Why not use the F-22 to replace the F/A-18 and F-14?
Old February 22nd 04, 09:50 PM
Tarver Engineering
"Ian" wrote in message
"Tarver Engineering" wrote in message
"R. David Steele" wrote in message
|The Tomcat is gone quicker than you can think....
|There is a big push by CNO to axe the F-14 sooner than planned, like
|now is too late...watch and see.
|The F/A-18 (I assume you mean the B/C/D models) already has a
|replacement, E/F. I don't think you are following current Naval
|Aviation very well.
|There is no need to replace the E/F Hornet, it will be pulling
|fighter/CAP/FAC/Bomber/tanker etc. duties for the next 10 years.
|Totally capable of performing all the above, with no current or
future
|enemy threat that can match it.
Yes, I am aware that the E/F variants are the upgrade to the
current F/A-18 and the F-14. However by the time the FB-22 is
online, even those versions will be dated.
Less dated than the F-22.
You are not considering the F-22's two greatest flaws, the pre-96 Ada
and
the Mil-spec components. The entire procurement of the F/A-18E is a
generation ahead of the F-22.
What language is F-22 software written in? I presume Ada-95?
The F-22 is older than that.
The F-35 has a chance of being more successful than the F-22 based solely on
it being post '96 Ada and having a late infusion of the RPL model. The
system itself has moved on since the parting and coding of the F-22.
  #32
Old February 22nd 04, 10:08 PM
Henry J. Cobb
Andrew C. Toppan wrote in message . ..
On Sun, 22 Feb 2004 14:36:35 GMT, R. David Steele
The F-35 is basically the same plane as the F-22. It has been
modified to be a carrier aircraft.
Huh? The F-35 is absolutely nothing like the F-22.
The F-35 was not "modified" to be a carrier aircraft, it was DESIGNED
AS a carrier aircraft.
And as Andrew well knows, only two of the three F-35 variants have
been designed to operate off of ships.
The F-35A is no more sutiable for shipboard service than the F/A-22
is.
-HJC
  #33
Old February 22nd 04, 10:26 PM
Ian
like
|Aviation very well.
future
and
Thats interesting cos I'm sure I've read somewhere that Eurofighter is
written in Ada-95 and flight standard C?
  #34
Old February 22nd 04, 11:14 PM
Tarver Engineering
like
|Aviation very well.
future
Ada
and
After a series of discussions WRT Ada here at ram with Ada experts i was
willing to accept the idea that Ada was fixed by 1996. Perhaps I am using
an incorrect identifier and it is Ada-95
  #35
Old February 22nd 04, 11:20 PM
Keith Willshaw
For some reason I had thought that the C-17 was built by
Lockheed, not McDonald Douglas (now Boeing).
That would McDonnell Douglas
Since Boeing is now
the contractor,
Make that owner.
what do they have in their line up that would be
similar? Basically that would be the short field operation plus
being able load and unload like the C-17 does.
Civilian use doesnt typically require such a facility.
I am not a fan of idea of taking an airliner design and making it
a cargo plane.
Most civilian cargo planes are just that.
Keith
  #36
Old February 22nd 04, 11:26 PM
Chad Irby
Ada-95. Like a lot of the F-22 software, which got recoded because it
was easier to support. Which is why a good part of the F-35 software is
based on the F-22 software...
cirby at cfl.rr.com
Remember: Objects in rearview mirror may be hallucinations.
Slam on brakes accordingly.
  #37
Old February 22nd 04, 11:30 PM
Keith Willshaw
| | Remember that we are planning for a war with China by the end of
| | the decade.
|Are you planning to fight them all yourself or do
|you have a couple of buddies lined up to help ?
|Keith
Ok, ok!!!
Not everyone keeps up with various policies and DoD planning.
the current chairman of the Joint Chiefs, Gen Myers, was picked
to plan for this potential war. China has let it be known, there
are a number of papers coming out of their post graduate officers
school, that they plan to challenge us for control of the far
east. That means control over India, most of SE Asia (down to
Australia), Japan, the Philippines and Siberia.
Hey if they choose to take on India and Russia they'll
have enough on their plate that they wont take on the
USA as well
Also China has sent it agents off its soil as it never has in
5000 years. They now run the Panama Canal.
No they dont , Hutchison Whampoa who own the Panama Canal
Co are a Hong Kong based limited company run the canal.
Have bases all
throughout the Caribbean. Now own a port (former naval base) in
San Diego.
Last time I checked the port of San Diego was a Public Benefit
Corporation
Keith
And they have extensive operations all throughout
North Africa.
It is going to be interesting starting somewhere between 2008 and
2012.
Yeah I'll be watching as you and your buds invade China
Keith
  #38
Old February 22nd 04, 11:33 PM
Keith Willshaw
| Should we be thinking of using the FB-22 Raptor as a replacement
| for the F/A-18 (and the F-14)?
|Lots of luck making a carrier landing in an F-22
| I know that the current F-22 was
| not designed to be heavy enough for naval use, but it could be
| re-engineered. They are planning to bring the FB-22 (bomber
| version that carries 30 2000 lbs bombs) online in the future.
| Why not upgrade it then?
|3 x 2000 lbs perhaps certainly not 30
In a bomber version, the fuselage would be longer and the wings
far larger to give the bomber greater range more than 1,600
miles, compared with the F-22's 600-plus and bomb-carrying
capacity.
That takes a little more than stretching the airframe to achieve this.
The suggested FB-22 does not have the range or mods you
claim. Such an aircraft would be a new design and given the
progress being made with UCAV's is unlikely to happen
IMHO
The FB-22 would replace the Air Force's F-15E and take
over some missions for long-range bombers such as the B-2 and
B-1. The initial design envisioned a plane that could carry 24
Small Diameter Bombs, which weigh only 250 pounds. Using Global
Positioning System guidance, the small bomb would be as lethal as
a 2,000-pound bomb.
No sir , GPS guidance systems are already available for
2000lb bombs
A regular F/A-22 would carry eight Small
Diameter Bombs. An FB-22 would carry 30.
Which would make a bomb load of 8000 lbs not
60,000
Keith
  #39
Old February 22nd 04, 11:48 PM
Tarver Engineering
"Chad Irby" wrote in message
solely on
Was to be, but tabbing to the F-22 would be foolish now.
  #40
Tarver Engineering
solely on
I thought that we had moved beyond ADA?
How?
"C-175 SoCal Beware" Original Poster Replies Bill Berle Aviation Marketplace 8 July 8th 04 07:01 AM
More LED's Veeduber Home Built 19 June 9th 04 10:07 PM
Replace fabric with glass Ernest Christley Home Built 38 April 17th 04 11:37 AM
RAN to get new LSD class vessel to replace 5 logistic vessels ... Aerophotos Military Aviation 10 November 3rd 03 11:49 PM
Air Force to replace enlisted historians with civilians Otis Willie Military Aviation 1 October 22nd 03 09:41 AM
