Powering JSF: One Engine Is Enough.
Old February 11th 08, 09:01 PM posted to rec.aviation.military.naval
Andrew Venor
Default Powering JSF: One Engine Is Enough.
R.C. Payne wrote:
Dean A. Markley wrote:
Lexington Institute.
http://lexingtoninstitute.org/docs/797.pdf
That'll be little consolation to the pilot who experiences an total
engine failure 300 miles from the carrier!
Seriously though, It is nothing short of incredible how reliability
has increased in engines and aircraft. I'd still worry just a little
bit though....
In the days of piston engines, no serious fighter had more than one
engine.
I think all the pilots who flew P-38 Lightnings might disagree with that
statement.
ALV
  #32
Old February 11th 08, 09:28 PM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
Tex Houston[_2_]
"R.C. Payne" wrote in message
engine. In more recent naval aviation, the Harrier seems to have been
reasonably successfully operated with a single engine. It is indeed
astounding how reliable modern jet engines are.
Robin
Dick Bong, Tommy McGuire and Rex Barber ring a bell? We bought 10,037 of
those 'non serious' fighters during WW-II. WW-II? It was in the papers.
Tex Houston
  #33
Old February 11th 08, 09:34 PM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
Ed Rasimus[_1_]
On Mon, 11 Feb 2008 19:36:05 +0000, "R.C. Payne"
Robin
One doesn't need to restrict the argument to piston engines.
Consider F-84, F-86, F-100, F-102, F-104, F-105, F-106, or maybe
MiG-15,17,21,23,27, or possibly Mirage 3, 5, or A-4, A-7, F-8.
To name just a few.
And, my basic argument is that if the engine loss is due to battle
damage, I've never seen the second engine survive the demise of the
first. Having one engine provides less plumbing to be battle damaged,
and with A/B the aft section of the engine doesn't really care what
the front is doing as long as the airflow continues.
Ed Rasimus
Fighter Pilot (USAF-Ret)
"When Thunder Rolled"
www.thunderchief.org
www.thundertales.blogspot.com
  #36
Old February 12th 08, 04:18 AM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
Gernot Hassenpflug[_2_]
Ian MacLure writes:
"dott.Piergiorgio" wrote in
Ed Rasimus ha scritto:
And, don't even get started on the one engine versus two engine
aircraft business. Single engine fighters have been doing quite nicely
for decades....ooops, make that more than a century.
More a century, yes, for *aircrafts* ; for *fighters* I guess we're
still 5-7 years prior of a century of Fighters.... (depend on one's
interpretation of what bird was the first Fighter...)
Uh Dottore, thats "aircraft" not "aircrafts". Plural same as
singular. Like "moose" and "moose".
Not to worry Dottore, my best friend, and Israeli, constantly says
"sheeps" for the plural of "sheep" which is absolutely hilarious: "See
any sheeps today?" As we're often referring to the ridiculous attire
of Japanese girls for wedding receptions, where the slightly shorter
than Western legs attached to a sinking bottom are poking out from
under a fluffed-up dress, and similarly puffed-up hairstyles decorate
the top. You get the idea!
BOFH excuse #402:
Secretary sent chain letter to all 5000 employees.
  #37
Old February 12th 08, 04:21 AM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
Default First Fighter Plane?
" writes:
I think about the first really decent fighters were the ones that
could fire two guns through the prop. Two seat aircraft with a guy in
back with a single gun just didn't make the cut.
Sooo, that means F-4Es, F-105F/Gs, F-14s, F-16B/Ds, F-18B/D/Fs, and
Tornado F-3s (to name a few) aren't fighters? I'm sure their pilots &
GIBs would be surprised to hear that! ;)
Well, also the guy in the back with a gun telling the pilot where to
go makes it a rather strange combination LOL
BOFH excuse #396:
Mail server hit by UniSpammer.
  #38
Old February 12th 08, 10:37 AM posted to rec.aviation.military.naval
fudog50[_2_]
What would certainly be interesting is to see the Stats on how many
cat shot 2 engine jets with a maintenance failure or FOD on one engine
made it back around to a "no event, single engine trap".
I know first hand one incident in a previous prowler command I was
MMCO and the Pilot was very happy he had 2 engines after losing one on
takeoff due to maintenance error. The 4 souls made it back safely on
one engine.
We all know the biggest arguement is blue water ops it is better to
have 2 engines.
Redundancy is the key arguement, not performance.
Reliability in normal ops has surely improved, but have the FOD #'s
gone down? Maintenance error? I would bet stats show they have
improved but by how much?
Lets not get confused with a turbo fan that sits high up on a
commercial jet, with a vacuum cleaner on the flight deck.
Sure the turbo fans have been certed for 2 engine long haul
transoceanic flights, but they don't operate in the same environment,
not even close as a Navy Fighter/Bomber/Jammer with a turbojet.
It's a great debate either way. Bottom line is cost over safety. I
would like to see the stats before I could come up with a decision.
Other than finding a needle in a haystack using FAA website, NTSB and
Naval safety center, does anyone have stats on Navy Jets having 2
engines making it back to ground safely with a one engine failure,
(combat, FOD, maintenance) readily available to peruse?
It don't matter anyway JSF is being shoved down the Navy's throat
(gag).
OBTW, with JSF where will you get the 270 VDC? You sure can't get it
from deck edge or hangar SESS. It is estimated 4 million per carrier
for that MOD.
(The new Mobile Electric Power Plant (MEPP) has 270 VDC. This MEPP
also can supply Hawkeye H2K with enough power to be the single power
source.)
This new MEPP is being carrier OpEvaled right now. It probably will
pass OpEval.
But then how many will a carrier need for JSF and H2K? 30 of these at
least on each carrier? Has this been calculated into "deck multiple"?
Can the carrier AIMD IM4 division fix it? Can you say Contractor
support again? Please can we have it?
This is the best arguement of all to scrap JSF, we don't need it, and
too expensive to support. Let alone the single engine arguement.
Super Hornet is plenty enough to get us through 2030 at least, and
all the ILS elements are in place and are strong.
Thanks.
On Mon, 11 Feb 2008 21:34:58 GMT, Ed Rasimus
Robin
To name just a few.
Ed Rasimus
  #39
Old February 12th 08, 08:28 PM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
dott.Piergiorgio
Aside that I refer to J-Girls as "Foemina Japonicus" (subtly pointing
that they're a different stock of women) I roughly agree about japanese
girl's dressing; I think that is because of the tendency of Japanese
legs to being not exactly straight; but I disagree about sinking
bottoms; I take this for what in this part of Italy we call "culi bassi"
that is, bottoms whose are low; In my experience with Japanese girls,
both in pics and in RL, I think the standard definition I give for their
asses is "flat" ("Culo piatto"), that is, aren't bulging from the back.
I guess that this stem from the Latin vs. German POV on female Aesthetic
Best regards from Italy,
Dott. Piergiorgio.
  #40
Old February 13th 08, 08:47 AM posted to rec.aviation.military.naval
Dave[_6_]
fudog50 wrote in :
[redacted]
for that MOD.
source.)
pass OpEval.
Last time I checked, carriers didn't depend on MEPPs. That's what deck edge
power is for. I'm sure they can put a system on a carrier to provide 270 VDC
for less money than trying to outfit with MEPPs that will sit unused and take
up space most of the time.
Dave in San Diego
AT1 USN Ret
Engine-out procedures and eccentric forces on engine pylons Mxsmanic Piloting 18 May 26th 07 01:03 AM
Westland Wyvern Prototype - RR Eagle Engine - Rolls Royce Eagle 24cyl Liq Cooled Engine.jpg Ramapo Aviation Photos 0 April 17th 07 09:14 PM
Saturn V F-1 Engine Testing at F-1 Engine Test Stand 6866986.jpg [email protected] Aviation Photos 1 April 11th 07 04:48 PM
F-1 Engine for the Saturn V S-IC (first) stage depicts the complexity of the engine 6413912.jpg [email protected] Aviation Photos 0 April 9th 07 01:38 PM
1710 allison v-12 engine WWII p 38 engine Holger Stephan Home Built 9 August 21st 03 08:53 AM
