#31
#32
RST Engineering wrote:
No chocks, only tiedowns could have kept that aircraft from moving. Chocks aren't perfect. At my home field we often get violent downbursts from thunderstorms in the summer. Peak gusts of 60-70 kts aren't unusual. I use both chocks and tiedowns, and I've found that after a particularly bad storm, the chocks were often blown away from wheels and the plane was sitting slightly sideways with the tiedowns pulled tight. John Galban=====N4BQ (PA28-180) -- Message posted via AviationKB.com http://www.aviationkb.com/Uwe/Forums...ation/200712/1 |
#33
On Dec 28, 12:05*pm, Bertie the Bunyip wrote:
"Robert M. Gary" wrote in news:5d5a8261-1459-465f-9e7e- : On Dec 27, 10:32*pm, Bertie the Bunyip wrote: The best reason I can think of for not relying on the parking brake in a wind is that they are not very reliable. Schwinn could make a better arrangement than you see on most Cessnas, for instance. Brakes are next to useless in very high winds anyway. After all, if the wing is being lifted.... I've never had occasion to stand on an airplane's brake but when I use the same amount of foot pressure on my Mooney as in my Saturn the Saturn will stop in 1/2 the distance. Well, you have twice the wheels, dontcha? But about 1/2 the weight. The Saturn weights 4300 lbs. -Robert |
#34
On Dec 28, 1:28*pm, "JGalban via AviationKB.com" u32749@uwe wrote:
No chocks, only tiedowns could have kept that aircraft from moving. * Chocks aren't perfect. * They may not be perfect but close. The chocks typicaly used on airlines could have prevented this. There are no provisions for tying down a jet. The 737 manual does recommend leaving the parking brake set in windy conditions. -- Message posted via AviationKB.comhttp://www.aviationkb.com/Uwe/Forums.aspx/aviation/200712/1 |
#35
The best reason I can think of for not relying on the parking brake in a wind is that they are not very reliable. Schwinn could make a better arrangement than you see on most Cessnas, for instance. Brakes are next to useless in very high winds anyway. After all, if the wing is being lifted.... Not to mention we're talking winter here. I've been at the controls of a 172, engine idling, foot brakes fully applied, and been pushed sideways across an icy ramp by the wind. Found out later a Citation (I think - some small bizjet) had slid off a taxiway. In Iowa, no less. Proving it not only sucks there, it also blows... |
#36
: On Dec 28, 12:05*pm, Bertie the Bunyip wrote: "Robert M. Gary" wrote in news:5d5a8261-1459-465f-9e7e- : On Dec 27, 10:32*pm, Bertie the Bunyip wrote: The best reason I can think of for not relying on the parking brake in a wind is that they are not very reliable. Schwinn could make a better arrangement than you see on most Cessnas, for instance. Brakes are next to useless in very high winds anyway. After all, if the wing is being lifted.... I've never had occasion to stand on an airplane's brake but when I use the same amount of foot pressure on my Mooney as in my Saturn the Saturn will stop in 1/2 the distance. Well, you have twice the wheels, dontcha? But about 1/2 the weight. The Saturn weights 4300 lbs. -Robert He heh. I was only kidding. it's an apples oranges thing anyway. Bertie |
#37
Rich Ahrens wrote in
ouse.com: Bertie the Bunyip wrote: The best reason I can think of for not relying on the parking brake in a wind is that they are not very reliable. Schwinn could make a better arrangement than you see on most Cessnas, for instance. Brakes are next to useless in very high winds anyway. After all, if the wing is being lifted.... Not to mention we're talking winter here. I've been at the controls of a 172, engine idling, foot brakes fully applied, and been pushed sideways across an icy ramp by the wind. Wow, you're almost like a seaplane in those conditions. Found out later a Citation (I think - some small bizjet) had slid off a taxiway. In Iowa, no less. Proving it not only sucks there, it also blows... Bwawhahwhahwhhahwh! Bertie |
#38
"F. Baum" wrote in
: On Dec 28, 1:28*pm, "JGalban via AviationKB.com" u32749@uwe wrote: No chocks, only tiedowns could have kept that aircraft from moving. * Chocks aren't perfect. * They may not be perfect but close. The chocks typicaly used on airlines could have prevented this. There are no provisions for tying down a jet. The 737 manual does recommend leaving the parking brake set in windy conditions. hmm, I think you may be mistaken about the tie down provisions. I've never seen anthing except the tug/towbar thng you mentioned, but I think some may have a spot where a ring can be screwed in , maybe where the hardpoints for the jacks go. I'll ask the guys next chance I get. Bertie |
#39
F. Baum wrote:
On Dec 27, 4:18 pm, "Bob Gardner" wrote: While its possible that someone does it, I'm not aware of any operator that sets the brake on aircraft when its not occupied. Usually chalks work just fine and are easier to move when you need to tow. In smaller aircraft there are other reasons to avoid setting the brake, like changes in outside pressure could burst the brake seals. -Robert Robert, out of everyone so far you are the closest. The brakes are released as soon as the chalks in signal is recieved. This is mainly done to facilitate brake cooling because airlines typicaly work with 45 minute turn times and leaving them set would greatly increase QTA The brake temp actually peaks about 10 minutes after landing .the fuse plugs can melt if the brake are left set . The 737 has a brake acumulator which will sufice for several parking brake applications, but chalks are still used for safety reasons . Just before push the process is reversed, The parting brake is set before the tug is hooked up and the chalks removed. Someone ask about brake pressures; the A&B hydraulics run at 3000 LBS which is reduced to 300 at the gear (In the event of a leak this prevents a total loss of fluid) I was not able to open the link but I hope this helps. FB Chalks. Ha, ha, ha... That is hilarious. |
#40
Mike Beede wrote:
In article , wrote: I've heard this many times and yet can imagine no situation other than maybe leaving the brakes on for months at a time where it would do anything. I was told during primary training that if you left the parking brake on the pads could rust to the disks or drum and make it hard to get moving. Don't know if that's realistic or not, but chocks and tiedowns work a lot better for a small plane anyway. That is much more plausible than the "temperature change will blow the seals excuse." I agree that tiedowns are best and chocks are fine for most conditions, but aren't as good as the brakes being set. If a gust of wind causes a chock jump, then the plane will keep on moving with nothing to restrain it. If the brakes are set, then even a gust that slides the tires won't keep the airplane moving once the gust subsides. The main reason I know of that most people park airplanes with the brakes released is to facilitate movement of the airplane when the owner isn't around. Matt |
Proof FAA Managers are full blown certified IDIOTS | SOS | Instrument Flight Rules | 1 | December 1st 07 05:05 AM |
Proof FAA Managers are full blown certified IDIOTS | SOS | Piloting | 1 | November 29th 07 07:44 PM |
Ramp riders 5 | Paul | Aviation Photos | 0 | November 19th 06 10:09 PM |
MMU ramp fee | Peter Gottlieb | Piloting | 25 | August 9th 03 12:49 AM |
Flight TWA 800 was shot down/blown up by Al Quadea? | Tiger | Military Aviation | 0 | July 3rd 03 05:38 PM |
