![]() "Al" wrote in message . .. I know this suggestion may be a bit far out, and you may not have the time or ability to make it happen, but perhaps one of your friends would. How about getting a slightly clapped out fuel truck, and setting up yourself as a distributor, and going and getting a load at a time of untainted fuel, and bringing it back and either using it yourself, or selling it to yourself and a few others? Thinking about it. Now looking for a fuel source. Of course, then I would have to go through a huge bureaucratic process to get that truck onto the field. But...I'm thinking about it. Good. Until a few people start doing that, the FBO's will continue to sit on their butts, and not go out of their ways to make good fuel available, along with the 100LL. -- Jim in NC |
On Apr 12, 10:56*pm, "Morgans" wrote:
"Al" wrote in message . .. *I know this suggestion may be a bit far out, and you may not have the time or ability to make it happen, but perhaps one of your friends would. How about getting a slightly clapped out fuel truck, and setting up yourself as a distributor, and going and getting a load at a time of untainted fuel, and bringing it back and either using it yourself, or selling it to yourself and a few others? Thinking about it. *Now looking for a fuel source. *Of course, then I would have to go through a huge bureaucratic process to get that truck onto the field. *But...I'm thinking about it. Good. *Until a few people start doing that, the FBO's will continue to sit on their butts, and not go out of their ways to make good fuel available, along with the 100LL. -- Jim in NC The problem with this is that it is easy to find used fuel trucks. However, driving them off of the airport requires insurance that will make your auto fuel cost more that than the 100LL unless you are selling or using very large quantities of fuel. This is why most Av- gas trucks never leave the airport. Brian |
![]() "Brian" wrote The problem with this is that it is easy to find used fuel trucks. However, driving them off of the airport requires insurance that will make your auto fuel cost more that than the 100LL unless you are selling or using very large quantities of fuel. This is why most Av- gas trucks never leave the airport. The next best thing would be to get to know someone that has a fleet of 18 wheeler delivery trucks, and see if he will load one of the cells in his truck with some clean premium, and bring it to you at the airport. -- Jim in NC |
On Mon, 07 Apr 2008 19:41:39 -0700, Al
wrote: I just happened to see a sticker on a fuel pump today that stated "may contain up to 10% ethanol" while I was filling my car this morning. Man, what state is that far behind the times? Here in Michigan they started doing that IIRC in the late 70's. Now they no longer tell you whether the fuel has alcohol in it or not. The sticker only says meets standard such and such. Upon further investigation with my fuel retailer, the local fuel jobber, and the fuel distributor here in Spokane, Washington that there is a federal mandate to add 9 billion gallons of ethanol per year to the nationwide gasoline fuel stream. A new twist is a 5.1 cent per gallon federal fuel tax break to the oil companies to get this "alternative" fuel into the market. Tomorrow (April 8) is the first day of the program and the dealers get their price tonight. According to my sources, there is a possibility that some retailers may opt out, however if that 5.1 cent break is passed on to them, it won't be likely. I was lucky and just happened to ask the right question at the right time. I haven't seen an outcry on this issue by EAA, AOPA or any other aviation group. AOPA has been working on this for some years. They have successfully fought battles in a number of states that were going to mandate Alcohol in all gas at the pumps. This is a nationwide situation. Not just in a few states. You may not find non-ethanol autogas at your usual outlet. Our jobber started mixing in ethanol last week, however I had not purchased any since mid-March so was unaware. In essence, with the 5.1 cent per gallon tax break, the US federal government has just killed the Aviation autogas concept. I'm trying to locate a new source, but may not be successful. The ethanol is added at the distribution rack. Chevron and a couple others are requiring their retailers to go to E-10. Al Spokane, Wa 1964 Skyhawk with an AutoGas STC Roger (K8RI) ARRL Life Member N833R (World's oldest Debonair) www.rogerhalstead.com |
On Wed, 23 Apr 2008 05:33:30 +0000 (UTC), Bertie the Bunyip
wrote: wrote in : On Mon, 07 Apr 2008 19:41:39 -0700, Al wrote: I just happened to see a sticker on a fuel pump today that stated "may contain up to 10% ethanol" while I was filling my car this morning. Man, what state is that far behind the times? Here in Michigan they started doing that IIRC in the late 70's. Now they no longer tell you whether the fuel has alcohol in it or not. The sticker only says meets standard such and such. In the 70s it was being called "Gasahol" and was from a seperate, labeled pump. Although they called E10 Gasohol, here in Michigan there were no separate pumps. Typically there was a sticker that said the gas contained 10% Alcohol. Some stations IIRC did still offer "uncontaminated gas" in a separate pump or pumps. I don't remember ever seeing a serrate pump for the Gasohol locally. However I don't claim to have an infallible memory. Seems like I was wrong one time...don't remember why though. Bertie Roger (K8RI) ARRL Life Member N833R (World's oldest Debonair) www.rogerhalstead.com |
A GA pilot's worst nightmare? | Kingfish | Piloting | 49 | February 1st 07 02:51 PM |
Our Worst Nightmare? | alank | Piloting | 56 | January 10th 07 10:10 AM |
Nightmare (long story) | JJS | Owning | 7 | April 2nd 06 11:34 PM |
Eurofighter is turning into German nightmare | Chad Irby | Military Aviation | 45 | October 4th 03 03:18 AM |
(long) WxWorx arrived... | Tom S. | Piloting | 0 | September 9th 03 04:54 PM |
