Is it safe/wise to fly a Cessna 172R from Telluride to Aspen? If so, what
conditions or restrictions (if any) should be observed? |
Are you referring to a real airplane or simulated flight with MSFS?
Viperdoc writes:
Are you referring to a real airplane or simulated flight with MSFS? I'm asking about real airplanes, subsequent to a simulated flight with the same aircraft that ended tragically just a few minutes ago, probably due to icing, although I'm not sure. I tried the flight as an experiment to see if it was possible, and I'd like to know from pilots of the real aircraft whether or not it would be possible or safe to attempt it in real life. Weather at Aspen was low IFR so I had planned to divert to Garfield County, but I lost control of the aircraft about 20 miles southeast at 12500 feet and impacted terrain. |
Mxsmanic wrote in
: Viperdoc writes: Are you referring to a real airplane or simulated flight with MSFS? I'm asking about real airplanes, subsequent to a simulated flight with the same aircraft that ended tragically just a few minutes ago, probably due to icing, although I'm not sure. I tried the flight as an experiment to see if it was possible, and I'd like to know from pilots of the real aircraft whether or not it would be possible or safe to attempt it in real life. Weather at Aspen was low IFR so I had planned to divert to Garfield County, but I lost control of the aircraft about 20 miles southeast at 12500 feet and impacted terrain. you weren;t in an aircraft, fjukkwt Bertie |
Mxsmanic wrote in
: Viperdoc writes: Are you referring to a real airplane or simulated flight with MSFS? I'm asking about real airplanes, subsequent to a simulated flight with the same aircraft that ended tragically just a few minutes ago, probably due to icing, although I'm not sure. I tried the flight as an experiment to see if it was possible, and I'd like to know from pilots of the real aircraft whether or not it would be possible or safe to attempt it in real life. Weather at Aspen was low IFR so I had planned to divert to Garfield County, but I lost control of the aircraft about 20 miles southeast at 12500 feet and impacted terrain. Wow. Our resident ace pilot can't even fly a 172 on his simulator! I wonder who give him directions on how to pee. |
On May 11, 9:20*am, Benjamin Dover wrote:
Mxsmanic wrote : Viperdoc writes: Are you referring to a real airplane or simulated flight with MSFS? I'm asking about real airplanes, subsequent to a simulated flight with the same aircraft that ended tragically just a few minutes ago, probably due to icing, although I'm not sure. *I tried the flight as an experiment to see if it was possible, and I'd like to know from pilots of the real aircraft whether or not it would be possible or safe to attempt it in real life. Weather at Aspen was low IFR so I had planned to divert to Garfield County, but I lost control of the aircraft about 20 miles southeast at 12500 feet and impacted terrain. Wow. *Our resident ace pilot can't even fly a 172 on his simulator! In this case the output of the game had a modicum of accuracy, MX would have crashed a real 172 also. Cheers |
On Sat, 10 May 2008 14:45:20 -0700 (PDT), More_Flaps
wrote: On May 11, 9:20*am, Benjamin Dover wrote: Mxsmanic wrote : Viperdoc writes: Are you referring to a real airplane or simulated flight with MSFS? I'm asking about real airplanes, subsequent to a simulated flight with the same aircraft that ended tragically just a few minutes ago, probably due to icing, although I'm not sure. *I tried the flight as an experiment to see if it was possible, and I'd like to know from pilots of the real aircraft whether or not it would be possible or safe to attempt it in real life. Weather at Aspen was low IFR so I had planned to divert to Garfield County, but I lost control of the aircraft about 20 miles southeast at 12500 feet and impacted terrain. Wow. *Our resident ace pilot can't even fly a 172 on his simulator! In this case the output of the game had a modicum of accuracy, MX would have crashed a real 172 also. Cheers there is the real life case of a clown who stole a cherokee 140 from Darwin Airport in the Northern Territory. now remember that the cherokee has the reputation for being one of the easiest to fly blandsville aircraft. said clown crashed with fatal consequences just over the piano keys on takeoff. mx if you ever try flying a real one can I watch? make it in winter so we can stand there warming our hands over the fire.... Stealth Pilot |
![]() Weather at Aspen was low IFR so I had planned to divert to Garfield County, but I lost control of the aircraft about 20 miles southeast at 12500 feet and impacted terrain. MSNTSB Report: 'Probable cause of accident: Pilot disorientation caused by hypoxia due to lack of simulated oxygen' -c |
This was by any measure a poorly designed experiment. The only lesson
to be learned is planning is necessary for safe flight. Superior planning is necessary if there are questions about the airplane's suitability. |
Uncontrolled Engine Compartment Fire Possible for Cessna 172R, 172S, 182T, T182T, 206H, and T206H Models | Larry Dighera | Piloting | 0 | April 19th 07 04:31 PM |
'99-'00 172R vs 172SP: R is good? or the weak little brother? | XrayYankee | Owning | 9 | May 1st 06 06:07 AM |
C-172R to SP upgrade | Greg Farris | Owning | 5 | May 6th 05 10:17 AM |
172P vs 172R for instrument platform..... | Jonathan | Instrument Flight Rules | 6 | July 22nd 04 01:52 AM |
FS: 1997 Cessna 172R | Alan Adamson | Aviation Marketplace | 1 | June 1st 04 12:57 PM |
