#31
"Ken S. Tucker" wrote in
: On Feb 4, 6:53 am, wrote: On Feb 3, 9:05 pm, "Marc J. Zeitlin" wrote: Any aircraft in which the CG can be ahead of the AIRCRAFT AC, but behind the main wing AC. There are many aircraft that when flown at rear CG positions and low speeds will have the tail producing lift. Gliders, in particular. Off the top of my head, I don't know of any in particular, although I remember being told that a C-172 will have an upforce on the tail at low speeds and rear CG. Can't cite it, though. Even with the CG at its most aft position, a 172's AC is still behind the CG. CG range is typically 25-33% of MAC, while AC is around 40%. The web site I indicated: http://www.av8n.com/how/htm/aoastab.html explains all this. That's a good site that I've used for more than four years. I think we're talking about two different things here and there's a misunderstanding that leads to argument. I find a fairly widely-held opinion that the aft CG can be (legally) at or behind AC. This isn't true for any "modern" lightplane. FAR 23.173 requires that the airplane return to trimmed speed after being slowed or accelerated using pitch inputs only and releasing them; this won't happen in a CG-behind-AC situation. As the wing slows its AC moves forward due to the breakup of the boundary layer toward the trailing edge, the CG therefore ends up even farther behind the AC, the situation gets worse as the nose rises with the forward-moving AC, and it eventually stalls. This is what I meant by the illegality of a lifting tail. Here's an example of some common miperceptions:http://answers.yahoo.com/question/index?qid= 2008 0109225927AAfYZDU Even the first answer, the one the voters liked, says that the CG is 12" ahead of the AC even in the most-aft position, This is extreme; it's a lot less than that, but it's still forward. Other posters think that with the CG at the aft position the tail must produce lift. Dan My experiments with models vindicate Dan's explanation where a conventional planform is concerned. Setting the CG = AC can cause a screwy stall, such as nose pitch-up. Sorry Dan, but that pretty much wraps it up. Ken agrees with you. You need to crack the books! Bertie |
#33
On Feb 4, 12:41 pm, Bertie the Bunyip wrote:
wrote : On Feb 4, 8:48 am, Bertie the Bunyip wrote: wrote innews:dad75380-7e0e-40c6-965a- om: On Feb 3, 9:05 pm, "Marc J. Zeitlin" wrote: Any aircraft in which the CG can be ahead of the AIRCRAFT AC, but behind the main wing AC. There are many aircraft that when flown at rear CG positions and low speeds will have the tail producing lift. Gliders, in particular. Off the top of my head, I don't know of any in particular, although I remember being told that a C-172 will have an upforce on the tail at low speeds and rear CG. Can't cite it, though. Even with the CG at its most aft position, a 172's AC is still behind the CG. CG range is typically 25-33% of MAC, while AC is around 40%. We're not talking about a 172. Bertie OK. I'll leave now. Why? Ken likes you! Seriously, I know what you're talking about, but your head is stuck in the standard issue light airplane. You're not exactly wrong, but you're missing the point. The OP is talking about putting an airplane together, not loading one up. Bertie I suppose I missed the point. But it disturbs me that Ken agrees with me. Either he's right for once or I'm way off base. Dan |
#34
wrote I suppose I missed the point. But it disturbs me that Ken agrees with me. Either he's right for once or I'm way off base. The fact that he makes this determination based on his observation of model planes further reinforces his lack of real and tangible knowledge of the subject at hand. And anyway, even a stopped clock is right once (or twice) per day. I would be disturbed, too. Don't take it too hard, though. It was a lucky guess. -- Jim in NC |
#35
On Feb 4, 12:09 pm, wrote:
On Feb 4, 12:41 pm, Bertie the Bunyip wrote: wrote : On Feb 4, 8:48 am, Bertie the Bunyip wrote: wrote innews:dad75380-7e0e-40c6-965a- om: On Feb 3, 9:05 pm, "Marc J. Zeitlin" wrote: Any aircraft in which the CG can be ahead of the AIRCRAFT AC, but behind the main wing AC. There are many aircraft that when flown at rear CG positions and low speeds will have the tail producing lift. Gliders, in particular. Off the top of my head, I don't know of any in particular, although I remember being told that a C-172 will have an upforce on the tail at low speeds and rear CG. Can't cite it, though. Even with the CG at its most aft position, a 172's AC is still behind the CG. CG range is typically 25-33% of MAC, while AC is around 40%. We're not talking about a 172. Bertie OK. I'll leave now. Why? Ken likes you! Seriously, I know what you're talking about, but your head is stuck in the standard issue light airplane. You're not exactly wrong, but you're missing the point. The OP is talking about putting an airplane together, not loading one up. Bertie I suppose I missed the point. But it disturbs me that Ken agrees with me. Either he's right for once or I'm way off base. Dan Berties OP wasn't bad, but it's primitive. He ignored (or is ignorant) of Rutan twisting the main wings on his Veri-Eze 4degrees +, at the tip. That "feeds-back" in the CL to pull it backward to alleviate the CL going forward when the main begins stalling at the hip, that Dan (the BIG HEAD) described surprisingly well. Score +1 for BIG HEAD, Bertie -1. What I do is calculate the CL off the geometry of the model A/C adjust the CG and fly them. Saves a lot of crashing and burning. Ken PS: Dan, you thawing out your nuts yet? |
#36
"Bertie the Bunyip" wrote: Ken agrees with you. Eeewww! Usenet cooties! |
#37
On Feb 4, 1:39 pm, "Ken S. Tucker" wrote:
On Feb 4, 12:09 pm, wrote: On Feb 4, 12:41 pm, Bertie the Bunyip wrote: wrote : On Feb 4, 8:48 am, Bertie the Bunyip wrote: wrote innews:dad75380-7e0e-40c6-965a- om: On Feb 3, 9:05 pm, "Marc J. Zeitlin" wrote: Any aircraft in which the CG can be ahead of the AIRCRAFT AC, but behind the main wing AC. There are many aircraft that when flown at rear CG positions and low speeds will have the tail producing lift. Gliders, in particular. Off the top of my head, I don't know of any in particular, although I remember being told that a C-172 will have an upforce on the tail at low speeds and rear CG. Can't cite it, though. Even with the CG at its most aft position, a 172's AC is still behind the CG. CG range is typically 25-33% of MAC, while AC is around 40%. We're not talking about a 172. Bertie OK. I'll leave now. Why? Ken likes you! Seriously, I know what you're talking about, but your head is stuck in the standard issue light airplane. You're not exactly wrong, but you're missing the point. The OP is talking about putting an airplane together, not loading one up. Bertie I suppose I missed the point. But it disturbs me that Ken agrees with me. Either he's right for once or I'm way off base. Dan Berties OP wasn't bad, but it's primitive. He ignored (or is ignorant) of Rutan twisting the main wings on his Veri-Eze 4degrees +, at the tip. Correction that should be -4 degrees. The wing tip has a REDUCED AoA. A 1000 pardons.... That "feeds-back" in the CL to pull it backward to alleviate the CL going forward when the main begins stalling at the hip, that Dan (the BIG HEAD) described surprisingly well. Score +1 for BIG HEAD, Bertie -1. What I do is calculate the CL off the geometry of the model A/C adjust the CG and fly them. Saves a lot of crashing and burning. Ken PS: Dan, you thawing out your nuts yet? |
#38
wrote in
: On Feb 4, 12:41 pm, Bertie the Bunyip wrote: wrote innews:da30af89-15c1-4b7b-8841- om: On Feb 4, 8:48 am, Bertie the Bunyip wrote: wrote innews:dad75380-7e0e-40c6-965a- om: On Feb 3, 9:05 pm, "Marc J. Zeitlin" wrote: Any aircraft in which the CG can be ahead of the AIRCRAFT AC, but behind the main wing AC. There are many aircraft that when flown at rear CG positions and low speeds will have the tail producing lift. Gliders, in particular. Off the top of my head, I don't know of any in particular, although I remember being told that a C-172 will have an upforce on the tail at low speeds and rear CG. Can't cite it, though. Even with the CG at its most aft position, a 172's AC is still behind the CG. CG range is typically 25-33% of MAC, while AC is around 40%. We're not talking about a 172. Bertie OK. I'll leave now. Why? Ken likes you! Seriously, I know what you're talking about, but your head is stuck in the standard issue light airplane. You're not exactly wrong, but you're missing the point. The OP is talking about putting an airplane together, not loading one up. Bertie I suppose I missed the point. But it disturbs me that Ken agrees with me. Either he's right for once or I'm way off base. Well, you are and you aren't. If you put a lifting stab and an aft CG in a 172 it's not going to be a happy airplane. You have to include the lifting stab as a wing in it's own right.. Bertie |
#39
#40
: On Feb 4, 1:39 pm, "Ken S. Tucker" wrote: On Feb 4, 12:09 pm, wrote: On Feb 4, 12:41 pm, Bertie the Bunyip wrote: wrote innews:da30af89-15c1-4b7b-8841- legrou ps.com: On Feb 4, 8:48 am, Bertie the Bunyip wrote: wrote innews:dad75380-7e0e-40c6-965a- om: On Feb 3, 9:05 pm, "Marc J. Zeitlin" wrote: Any aircraft in which the CG can be ahead of the AIRCRAFT AC, but behind the main wing AC. There are many aircraft that when flown at rear CG positions and low speeds will have the tail producing lift. Gliders, in particular. Off the top of my head, I don't know of any in particular, although I remember being told that a C-172 will have an upforce on the tail at low speeds and rear CG. Can't cite it, though. Even with the CG at its most aft position, a 172's AC is still behind the CG. CG range is typically 25-33% of MAC, while AC is around 40%. We're not talking about a 172. Bertie OK. I'll leave now. Why? Ken likes you! Seriously, I know what you're talking about, but your head is stuck in the standard issue light airplane. You're not exactly wrong, but you're missing the point. The OP is talking about putting an airplane together, not loading one up. Bertie I suppose I missed the point. But it disturbs me that Ken agrees with me. Either he's right for once or I'm way off base. Dan Berties OP wasn't bad, but it's primitive. He ignored (or is ignorant) of Rutan twisting the main wings on his Veri-Eze 4degrees +, at the tip. Correction that should be -4 degrees. The wing tip has a REDUCED AoA. Either way, it;s irrelevant. Bertie |
| Thread Tools | |
| Display Modes | |
| Yaw control in a tandem rotor helo? | Capt.Doug | Piloting | 0 | January 14th 07 01:02 AM |
| Yaw control in a tandem rotor helo? | Chris W | Piloting | 3 | January 13th 07 01:04 AM |
| Yaw control in a tandem rotor helo? | Morgans | Piloting | 1 | January 12th 07 11:26 PM |
| Yaw control in a tandem rotor helo? | Stealth Pilot | Piloting | 0 | January 12th 07 03:38 PM |
| Tandem Mi-26? | PDR | Military Aviation | 6 | June 6th 04 11:49 AM |
