jet pack
Old August 11th 08, 09:01 PM posted to rec.aviation.homebuilt
Jim Logajan
Default jet pack
"Capt. Geoffrey Thorpe" The Sea Hawk @See My Sig.com wrote:
You are correct the center of gravity will align with the aerodymanic
center of effort. But, where are the Cp and Cg on the "jet pack" with
ducted fans in the "tractor position" - and how much stability will it
add in a hover?
Obviously the Cp and Cg are close enough together that it doesn't matter
much where they are - it appears it would be unstable with or without
power.
In fact I should confess that I only posted my comments in a very modest
effort to promote lighter-than-air (LTA) as a more viable option for such
things. Of course the "open" technical challenges and usage tradeoffs of a
personal "portable(!?)" airship are quite different from rotorcraft.
  #32
Old August 11th 08, 10:43 PM posted to rec.aviation.homebuilt
Default jet pack
"Jim Logajan" wrote in message
a
Would this sort of concept use He and a compressor to recover it after a
flight, or hot air?
He would, I think, take a lot of compressing to make it portable - Right?
Wrong?
I assume you are talking about something with power - one fuel could
provide power and the heat for hot air. The engine cooling / exhaust would
help maintain the temperature inside the envelope?
Geoff
P-61 belly gun pack Dave Kearton Aviation Photos 0 March 2nd 07 09:19 AM
Power pack for camping? LincTex General Aviation 2 June 26th 06 12:40 PM
Jet pack Bob C Soaring 14 January 12th 06 07:11 PM
Jet pack Bob C Soaring 0 January 10th 06 07:21 AM
Pack guns in your little airplane Rich S. Home Built 17 July 13th 03 05:45 PM
