Favorite panel gadget?
Old May 15th 08, 09:11 PM posted to rec.aviation.piloting
Dudley Henriques[_2_]
Default Favorite panel gadget?
Mxsmanic wrote:
Dudley Henriques writes:
Not a moment's hesitation.......An angle of attack indicator.
I can understand that. Why are angle-of-attack indicators so rare in
aircraft? Is it something that is difficult to measure? I should think it
would be far more useful than trying to figure out what combination of speed,
weight, pitch angle, etc., is likely to produce a stall.
You are absolutely correct. The military for years has used AOA to
determine cruise, climb, descent, and approach speeds. Almost all high
performance aircraft performance charts use AOA to determine performance
criteria.
For example, a T38 is flown on approach at an optimum AOA of .6 units.
This optimizes the aircraft at whatever approach airspeed the GW
dictates. (remaining fuel). The aircraft can also be flown manually on
approach using an IAS of 155kts plus fuel, which is an additional 1kt
for every l00lbs remaining over 1000lbs. You can fly the approach either
way but as you can see, it's a lot easier using AOA.
Some T38's BTW, incorporate an AOA indexer on the glare shield that will
automatically keep you on speed if you fly the airplane in the on speed
green "donut". The top of the indexer is a red chevron pointing downward
to indicate you're too slow on the approach. The bottom is a red chevron
pointing upward showing too high an airspeed. Keeping the airplane right
on speed in the green donut gives you .6 units AOA regardless of the
gross weight of the airplane.
To expand just a bit on the T38, the AOA indicator shows up as arbitrary
"units" ranging from 0 to 1.0 based on the angle range of the AOA vane.
Some other helpful data supplied by the AOA indicator if I remember
right for the Talon is a maximum range at about .2 units, and a maximum
endurance at .3 units. Initial stall buffet is t about .9 units.
In light civilian airplanes, AOA indicators can be quite useful although
the low speeds involved don't necessarily produce the same advantages
found in much higher performance airplanes where the slightest
difference between optimum and off optimum AOA for a specific
configuration can mean big differences in performance.
Personally, I like the idea of basing even light airplane performance on
AOA. If this format is begun at the manufacturer's level and proper
testing on the aircraft done at that point, the end user has a simple
and precise instrument on which to base the aircraft's performance. This
decreases cockpit workload which is a good thing in itself.
It is my understanding after talking to some ATR (ATP) friends of mine
flying for major air carriers that their companies have been engaged
with manufacturers on better ways to use AOA in their aircraft operations.
Dudley Henriques
Old May 15th 08, 09:23 PM posted to rec.aviation.piloting
think it
speed,
criteria.
Correction on the indexer. The lower chevron should read yellow and not red.
Dudley Henriques
Old May 16th 08, 03:53 PM posted to rec.aviation.piloting
Tina
For plain vanilla flying, D, (point to point in an M20J) what
improvement might we expect using aoa instead of what we use now in
takeoff, cruise, or landing phases?
I can appreciate aoa's utility in higher performance a/c, or maybe
when flying close to some edge, but am not sure how it would improve,
for example, our take off (best rate for the first few hundred feet,
that's less than 30 seconds of flying) , then a prudent cruise climb
to our en route altitude. En route, usually as high as possible
consistent with the trip length and winds, we go to the lowest rpm we
can, and maintain the same ias going lower until approaching the OM.
Old May 15th 08, 07:49 PM posted to rec.aviation.piloting
Gezellig
Why is this not standard?
Old May 15th 08, 09:16 PM posted to rec.aviation.piloting
I gave up years ago trying to figure out why things that make flying
safer and better are not made standard. :-)))
AOA indication has always as far as I know been considered an option on
light civilian aircraft. There are costs involved as well as performance
testing to determine optimum parameters....another step in the process.
The main reason I believe is the fact that light civilian airplanes fly
in the area of lowest performance where the raw data already existing
using basic instrumentation is sufficient.
Dudley Henriques
Old May 16th 08, 02:38 PM posted to rec.aviation.piloting
They're somewhat more common on experimentals (i.e., homebuilts), and
I agree, I wish I had one on even my lowly Cherokee.
Old May 15th 08, 01:36 AM posted to rec.aviation.piloting
If money were not an issue, and you had the opportunity to install a single
new gadget in your instrument panel (without removing anything else--assume
you have the room for something new), which instrument would you install, and
why?
Perhaps an instrument that shows wind velocity.. I guess this can only
be calculated if there is a GPS to figure out ground speed.
Old May 15th 08, 06:30 PM posted to rec.aviation.piloting
JB
why?
Flush toilet. I am REALLY tired of trying to stand up in a single
engine, pull my pants around my ankles, and take care of business
without totally ending up in some vertical dive-bombing death spiral.
Sticking my crank in a hole in the instrument panel would be
wonderful. Ladies...sorry, I don't know what to suggest.
--Jeff
Old May 15th 08, 07:05 PM posted to rec.aviation.piloting
Shirl
I know this will sound like "mom", but ... don't have coffee before you
leave, and "go" before you saddle up?
Favorite Airlines Kloudy via AviationKB.com Piloting 0 May 7th 08 06:20 PM
density altitude calculator and wind calculator on web site and asGoogle gadget Howie Piloting 3 August 5th 07 11:52 PM
density altitude calculator and wind calculator on web site and asGoogle gadget virtuPIC[_2_] General Aviation 0 August 4th 07 05:55 PM
Favorite picture of my favorite airplane. russell[_2_] Aviation Photos 3 August 4th 07 04:39 PM
Weather gadget Bill Daniels Soaring 1 November 19th 03 03:38 PM
