSU versus from a GAU-8, and it showed that if a Hog and a
ZSU fired accurate rounds at each other at the same exact time, the
ZSU died first and the Hog could (conceivably) jink before the 23mm
arrived. Pretty neat stuff, if somewhat idealized.
  #39
Old December 9th 03, 05:32 PM
I see...that's interesting...how do they do that? (your last
sentence I mean)
-Gord.
"I'm trying to get as old as I can,
and it must be working 'cause I'm
the oldest now that I've ever been"
  #40
Old December 9th 03, 11:56 PM
Bob Martin
Gord Beaman wrote in message
gravity
sentence I mean)
That's what I've been trying to explain... the bullets from the GAU-8 go
faster and therefore drop less for a given range than do bullets from other
guns. The smaller the drop, the easier it is to compensate for. In the
case of the A-10, the drop is so small that, for practical purposes, the
bullets go in a straight line.
Aircraft Walkaround Center alive and well, new URL Voigt Lander Military Aviation 7 December 10th 03 04:16 PM
Center vs. Approach Altitudes Joseph D. Farrell Instrument Flight Rules 8 October 21st 03 08:34 PM
Aircraft Walkaround Center update, new section Robert Lundin Military Aviation 0 August 30th 03 08:12 PM
PACAF’s Hawaii air ops center sets new goals while adding 109 positions Otis Willie Military Aviation 0 August 20th 03 09:44 PM
