Pitch vs. trim in flight phases
Old May 16th 08, 08:45 PM posted to rec.aviation.piloting,rec.aviation.student
gatt[_3_]
Default Pitch vs. trim in flight phases
Mxsmanic wrote:
Tina writes:
Perhaps the difference between the MSFS and reality is the notion of
adjusting trim to take pressure off the yoke is one of those 'it
doesn't matter in simulated flight' issues.
Some controls for use with the sim, including the Saitek X52 joystick that I
have, are spring loaded, and MSFS behaves in such a way that you must maintain
pressure against the springs if the aircraft isn't properly trimmed.
I don't know how that compares to the Saitek Aviator which is what I
use, but I'm thinking of removing the springs and replacing them with
stiffer ones to make it a bit more realistic.
-c
Old May 16th 08, 08:49 PM posted to rec.aviation.piloting,rec.aviation.student
Dudley Henriques[_2_]
gatt wrote:
Mxsmanic wrote:
Tina writes:
that I
maintain
-c
Ah yes......but at what airspeed? (slugs dynamic pressure vs unboosted
control surfaces :-))
Dudley Henriques
Old May 16th 08, 10:59 PM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
gatt writes:
I'm sure there's some lack of realism, but I don't fly to feel control
pressures. I don't take an interest in the visceral sensations of flying.
I'm sure that the same pilots who enjoy flying in an open-cockpit biplane
built of cloth-covered wood probably wouldn't enjoy a desktop sim, because
they like physical sensations. However, pilots (and others) who like the
considerable intellectual exercise of flying and navigation might not care
about the physical effects, and indeed, for some (important) types of flying,
those physical sensations are not important.
If someone thinks that physical sensations are essential, I suggest he put on
a blindfold and see how long he can remain in straight and level flight with
those sensations alone.
Old May 17th 08, 05:21 AM posted to rec.aviation.piloting,rec.aviation.student
The Visitor
I've lost track. Now I just fly the trim.
Mxsmanic wrote:
In a small GA aircraft, in which phases of flight will you normally use mostly
trim to adjust pitch, and in which phases will you normally mostly use the
yoke?
Typical power settings during cruise and other phases of flight Mxsmanic Piloting 99 October 2nd 06 10:12 AM
Making a pitch trim indicator for a Glasair [email protected] Home Built 5 September 13th 06 02:30 AM
$30,000 pitch links Stuart Fields Home Built 3 January 16th 06 02:13 AM
Cherokee Electric Pitch Trim Jonathan Goodish Owning 4 November 18th 04 02:43 AM
ALTRAK pitch system flight report optics student Home Built 2 September 21st 03 11:49 PM
