SPOT messenger
Old June 17th 08, 07:24 PM posted to rec.aviation.soaring
Ramy
Default SPOT messenger
I still mount mine on the parachute shoulder straps (below my
shoulder), so it is pointing 45 degrees or so. After experimenting
with it in various angles I determined it made no difference. Allen
Silver just repacked my chute and had no concerns about the location.
As for that particular flight, I don't know who else flew in the area
with Spot (suprisingly, even with it's low cost - about a cost of 2
tows nowaday, pilots are not in a hurry to buy one) so can't compare,
but I can tell that nothing else was different from the rest of the
flight, and it was mostly flying straight so the Spot had a clear view
of the sky the whole time. After over 10 flights with the Spot (still
running on the original batteries btw), this is the first time I had
more then 30 minutes without track.
Ramy
On Jun 17, 9:48*am, Darryl Ramm wrote:
On Jun 17, 9:14*am, Greg Arnold wrote:
Ramy
Spot uses the Globalstar L-Band simplex links. L-band *is relatively
immune to rain attenuation, rain/water droplets suspended in storm
clouds are likely the worse case scenario. A guess for bad rain
attenuation might be something like only a dB or so at L-band. The GPS
signals are in the same frequency bands and will have similar
attenuation. So my first guess is clouds, even storm clouds are not
likely to be the issue.
So the next question is did anybody else flying in the genral area
have the same problem? I was flying in the Mendocinos at the same time
and had no SPOT problems but that is probably far enough away to not
count, except to exclude more systemic problems. The next question is
did the unit have a full view of the sky or are you still mounting it
on your parachute harness? *I'm not sure if this is on your shoulder -
in which case your head (hopefully opaque at L-band :-) ), RF opaque
parts of the fuselage/canopy frame area, etc. will be obscuring lots
of the sky, or vertical on your harness in which case far more of the
sky will likely be obscured. Both of these will affect coverage as
Global star satellites fly into and out of the now fairly restricted
sky view or as you turn the direction of the obscured antenna to bring
Globalstar or GPS satellites into view.
I think SPOT is fantastic, fly with one all the time in SPOTcast mode,
but I'm not giving up on my 406MHz PLB on my parachute harness.
Darryl
I have a SPOT on order. *Where is the best place to mount it so it has a
full view of the sky (excluding the top of the glare shield)? * Will it
work under a fiberglass glare shield?
Greg
People are mounting them on their harnesses and apparently getting
them to work, but the problems that Ramy reports may show this is not
as reliable as a less obscured location. I'll remind people of Allen
Silvers' (experienced parachutist/parachute rigger) warning against
mounting them on the shoulder area of a parachute.
Ideally you just want it mostly flat and not obscured. I mount mine on
the right canopy rail of my ASH-26E using 3M dual-lock tape. You can
see it herehttp://www.flickr.com/photos/darrylramm/2082630811*The
glareshield should not present a problem for RF signals but you need
to unit where you can press buttons, check LEDs (flat batteries etc.).
On the canopy rail I have to pop the unit off to check the LEDs etc.
This may not work on all gliders but even on my DG-303 with a thin
rail I would have just installed a mounting plate on the narrower
canopy rail.
If you do need to end up mounting on the glareshield area the bright
orange color/reflections are likely to be a distraction. A black cloth
covering could work. SPOT also make a sturdy looking black nylon bag/
holster for the SPOT (purchased separately, does not come with it). I
saw a Holster for sale at at Williams Soaring but have not seen them
elsewhere, I think they had a SPOT logo on them. You might be able to
mount that holster on the glareshield and slip the spot unit into it
for use. Hopefully it won't get too hot in the sun. Braver people
could disassemble the SPOT (disassembly is easy) and paint it with
Krylon Fusion flat black paint, but I'd be worried of the paint
scratching off over time or the unit getting too hot in the Sun.
This all assumes you care mostly about use in flight, I do, and thing
the SPOTcasting/tracking feature is the best thing. If you mostly care
about the "911" feature and the SPOT unit going with you in a bailout,
then put it on your parachute harness with a Silver Parachute SMAK
pack (the large size, seehttp://www.silverparachutes.com/smak_pak.html
) *or similar.
Darryl- Hide quoted text -
- Show quoted text -
  #32
Old June 17th 08, 07:36 PM posted to rec.aviation.soaring
Darryl Ramm
Ramy
Ramy
Darryl
Greg
canopy rail.
) *or similar.
Well maybe you just determined the orientation does make a
difference! Taking a wild guess, you have a quarter or so of the
sky coverage of a level unit and going to be much more sensitive to
relative location of passing globalstar satelites. But again that
might be a good trade off if you want the unit to go with you on a
bail out. I also don't get the concern about cost or people worrying
about the unit being replaced by something better. My only concern was
does it work (in tracking/SPOTcast mode), and clearly it does work
pretty darn well. At that cost you can afford to throw it away and buy
the new model after not too much time. For the cost it is a wonderful
piece of mind for family and friends.
Darryl
  #33
Old June 17th 08, 09:37 PM posted to rec.aviation.soaring
5Z
On Jun 17, 12:24 pm, Ramy wrote:
After over 10 flights with the Spot (still running on the original batteries btw),
I did a test with my unit and with spotcasting 24/7 it ran for over 2
weeks. When the power LED illuminated RED, I ran it for another few
days before calling the test off.
Also, a few times I would forget to take the SPOT out of the car
overnight, so it was in the garage (wood frame construction, 2nd floor
above) and still got many of the messages through.
-Tom
SPOT messenger [email protected] Piloting 19 June 17th 08 04:42 PM
SPOT Satellite Messenger [email protected] Soaring 9 January 3rd 08 06:30 PM
SPOT Satellite Messenger Marc Ramsey[_2_] Soaring 7 October 3rd 07 10:30 PM
Lawrence Sperry's Messenger biplane landing in front of the US Capitol Building, Washington DC Dave Kearton Aviation Photos 1 May 10th 07 07:48 AM
Dont shoot the messenger Jeff Piloting 5 February 11th 04 09:12 AM
